Topic: Parallax RFID Scanner (Read 514 times) previous topic - next topic
Trickyrick
Having trouble getting my scanner running.  I have searched this form and found this code but it will not compile
The error is
NewSoftSerial does not name a type                 (not sure what this means)
Code: [Select]
#include "NewSoftSerial.h"
#define txPin 6
#define rxPin 8
//Reader/Writer Commands
#define RFID_READ 0x01
//#define RFID_WRITE 0x02
//#define RFID_LEGACY 0x0F
NewSoftSerial mySerial(rxPin, txPin);
int  val = 0;
//char code[6];     //Note this is 11 for the extra null char?
//int bytesread = 0;
//int flag = 0;
//Tags
//char TAG1[11] = "0800E28C60";
//char TAG2[11] = "0800D9E43E";
  mySerial.begin(9600);
  //  pinMode(2, OUTPUT);
  //  pinMode(4, OUTPUT);
  pinMode(txPin, OUTPUT);     //pin 6
  pinMode(rxPin, INPUT);      //pin 8
  Serial.println("RFID Read/Write Test");
  mySerial.print("!RW");
  mySerial.print(RFID_READ, BYTE);
  mySerial.print(3, BYTE);
  //0th read
  if(mySerial.available() > 0) {          // if data available from reader
    val = mySerial.read();
    if(val != 255){
      Serial.print("Error Code:");
      Serial.println(val, HEX);
  //1st byte
    if(val != 255){
      Serial.print("1st:");
  //2nd byte
    if(val != 255){
      Serial.print("2nd:");
  //3rd byte
    if(val != 255){
      Serial.print("3rd:");
  //4th byte
    if(val != 255){
      Serial.print("4th:");
  delay(500);                       // wait for a 1/2 second
johnwasser
It means you don't have the NewSoftSerial library installed.  You should change NewSoftSerial to SoftwareSerial which comes with Arduino 1.0.x.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
