Topic: AWind: GUI library for Arduino - TFT and OLED Displays (Read 54218 times) previous topic - next topic
PrSaban
Hi Andrei!
I am using Awind for my TFT LCD ( SSD1963 800x480) . When i complier example "Tabcontrol" , it is ok. But there is a problem, the position where i touch is incorrect with icon . I touch "Tab3" , the screen show up Tab1 window :(
Can you help me to solve this error!
Thanks and again, great job with this library AndreiDegtiarev .
AndreiDegtiarev
Hi PrSaban!
I have answered your question in the another topic in display forum
Regards
Andrei
AWind: GUI library for Arduino - TFT Displays
https://github.com/AndreiDegtiarev/AWind
pbecchi
I am looking for a GUI library that can be ported to ESP8266,
I have donloaded Awind , a perfect tool for my needs , but I am having problems in the porting:
ESP8266 has only few GPIO available and therefore work only with SPI Tft Touch display.
I have found UTFT and UTOUCH libraries working on ESP8266
Nevertheless compilation on ESP8266 give a uge number of errors
Mainly errors are related to PROGMEM costants that are widely used in the code
Any suggestion?
AndreiDegtiarev
The idea to use esp8266 is very interesting. At least this board has enough memory.
I have such board, but I didn't tried it yet.
Can you please give me links to the UTFT und UTOUCH libraries that you use?
At the moment I use arduino 1.6.6 version, which version did you try?
Andrei
pbecchi
Hi Andrei
thanks for your replay!
I did progress a little with charts.pde example :
I had to delete most of PROGMEM but finally I got it compiled :
it start , it show the window with the y scale, then it clear and draw a sin wave, then it show the scale again and when start drawing the sinus again it reset with a Softare Reset error.
Since there is no documentations it is difficult to undertand what the program is doing and to trace the point of the reset!
I will be very glad if you can compile on ESP8266 your code and try the examples: I am not a skilled programmer and I really need your help to go throught the code for debug
Regarding libraries:
for UTFT : github.com/gnulabis/UTFT-ESP8266
for UTOUCH : I made a dummy UTOUCH.h that call the only touch library available https://github.com/spapadim/XPT2046
this is the utouch code:
[code//
#include <Arduino.h>
#include <XPT2046.h>
#include "UTOUCH.h"
UTouch::UTouch(byte tclk, byte tcs, byte tdin, byte dout, byte irq)
 XPT2046 touch(/*cs=*/ tcs, /*irq=*/ irq);
 void UTouch::InitTouch(byte orientation ) {
 touch->begin(240,320);
 touch->setRotation(touch->ROT270);
 touch->setCalibration(176, 256, 1739, 1791);//banggood3.2"
 if(orientation==1)touch->setRotation(touch->ROT0);
 else touch->setRotation(touch->ROT270);
 void UTouch::read() {
 uint16_t x, y;
 touch->getPosition(x,y);
 TP_X = x;
 TP_Y = y;
 bool UTouch::dataAvailable() { return touch->isTouching(); }
 int16_t UTouch::getX() { return UTouch::TP_X; }
 int16_t UTouch::getY() { return UTouch::TP_Y; }
 void UTouch::setPrecision(byte precision) {}
/code]
Has you can see I am very poor programmer! :(
Paolo
elpapais
Hi Andrei.
Nice work!!!
I find your library verry nice!
I have a question:
I can't find a image object.
Is possible to load a image into a box?
Regards.
www.infoportal.it support at infoportal.it
elpapais
Hi Andrei!
Please can you give me a little help?
1) i can't find how to allign to right the TextBoxNumbers
2) i need to have into the tab controll one image. is thath possible? and how?
regards
AndreiDegtiarev
Hi Elpapais,
thank you for the kind words about AWind library!
Unfortunately, the features you are asking are not implemented yet, although it isn't that much work As workaround for the text alignment you can use function SetMargins.
If you know how to draw pictures with the help of UTFT library than you can override function void OnDraw(DC *dc) in the child window of tab control.
Regards,
Andrei
elpapais
Hi Andrei.
Tnx for answer.
margins...
but margins are from top and lef... and the numbers is variant...
you mean one routine can read if units or thens or hundert and so on an make correct lef space?
AndreiDegtiarev
Hi Elpapais,
the text horizontal alignment functionality is implemented (see VacuumPump example and SetHorizontalAlignment function) The changes are not released yet, so that you need clone actual AWind, ASensor and AFrame repositories.
Regards,
Andrei
AndreiDegtiarev
... and sorry pbecchi. I have made couple of attempts, but compilation for ESP8266 is more difficult as I expected. I keep trying
Henrigp
Hello,
very interesting libraries and examples but I can't run it on Arduino Mega 2560  :(
Is it only designed to DUE ?
Thank's
Henri
AndreiDegtiarev
Hi Henri,
It should work on mega too.
Are the examples from UTFT library running ok on your configuration?
What kind of errors do you receive?
Regards,
Andrei
asokolsky
Thanks for AWind, Andrei!
UTFT seems to work on my ST7735S - demos run fine.
Q: UTOUCH seems to be replaced by URTouch.  Any plans to update this dependency in AWind?
Q: I do not intend to use touch screen.  Any plans to make the dependency on UTOUCH optional?
Q: minor suggestion: default serif display in UTOUCH is really ugly.  Your GUI would look better with sans-serif font.  Free sans-serif fonts are readily available.
Thanks again!
asokolsky
My attempts to compile sample Carts fail - can't find headers:
Log.h
LinkedList.h
AHelper.h
I used URTouch instead of UTOUCH as author recommended.
What am I missing?
Thanks!
