Topic: PWM dimming problem (Read 2399 times) previous topic - next topic
Mr_Stian
Hello everyone. I am working on my own LED light for nye aquarium, and are now finished with the hardware and are working on the code. I have a arduino Leonardo controlling 6 LED channels with PMW signal via 6 LED LDD drivers from Meanwell.
I have checked that all the channels work using analogWrite commands so they all work.
I found a sketch somwhere online (can not find were at the moment) and adapted this to have 6 channels. The original one only had 2. That is the only modifications i have done. I have the DS1307 RTC and a I2C controlled LCD panel (connected, but not in use yet)
The problems i am having is that it always seems to be night mode. That there are some problems with getting the time from the RTC. I used this code to set the time on the RTC:
Code: [Select]
#include <WProgram.h>
#include <Wire.h>
#include <DS1307.h>
int rtc[7];
  RTC.stop();
  RTC.set(DS1307_SEC,1);
  RTC.set(DS1307_MIN,57);
  RTC.set(DS1307_HR,17);
  RTC.set(DS1307_DOW,4);
  RTC.set(DS1307_DATE,18);
  RTC.set(DS1307_MTH,2);
  RTC.set(DS1307_YR,9);
  RTC.start();
  RTC.get(rtc,true);
  for(int i=0; i<7; i++)
    Serial.print(rtc[i]);
    Serial.print(" ");
When i adapted the serial monitor code to the light script the RTC showed the correct time.
Can anyone see if there is a problem with my light controller script? Here is the code:
Code: [Select]
Arduino LED controller for reef aquariums
// paramterized LED lighting control for reef aquariums
// use a DS1307 RTC to kick off lighting schedules
//   fade up on a given slope
//         delay a set amount
//         fade back down
//   such that the photoperiod lasts the correct amount of time
//  Circuit
// PWM pins described below connected to dimming circuits on drivers
// ledMaster pin below connected to a 120V AC relay to turn the LED drivers on and off (optional)
// grounds from drivers connected to arduino ground
// DS1307 RTC connected via I2C
// Pins to control LEDs. Change these if you're using different pins.
int actinic1Led = 5;    // LED PMW channel for actinic. Channel 1 Lumina 5.2 LED
int blueLed = 6;        // LED PWM channel for blues. Channel 2 Lumina 5.2 LED
int whiteLed = 9;      // LED PWM channel for whites. Channel 3 Lumina 5.2 LED
int colorLed = 10;      // LED PMW channel for enhanced color spectrum. Channel 4 Lumina 5.2 LED
int actinic2Led = 11;   // LED PMW channel for actinic. Channel 5 Lumina 5.2 LED
int moonlightLed = 13;  // LED PMW channel for moonlight.
// Set up RTC
#include "Wire.h"
#define DS1307_I2C_ADDRESS 0x68
// RTC variables
byte second, rtcMins, oldMins, rtcHrs, oldHrs, dayOfWeek, dayOfMonth, month, year;
// Other variables. These control the behavior of lighting. Change these to customize behavoir
int minCounter = 0;            // counter that resets at midnight. Don't change this.
int blueStartMins = 480;       // minute to start blues. Change this to the number of minutes past
                               //    midnight you want the blues to start.
int whiteStartMins = 480;      // minute to start whites. Same as above.
int actinicStartMins = 480;    // minute to start actinic. Same as above.
int colorStartMins = 480;       // minute to start color channel. Same as above.
int moonlightStartMins = 0;    // minute to start moonlight. Same as above.
int bluePhotoPeriod = 510;     // photoperiod in minutes, blues. Change this to alter the total
                               //    photoperiod for blues.
int whitePhotoPeriod = 510;    // photoperiod in minutes, whites. Same as above.
int actinicPhotoPeriod = 510;  // photoperiod in minutes, actinic. Same as above.
int colorPhotoPeriod = 510;    // photoperiod in minutes, color. Same as above.
int moonlightPhotoPeriod = 510;     // photoperiod in minutes, monlight. Same as above.
int fadeDuration = 60;      // duration of the fade on and off for sunrise and sunset. Change
                            //    this to alter how long the fade lasts.
int blueMax = 255;          // max intensity for blues. Change if you want to limit max intensity. channel 2
int whiteMax = 255;         // max intensity for whites. Same as above. Channel 3
int actinicMax = 255;       // maxintensety for actinic channel 1 and 5
int moonlightMax = 255;     // max intensety for moonlight
int colorMax = 255;         // max intensety for color channel 4
/****** LED Functions ******/
//function to set LED brightness according to time of day
//function has three equal phases - ramp up, hold, and ramp down
void setLed(int mins,    // current time in minutes
            int ledPin,  // pin for this channel of LEDs
            int start,   // start time for this channel of LEDs
            int period,  // photoperiod for this channel of LEDs
            int fade,    // fade duration for this channel of LEDs
            int ledMax   // max value for this channel
  if (mins > start && mins <= start + fade)  {
    analogWrite(ledPin, map(mins - start, 0, fade, 0, ledMax));
    if (mins > start + period && mins <= start + period - fade)  {
    analogWrite(ledPin, ledMax);
    if (mins > start + period - fade && mins <= start + period)  {
    analogWrite(ledPin, map(mins - start + period - fade, 0, fade, ledMax, 0));
/***** RTC Functions *******/
// Convert normal decimal numbers to binary coded decimal
byte decToBcd(byte val)
  return ( (val/10*16) + (val%10) );
// Convert binary coded decimal to normal decimal numbers
byte bcdToDec(byte val)
  return ( (val/16*10) + (val%16) );
// 1) Sets the date and time on the ds1307
// 2) Starts the clock
// 3) Sets hour mode to 24 hour clock
// Assumes you're passing in valid numbers.
void setDateDs1307(byte second,        // 0-59
                   byte minute,        // 0-59
                   byte hour,          // 1-23
                   byte dayOfWeek,     // 1-7
                   byte dayOfMonth,    // 1-28/29/30/31
                   byte month,         // 1-12
                   byte year)          // 0-99
   Wire.beginTransmission(DS1307_I2C_ADDRESS);
   Wire.write(0);
   Wire.write(decToBcd(second));
   Wire.write(decToBcd(minute));
   Wire.write(decToBcd(hour));
   Wire.write(decToBcd(dayOfWeek));
   Wire.write(decToBcd(dayOfMonth));
   Wire.write(decToBcd(month));
   Wire.write(decToBcd(year));
   Wire.endTransmission();
// Gets the date and time from the ds1307
void getDateDs1307(byte *second,
          byte *minute,
          byte *hour,
          byte *dayOfWeek,
          byte *dayOfMonth,
          byte *month,
          byte *year)
  Wire.write(0);
  Wire.requestFrom(DS1307_I2C_ADDRESS, 7);
  *second     = bcdToDec(Wire.read() & 0x7f);
  *minute     = bcdToDec(Wire.read());
  *hour       = bcdToDec(Wire.read() & 0x3f);
  *dayOfWeek  = bcdToDec(Wire.read());
  *dayOfMonth = bcdToDec(Wire.read());
  *month      = bcdToDec(Wire.read());
  *year       = bcdToDec(Wire.read());
void setup()  {
// init I2C
  Wire.begin();
/***** Main Loop ***********/
void loop()  {
  // get time from RTC and put in hrs and mins variables
  getDateDs1307(&second, &rtcMins, &rtcHrs, &dayOfWeek, &dayOfMonth, &month, &year);
  minCounter = rtcHrs * 60 + rtcMins;
  // determine if it is day or night, and act accordingly
  if ((minCounter > blueStartMins || minCounter > whiteStartMins || minCounter > actinicStartMins || minCounter > colorStartMins)
           && (minCounter < blueStartMins + bluePhotoPeriod || minCounter < whiteStartMins + whitePhotoPeriod
           || minCounter < actinicStartMins + actinicPhotoPeriod || minCounter < colorStartMins + colorPhotoPeriod))  {   //day
    // set LED states
    setLed(minCounter, blueLed, blueStartMins, bluePhotoPeriod, fadeDuration, blueMax);
    setLed(minCounter, whiteLed, whiteStartMins, whitePhotoPeriod, fadeDuration, whiteMax);
    setLed(minCounter, colorLed, colorStartMins, colorPhotoPeriod, fadeDuration, colorMax);
    setLed(minCounter, actinic1Led, actinicStartMins, actinicPhotoPeriod, fadeDuration, actinicMax);
    setLed(minCounter, actinic2Led, actinicStartMins, actinicPhotoPeriod, fadeDuration, actinicMax);
    analogWrite(moonlightLed, 50);
  else  {   //night
    analogWrite(blueLed, 0);
    analogWrite(whiteLed, 0);
    analogWrite(actinic1Led, 0);
    analogWrite(actinic2Led, 0);
    analogWrite(colorLed, 0);
    analogWrite(moonlightLed, 100);
  // Get ready for next iteration of loop
I see from the basic sketch that i used to set the RTC do not use the address of the RTC. Can this cause this? Do i have to set the time with another sketch, or is it possible from the main sketch?
Thank you for taking the time to help me! :)
luisilva
My first advice is that you may use the library at your main code. If yo don't do that how you want to find the error?
megaBlocks
#2
Aug 04, 2014, 10:32 pm Last Edit: Aug 04, 2014, 10:37 pm by megaBlocks Reason: 1
Do you ever set pinMode(pin, OUTPUT)?? I didnt see that being called in your setup() function.
Mr_Stian
Could you elaborate? I do not understand your reply. Which library?
I am very new to programming Arduino so sorry if this is a stupid question.
megaBlocks
try replacing you setup function with this:
Code: [Select]
void setup()  {
  pinMode(actinic1Led,OUTPUT);
  pinMode(blueLed,OUTPUT);
  pinMode(whiteLed,OUTPUT);
  pinMode(colorLed,OUTPUT);
  pinMode(actinic2Led,OUTPUT);
  pinMode(moonlightLed,OUTPUT);
// init I2C
  Wire.begin();
Also to save on variable space try replacing your "int" decorations with "const int" instead, like this:
Code: [Select]
const int actinic1Led = 5;    // LED PMW channel for actinic. Channel 1 Lumina 5.2 LED
const int blueLed = 6;        // LED PWM channel for blues. Channel 2 Lumina 5.2 LED
const int whiteLed = 9;      // LED PWM channel for whites. Channel 3 Lumina 5.2 LED
const int colorLed = 10;      // LED PMW channel for enhanced color spectrum. Channel 4 Lumina 5.2 LED
const int actinic2Led = 11;   // LED PMW channel for actinic. Channel 5 Lumina 5.2 LED
const int moonlightLed = 13;  // LED PMW channel for moonlight.
luisilva
If this reply is for me, I referring to the library DS1307.h. In the sketch of the serial line you have it:
Code: [Select]
#include <Wire.h>
#include <DS1307.h>   // <--- This is the library that I referring
int rtc[7];
  RTC.stop();
  RTC.start();
  RTC.get(rtc,true);
    Serial.print(" ");
I don't know that library and I don't here you get it. My advice is, try to download this other library:
https://github.com/adafruit/RTClib
I use it and I like it. Install it and try to use the examples, and to adapt it for what you are trying to do.
Mr_Stian
I found the page that had the source code, and no one of the guys using it use the library DS1307.h
I can also add the OUTPUT to the sketch, but not sure if this helps as the moonlights are on, as if the time is in the middle of the night.
I have some questions about this part of the code:
Code: [Select]
                   byte hour,          // 1-23
                   byte month,         // 1-12
                   byte year)          // 0-99
Is this to set the time on the RTC? Can i just add the time and date behind each byte, uploade and then remove the time and date and upload again?
Mr_Stian
I managed to figure out why it did not work. There were an error in the if statement when the LED´s were supposed to be at max.
This is the fixed state:
Code: [Select]
    if (mins > start + fade && mins <= start + period - fade)  {
The second if statement originally said if mins > start + photoperiod. This is wrong. This phase starts after mins > start + fade
So now it works as it is supposed to work....
TomGeorge
Quote
Can you tell us the specifications or part number of the driver please.
Tom..... :)
Everything runs on smoke, let the smoke out, it stops running....
MarkT
You have a function that's a great candidate for using references rather than pointers:
Code: [Select]
void getDateDs1307(byte & second,
          byte & minute,
          byte & hour,
          byte & dayOfWeek,
          byte & dayOfMonth,
          byte & month,
          byte & year)
  Wire.write(0);
And then the call would be:
Code: [Select]
  getDateDs1307(second, rtcMins, rtcHrs, dayOfWeek, dayOfMonth, month, year);
instead of
Code: [Select]
