Topic: print only new sensor data (Read 620 times) previous topic - next topic
Backy
Aug 05, 2014, 08:36 am Last Edit: Aug 05, 2014, 09:15 am by Backy Reason: 1
Hello everyone! Sorry for bothering, I need help: I have GPS  and code http://learn.parallax.com/KickStart/28500
But in loop every 5 second  same data  sent, its little bit messy ,I wanna print only new sensors data not the same with previous . If you have advice or some examples pls share with me
For example result is :
Reading GPS
35.3608, 139.2746
35.3611, 139.2745
35.3610, 139.2745
35.3610, 139.2745
35.3610, 139.2745
35.3610, 139.2745
35.3610, 139.2745
35.3610, 139.2745
35.3610, 139.2745
It will be better if it will be printed like this :
35.3608, 139.2746
35.3611, 139.2745
35.3610, 139.2745
here code:
Code: [Select]
#include <SoftwareSerial.h>
#include "./TinyGPS.h"                 // Special version for 1.0
TinyGPS gps;
SoftwareSerial nss(6, 255);            // Yellow wire to pin 6
 nss.begin(4800);
 Serial.println("Reading GPS");
 bool newdata = false;
 unsigned long start = millis();
 while (millis() - start < 5000) {  // Update every 5 seconds
   if (feedgps())
     newdata = true;
 if (newdata) {
   gpsdump(gps);
// Get and process GPS data
void gpsdump(TinyGPS &gps) {
 float flat, flon;
 unsigned long age;
 gps.f_get_position(&flat, &flon, &age);
 Serial.print(flat, 4); Serial.print(", ");
 Serial.println(flon, 4);
// Feed data as it becomes available
bool feedgps() {
 while (nss.available()) {
   if (gps.encode(nss.read()))
     return true;
 return false;
UKHeliBob
If you only want to put the data in the database when it has changed, then each time you read it save it in a variable.  Next time you read the data compare it with the previous saved data and only put it in your database if it has changed.
Note, however, that the data from the GPS may fluctuate slightly on each read even if the unit has not moved.  You might like to consider only putting it in the database if it has changed by a significant amount.  Something like this
Code: [Select]
if abs( (newData - prevData) ) > 10)
    //code to put the data in the database
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
Robin2
There is already a newdata variable in your code. What is that doing?
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
Backy
thank you for reply
yes I also think that way...but the problem is I am not a good in C programming  :smiley-roll:
How can I save previous data?
Backy
...R
I think its just new sensor data , it will be the same with previous , only sending time is different
35.3610, 139.2745
35.3610, 139.2745
UKHeliBob
Code: [Select]
float prevFlat = flat;
float prevFlon =  flon;
unsigned long prevAge = age;
float flat, flon;
unsigned long age;
