Topic: Wireless robot control (Read 1 time) previous topic - next topic
Wasd9595
Hi
I just finished my first robot. It is very Classic - a platform, two motors and some sensors. My next step is to remote control it wirelessly. I just dont know how to do this. I was thinking about using my iPhone as a controller and later some kind of RC controller. What would you suggest?
Im using the Uno with the official motorshield.
steinie44
If you just want to try "play with' wireless then think about IR.
All you need is an IR receiver, about $2, and a IR remote control.
I use my DVD or my TV remote.
Then later you can upgrade to something else.
raschemmel
I haven't built a robot so maybe I am not "QUALIFIED" to advise but IF I did I would use 433 Mhz RF and not IR.
Arduino UNOs, Pro-Minis, ATMega328, ATtiny85, LCDs, MCP4162, keypads,<br />DS18B20s,74c922,nRF24L01, RS232, SD card, RC fixed wing, quadcopter
AnalysIR
The thing about 433Mhz (and similar ISM RF bands) is that there can be limits on the % of time you can use the frequency - will need a search. So good for occasional control (actually data exchange) but less so for continuous remote control.
IR is good provided you have line of sight to the receiver and using it indoors. (Arduino Libraries - IRLib & IRremote). range up to 15m.
(High power gives you effectively LoS indoors, because of reflections)
My suggestion would be to try using cheap Bluetooth serial adapters, which will give you more than reasonable range indoors and outside. (up to 10m?)
There are other RF modulaes like the nRF24L01 series which may be the next step up (not expensive either & libraries are available for Arduino). Much longer range available.
If you look at remote control of toy helicopters, the cheaper entry level ones use IR & the top end hobby & pro ones use RF.
rogerClark
Quote
Would not be compatible with an iPhone.
Quote
This keeps cropping up over and over again. iPhones are locked and won't communicate with HC05 or HC06 modules.
Get yourself an Android based phone if you want to control using your phone
Freelance developer and IT consultant
www.rogerclark.net
JimboZA
I've used both IR (with a TSOP34838) and Wixel (which is basically wireless USB).
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
shev
Interesting article how you can manage the robot platform with two wheels with the Android smartphone via Bluetooth
http://remotexy.com/en/examples/car/
Is there a code sample.
zoomkat
If your iphone is web enabled, you might consider making a simple router bot and control it via a web page. Some ideas on this below.
http://www.lynxmotion.net/viewtopic.php?f=20&t=6343
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
