Topic: drum kit arduino mega 2560 (Read 1 time) previous topic - next topic
sylveur
Hello, my name is Sylvain, I am in the objective to create an drum kit midi wicht arduino mega 2560.
I need you, because I try to use my pedal of sustain, to close my hi-hat. I have to find on your forum a code, but I try to add it the swicht.
Could you help me?
Exemple: (A0, is my hi-hat...)
Thank you!
Quote
#define  MAX_PIEZO  9
uint8_t piezo[MAX_PIEZO] = { A0, A1, A2, A3, A4, A5, A6, A7, A8 };
uint8_t drumType[MAX_PIEZO] = { 9, 8, 7, 6, 5, 4, 3, 2, 1 };
const int threshold = 500;
  for (uint8_t i=0; i<MAX_PIEZO; i++)
    pinMode(piezo, INPUT);
  Serial.begin(57600);
void MidiTX(unsigned char StatusByte, unsigned char Note, unsigned char Val)
  Serial.write(StatusByte);
  Serial.write(Note);
  Serial.write(Val);
void ProcessPiezo(uint8_t p)
  uint16_t sensorReading = analogRead(piezo[p]);
  uint16_t  val;
  if (sensorReading > threshold)
    uint32_t oldcas = millis() + 5;
    // this part of the code looks complex
    // explain what you are trying to do?
    while (analogRead(piezo[p]) > threshold)
      if (millis() >= oldcas)
        val = analogRead(piezo[p]) / 9;
    MidiTX(144, drumType[p], val);
    MidiTX(128, drumType[p], val);
    ProcessPiezo(i);
