Topic: Safely remove hardware (Read 467 times) previous topic - next topic
Shtef
Jul 25, 2014, 04:27 pm Last Edit: Jul 25, 2014, 05:18 pm by Shtef Reason: 1
HI!
I connected Arduino Duemilanove w/ATmega328 compatible board (Croduino Basic) to my PC. It works fine.
When I connected it, there is no "Safely Remove Hardware" icon in the system tray and I can't use possibility to properly remove the Arduino board. I disconnected "brutally"  :smiley-red:  the Arduino's board from the USB port and nothing happened. This time.
Is it commont to disconnect the board in this way?
My PC: Windows XP, SP3 32 bits.
Thank you for the answer.  :)
spycatcher2k
Yes this is normal - the remove hardware is usually for storage devices to clear the cache to the storage medium
http://www.uk-pcb.co.uk - UK Based PCB Fab Company
I will code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
Shtef
Thank you, I was a little bit scared of unwanted  consequences.  :)
