Topic: Blinking in different configurations (Read 3183 times) previous topic - next topic
nexusprime
Helo
I am just starting with the Arduino Leonardo.
I used found here code
Code: [Select]
/* Blink Multiple LEDs without Delay
* Turns on and off several light emitting diode(LED) connected to a digital
* pin, without using the delay() function.  This means that other code
* can run at the same time without being interrupted by the LED code.
int POST = 13;                // LED connected to digital pin 13
int KIER = 12;
int STOP = 11;
int value1 = LOW;                // previous value of the LED
int value2 = LOW;
int value3 = LOW;// previous value of the LED
long time1  = millis();
long time2 = millis();
long time3 = millis();
long czasPOST = 1000;           // interval at which to blink (milliseconds)
long czasKIER = 500;
long czasSTOP = 300;
  pinMode(POST, OUTPUT);      // sets the digital pin as output
  pinMode(KIER, OUTPUT);
  pinMode(STOP, OUTPUT);
  unsigned long m = millis();
  if (m - time1 > czasPOST){
    time1 = m;
    if (value1 == LOW)
      value1 = HIGH;
      value1 = LOW;
    digitalWrite(POST, value1);
  if (m - time2 > czasKIER){
    time2 = m;
    if (value2 == LOW)
      value2 = HIGH;
      value2 = LOW;
    digitalWrite(KIER, value2);
  if (m - time3 > czasSTOP){
    time3 = m;
    if (value3 ==LOW)
      value3 = HIGH;
      value3 = LOW;
      digitalWrite(STOP, value3);
and this is going very well, but what to do to...
make for example the POST after 20 repeats  light on with no blinking for 1 minute and then again make it blinking for some time or cycle ?
How to make such command? I want to make a testing program for my device and put it on the Attiny85. I saw here that it support 3 outputs.
and another thing...How to make the led more time HIGH than LOW in the blinking script ?
Grumpy_Mike
BulldogLowell
think about creating a function for each led.  You can call the function as many times as you want
Quote
I included an example below:
Code: [Select]
int KIER = 12;
int STOP = 11;
int value2 = LOW;
unsigned long startTime3;
unsigned long onTime = 1900UL;
unsigned long interval = 2000UL;// this combination turns led off for 100ms of a 2 sec total time
    time1 = m;
    if (value1 == LOW)
      value1 = HIGH;
      value1 = LOW;
    time2 = m;
    if (value2 == LOW)
      value2 = HIGH;
      value2 = LOW;
  blink3(); //your new function
void blink3()
  unsigned long elapsedTime = millis() - startTime3;
  if (elapsedTime < onTime) //on time
    digitalWrite(STOP,HIGH);
  else if (elapsedTime < interval) //total time
    digitalWrite(STOP,LOW);
    startTime3 += interval;
Robin2
Two or three hours spent thinking and reading documentation solves most programming problems.
nexusprime
#4
Aug 06, 2014, 10:56 am Last Edit: Aug 06, 2014, 11:03 am by nexusprime Reason: 1
ok, i will try to deal with it. Maybe i will put it on 3 chips than on 1.
nexusprime
#5
Aug 06, 2014, 05:07 pm Last Edit: Aug 06, 2014, 05:30 pm by nexusprime Reason: 1
another question...
I want to make a fade on 3 Attiny pins. The pin 4 is OK but the 0 and 1 is little jerky, it is not a soft fading. How to deal with this and make it soft? i used standard fading code. i know this is all about the PWM
Code: [Select]
Fade
This example shows how to fade an LED on pin 9
using the analogWrite() function.
This example code is in the public domain.
int led = 0;
int led2 = 1;
int led3 = 4;
int brightness = 0;    // how bright the LED is
int fadeAmount = 5;    // how many points to fade the LED by
// the setup routine runs once when you press reset:
void setup()  {
 // declare pin 9 to be an output:
 pinMode(led, OUTPUT);
 pinMode(led2, OUTPUT);
 pinMode(led3, OUTPUT);
// the loop routine runs over and over again forever:
void loop()  {
 // set the brightness of pin 9:
 analogWrite(led, brightness);
 // change the brightness for next time through the loop:
 brightness = brightness + fadeAmount;
 // reverse the direction of the fading at the ends of the fade:
 if (brightness == 0 || brightness == 255) {
   fadeAmount = -fadeAmount ;
 // wait for 30 milliseconds to see the dimming effect
 delay(5);
 analogWrite(led2, brightness);
 delay(5);
 analogWrite(led3, brightness);
 delay(5);
Robin2
I hope you are not thinking of 3 separate Arduinos to do something that is more easily done with one.
...R
nexusprime
#7
Aug 06, 2014, 05:28 pm Last Edit: Aug 06, 2014, 05:32 pm by nexusprime Reason: 1
I mine use one attina to control HIGH LOW on pins which will be connected to the VCC of 3 Attinas with different program each.  I can use blinking program to turn on and off VCC. I think this is the easiest way.
Robin2
How many LEDs do you want to blink? The code in several things at a time could be easily extended to do several.
...R
nexusprime
#9
Aug 06, 2014, 09:35 pm Last Edit: Aug 06, 2014, 09:36 pm by nexusprime Reason: 1
a lot of leds. 3 line about 12V/350mA each.
Here is schematic for Attiny.
Left side of schematic represent the Attiny because i dont have the chips in iCircuit app
Robin2
a lot of leds.
Does that mean 10, 100 or 1000?
Does every one of them need a separate blinking pattern?
...R
BulldogLowell
attach a shift register and go nuts
nexusprime
#12
Aug 07, 2014, 06:24 am Last Edit: Aug 07, 2014, 06:40 am by nexusprime Reason: 1
I will be more specific.
I have 3 lines of leds. Each have about 11 leds. Each line require about 350mA and 12v.
Now...
I need 3 different programs for drive all leds in the same time.
First is slow blinking
Seccond is fast blinking
Third is soft fading
I am planing to put 3 programs on 3 chips which will be connected to the resistors and first transistors the pnp transistors in the schematic.
More specific...
I will use 3 attiny pins which will be connected to the transistors, each pin each transistor.
So in ready to go device 9 pin of 3 attines will be connected to the 3 transistors.
This 3 chips will be drived by another 4 chip which will be give them command to start doing thing.
the 4 chip will be connected to the voltage devider.
Yes, i could put the shift register, but using the arduino i can make different times of doing things for each of 3 chips.
This is the whole idea.
UKHeliBob
Quote
As has been pointed out, you can turn 3 sets of LEDs on and off at different rates, including a slow fade,  using just one Arduino, so why use 4 of them ?
Please do not send me PMs asking for help.  Post in the forum then everyone will benefit from seeing the questions and answers.
Robin2
That's more or less what I thought. The several things at a time demo pretty much does that out of the box.
...R
