Topic: ArduinoBT on Mac OS X Leopard (Read 11083 times) previous topic - next topic
feesta
hi Michael,
I also have had no luck with the possible solutions listed here for leopard. I'm still following the thread hoping for fix.
Jeff
admin
Hello
I've noticed that since leopard was introduced a lot of people have had problems with the BT board.
We are looking into it and (as tinker.it) we are experimenting with other BT modules to be used in future versions of the board (I would like the board to cost less money and be easier to use)
we'll let you know what we find out
m
admin
#17
Mar 03, 2008, 07:54 pm Last Edit: Mar 03, 2008, 07:56 pm by admin Reason: 1
to auco:
the source is always available :
see the "source code" section of http://www.arduino.cc/en/Main/Software
how to upload to the board via the command line:
/Applications/arduino-0010/hardware/tools/avr/bin/avrdude -p m168 -b 115200 -c stk500v2 -P /dev/tty.ARDUINOBT -e -U flash:w:yourfile.hex
/dev/tty.ARDUINOBT is your bluetooth board while yourfile.hex is the hex file generated by arduino.
(you can find it in /tmp/buildXXXXX where XXXX changes for every sketch... this is where arduino compile the code when you hit the "compile" button)
John_Ryan
"Busy" seems to be the common denominator, and that's regardless of which version of OSX since I got the same on 10.3.9.
I solved that, by replacing "every instance" of the RXTX library with the one supplied in 10. Scattered around the drive, I found 8 instances, replaced them all with the version from 10 (I could have deleted them but didn't for just in case sake).
It didn't fix the problem until I rebooted the machine, but I only discovered that by accident when a brief power outage caused a reboot.
So, anyone that's experiencing a similar problem, once you've replaced RXTX "everywhere" try rebooting the machine.
auco
Thanks for all the answers!  :)
I made some more tests with my WinXP-Laptop. At first I had similar problems as Brenin - Arduino010 freezed on upload until I manually killed the avrdude process or I got a "not in sync" error message. I tested the suggested reset methods before upload - and then after some failures it worked!  :D
After this discovery I switched back to the mac, checked the running processes and found four avrdude zombie processes, which couldn't be terminated.
So I restarted, downloaded, compiled and tested various avrdude versions (the one included in Arduino010, 5.4 and 5.5; called from terminal), but I keep getting the same error messages "ser_open(): can't open device "/dev/tty.ARDUINOBT-BluetoothSerial": Resource busy".
In contrast, I'm now getting "Port in use" when I try to upload from Arduino010 (Mac)...
So, my conclusion for this evening:
- I really don't think it has anything to do with the RXTX library, because AFAICS there is no Java involved when I try to upload the hex file with avrdude via bash terminal.
- I don't think setting write permissions in "/var/" helps either, I rather guess the people who tried this had some luck, maybe it works on the mac as well from time to time?
- I guess the error is either avrdude or (somewhat more likely) there's something wrong with the timing of the authorisation process; sometimes there's an alert box saying (translated): "Couldn't open any RFCOMM channel. Please check if the identification of your device has to be activated".
In these cases, there's an established connection, but the "Serial port '/dev/tty.ARDUINOBT-BluetoothSerial' [is] already in use"
The next thing I'll try is to upload a program which sends some data, and see if I'm able to communicate with a phone app; I'll keep you updated on this...
Best,
Michael
auco
okay, the strange thing is:
I can connect to Arduino BT from my Mac running "Mobile Processing" with MPowerPlayer and AvetanaBluetooth. I have a nice serial connection and everything works wonderful! No errors so far!
So, the connection results on my system so far:
Arduino 010NO
AVRDude via TerminalNO
XtermNO
MPowerPlayer + AvetanaBluetoothYES
Just a guess: the most obvious difference in the list is that MPP/Avetana is incredibly slow (timing issue with pairing/authentification?)
Still having troubles to connect from my phone (SE k800i), but I don't know yet if it's just a bug in my software.
I'll keep you updated -
Best,
Michael
mrkbrz
I have the same problem. I really want to solve this, if it ends up that this iteration of ArduinoBT will never work on Leopard, that's £60 down the pan. They should really put a warning to leopard users up on tinker.it for now.
I compiled the latest Arduino source from svn. I noticed that the code has already been modified not to flush the serial buffer unless specifically stated in the preferences (which by default, it isn't). It locks up my computer. Can't quit arduino. I have to actually turn off my computer to stop it running. The process (when I open terminal and type ps aux) that can't be terminated is avrdude.
So, I tried to upload some code directly using avrdude. This is the command line options (note: you need to use -C to specify where your avrdude.conf is, and the -v -v -v for extra verbosity)
$ /Applications/arduino-0011/hardware/tools/avr/bin/avrdude -C/Applications/arduino-0011/hardware/tools/avr/etc/avrdude.conf -p m168 -b 115200 -c stk500v2 -P /dev/tty.ARDUINOBT-BluetoothSeri-1 -e -U flash:w:/Standard_Firmata.hex -v -v -v
When I run it, the little red light in the bluetooth system preferences goes green, indicating that it's connected.
Check the next post for the output!
Thanks,
Marek
mrkbrz
Code: [Select]
avrdude: Version 5.4-arduino, compiled on Oct  9 2007 at 11:20:31
        System wide configuration file is "/Applications/arduino-0011/hardware/tools/avr/etc/avrdude.conf"
        User configuration file is "/Users/marek/.avrduderc"
        User configuration file does not exist or is not a regular file, skipping
        Using Port            : /dev/tty.ARDUINOBT-BluetoothSeri-1
        Using Programmer      : stk500v2
        Overriding Baud Rate  : 115200
avrdude: ser_recv(): programmer is not responding
avrdude: stk500_2_ReceiveMessage(): timeout
... about 50 of these
avrdude: stk500v2_getsync(): timeout communicating with programmer
        AVR Part              : ATMEGA168
        Chip Erase delay      : 9000 us
        PAGEL                 : PD7
        BS2                   : PC2
        RESET disposition     : dedicated
        RETRY pulse           : SCK
        serial program mode   : yes
        parallel program mode : yes
        Timeout               : 200
        StabDelay             : 100
        CmdexeDelay           : 25
        SyncLoops             : 32
        ByteDelay             : 0
        PollIndex             : 3
        PollValue             : 0x53
        Memory Detail         :
                                 Block Poll               Page                       Polled
          Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
          eeprom        65     5     4    0 no        512    4      0  3600  3600 0xff 0xff
          flash         65     6   128    0 yes     16384  128    128  4500  4500 0xff 0xff
          lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
          signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
        Programmer Type : STK500V2
        Description     : Atmel STK500 Version 2.x firmware
        Programmer Model: Unknown
etc...
every once in a while I get
Code: [Select]
mrkbrz
#23
Mar 07, 2008, 02:34 pm Last Edit: Mar 07, 2008, 02:36 pm by mrkbrz Reason: 1
:DI can get a serial connection to the arduino by typing
screen /dev/tty.ARDUINOBT-BluetoothSeri-1
I can send it commands (it had SimpleMessagingSystem from before)
So, it's not that a serial connection can't be established, it's something up with what avrdude is doing. All the information about the arduino board is in avrdude.conf so it could be just not connecting at all. I'm trying to install the latest avrdude to see if that makes a difference. (There's one on darwinports that says it's for leopard)
auco
nice good to see so many people trying to find a solution :)
I agree about avrdude, seems suspicious indeed...
Quote
I already tried with avrdude 5.4 and 5.5. (see posting somewhere before). It had exactly the same results... And I haven't succeeded in connecting via screen cmd either (same error, "already in use" or "port busy"). Only thing working here besides the Win-PC is MPowerPlayer emulation with Avetana.
But I got one more theory:
I stumbled upon a problem when I tried to communicate with my phone (see this topic). The WT11 (BT chip on the Arduino BT) is configured to broadcast the SPP (Serial Connection Protocol) with the UUID 0x1101 ... Now this is a very common UUID and if there are probably other services on the phone (and on the computer!) broadcasting this UUID (eg DUN), which may cause interferences.
In other words: The Arduino BT can be detected, but not it's SPP, because the nearer SPPs have a stronger signal and are detected first.
Could it be (even if I can connect from the emulator), that maybe this UUID is the root of all problems? I mean uploading from the PC isn't very straightforward as well, it needed some trials before it actually worked...
I try to test this as soon as I got my ISP...
Best,
Michael
mrkbrz
avrdude 5.5 didn't make a difference. I also tried fiddling with the options of avrdude, changing the baud rate to 9600: nothing, changing the programmer from a stk500v2 to a stk500, this did something weird, but it didn't work.
mellis
mrkbrz: Does the same lock-up happen with Arduino 0010?  I've been testing Arduino 0011 (without the auto-flushing) on my Leopard (10.5.2) machine and it works fine.  What version of 10.5 do you have?
Also, with avrdude you should be using stk500v1 (which is the same as stk500) not stk500v2.  Try a baud rate of 19200.
mrkbrz
mellis! thanks for the suggestion, but alas, if only it were that easy. The Arduino IDE is set to upload using stk500v2 on the BT boards, and also I read somewhere that the BT only works at 115200 baud, but I tried it anyway.
This is what I typed into the console:
Code: [Select]
$ avrdude -C/Applications/arduino-0011/hardware/tools/avr/etc/avrdude.conf -p m168 -b 19200 -c stk500v1 -P /dev/tty.ARDUINOBT-BluetoothSeri-1 -e -U flash:w:/Standard_Firmata.hex -v -v
This is the output I got:
Code: [Select]
avrdude: Version 5.5, compiled on Mar  7 2008 at 14:35:13
        Using Programmer      : stk500v1
        Overriding Baud Rate  : 19200
        PAGEL                 : PD7
        BS2                   : PC2
        RETRY pulse           : SCK
        Timeout               : 200
        StabDelay             : 100
        CmdexeDelay           : 25
        SyncLoops             : 32
        ByteDelay             : 0
        PollIndex             : 3
        PollValue             : 0x53
        Memory Detail         :
        Description     : Atmel STK500 Version 1.x firmware
        Hardware Version: 2
        Firmware Version: 1.15
        Vtarget         : 0.0 V
        Varef           : 0.0 V
        Oscillator      : Off
        SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.11s
avrdude: Device signature = 0x000000
avrdude: Yikes!  Invalid device signature.
        Double check connections and try again, or use -F to override
        this check.
avrdude done.  Thank you.
Device signature null! I tried the -F option, and that locks up my computer. I wasn't getting any kind of lock. I can't remember exactly what I was doing but, yes, it locked up with Arduino 10 (I might have fiddled with some stuff first, but I don't think so)
mellis
The upload should be using stk500 (v1) - that's what it's set to in the boards.txt and that's what the bootloader expects.  (We don't use any stk500v2 bootloaders.)  The communication between the ATmega168 on the Arduino board and the BT module has to happen at 115200 baud.  The communication between the computer and the BT module can be at any baud rate (or at least you can specify any baud rate - I'm not sure if the value is actually used or not).
In any case, can you post the output you get if you use the command line you posted but add two more -v 's (so there are four total)?  (Without the -F).  It should show every byte that goes back and forth, which might help us figure out what the problem is.
Are you using the avrdude that comes with the Arduino?  It has a patch to allow to properly read the device signature from our bootloaders.
mrkbrz
#29
Mar 08, 2008, 10:13 pm Last Edit: Mar 08, 2008, 10:14 pm by mrkbrz Reason: 1
I don't know what happened, but it's mysteriously working now (in Arduino 11) actually in the IDE itself... I can't think of what might have caused it to suddenly start working?! It works every time, and serial comms work fine with the board with processing and pd. I found the reference to stk500v2 in avrdude.conf, so that's why I was using it. Like I said though, it finally worked through the IDE. Magic.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
