Topic: Re-purposing the code for a digital potentiometer? (Read 545 times) previous topic - next topic
electricviolin
I took a look at the code here: http://arduino.cc/en/Tutorial/SPIDigitalPot
I notice that they use an arduino uno and they said
" * CS - to digital pin 10  (SS pin)
  * SDI - to digital pin 11 (MOSI pin)
  * CLK - to digital pin 13 (SCK pin)"
I need to use this with an arduino mega, so how would I wire it differently and how would I code it differently? Do I just use the same digital pins at described, or are the SS, MOSI, and SCK pins different on the arduino Mega? Thanks!
"To invent, you need a good imagination and a pile of junk" -Thomas Edison
Docedison
--> WA7EMS <--
"The solution of every problem is another problem." -Johann Wolfgang von Goethe
I do answer technical questions PM'd to me with whatever is in my clipboard
UKHeliBob
The equivalent pins on the Mega are
51 (MOSI)
52 (SCK)
53 (SS)
See http://arduino.cc/en/Main/ArduinoBoardMega2560
I have not looked at the link to the code for the Uno but it should just be a matter of substituting the Mega pin numbers for the equivalent Uno ones in the code.
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
electricviolin
Okay, Thanks! I just want to check though, I do not have to change anything else in the code, do I?
UKHeliBob
You should only need to change the pin numbers to match the Mega, not the code.
