Topic: Line following robot attempt!! (Read 1 time) previous topic - next topic
Marshiewoo
hi all!!
After many many many many hours of attempting to automate my RC car with Arduino, I finally have a slight breakthrough.
I do have a problem, which is apparent from the video... (apologies for the typical phone resolution)
https://www.youtube.com/watch?v=HP-_UZhYJQ0&list=UUwufizM79rJxHxXAgDab0WQ
As you can see, the robot is obviously doing it's job but when it comes to following the lines it is making rather big turns and eventually goes totally off track because of these turns.
For this reason I cannot speed it up, and I am just not happy with the large turns and overall tackyness. Any suggestions???
Here is my code.
const int lightSensor1 = A0;
const int lightSensor2 = A1;
const int forward = 5;
const int backward = 3;
const int left = 10;
const int right = 11;
const int topFlasher = 13;
int currentLight1;
int currentLight2;
void setup(){
   pinMode(forward, OUTPUT);
   pinMode(backward, OUTPUT);
   pinMode(left, OUTPUT);
   pinMode(right, OUTPUT);
   pinMode(topFlasher, OUTPUT);
   pinMode(lightSensor1, INPUT);
   pinMode(lightSensor2, INPUT);
   digitalWrite(forward, LOW);
   digitalWrite(backward, LOW);
   digitalWrite(left, LOW);
   digitalWrite(right, LOW);
   digitalWrite(topFlasher, LOW);
void loop(){
  currentLight1 = analogRead(lightSensor1);
  currentLight2 = analogRead(lightSensor2);
  Serial.print(currentLight1);
  Serial.print(" - ");
  Serial.print(currentLight2);
  Serial.println(" ");
  analogWrite(forward, 140);
  if(currentLight2 > currentLight1){
    digitalWrite(left, HIGH);
    topBeacon();
    digitalWrite(right, HIGH);
    topBeacon();
  /*if(millis() == 2000){
    digitalWrite(forward, HIGH);
  if(millis() == 2100){
  if(millis() == 2500){
  if(millis() == 2600){
  if(millis() == 3000){
  if(millis() == 3100){
   if(millis() == 2750){
   if(millis() == 3400){
     digitalWrite(backward, HIGH);
   if(millis() == 3900){
void topBeacon(){
     if( (millis() / 1000 % 2) == 0){
       digitalWrite(topFlasher, HIGH);
Thanks!!
GunnerCAF
It looks like the only corrections the car can make are full right turn or full left turn.  The car only detects two conditions, the white line is under the sensor and it turns away from the line.  You can try a little wider line of consistent width.
If the car can go straight, you can add another condition, and maybe follow the line closer.  How about making your line wider.  If both sensors detect the line, it goes straight.  When one sensor looses the line, it turns back to the line?
Dave
Marshiewoo
Fantastic idea, I just don't know how to put that into code.
As you can see in my code, the side with the lowest light will turn toward the line, I've no idea how I can add a way to let it know when both see the line.
The photo resistors I am using give me slightly different values even in the same conditions, so I think it would be hard.
Marshiewoo
Done, working much better now thanks, just need to get an IR LED and IR phototransistors.
const int trigPin = 12;
const int echoPin = 4;
int forwardAnalog = 0;
int targetSpeed = 6;
int CMPSSelector = 0;
int CMPSDistanceAverage = 0;
int CMPSStorage1;
int CMPSStorage2;
int CMPSStorage3;
int CMPSStorage4;
int currentLight1;
int currentLight2;
int gapValue;
int highest;
int lowest;
int CMPSStorageSelector = 1;
long duration, distance;
void setup(){
   Serial.begin(9600); // Start printing to Serial.
   // Set all pinModes.
   pinMode(trigPin, OUTPUT);
   pinMode(echoPin, INPUT);
   // Set default position of outputs.
   // Determine the gap between both light sensors.
   if(lightSensor1 > lightSensor2){
     highest = lightSensor1;
     lowest = lightSensor2;
     highest = lightSensor2;
     lowest = lightSensor1;
   gapValue = (highest - lowest) + 20;
void loop(){
  ultraSonic();
  CMPS();
  // Set variable to read light sensors, and print to Serial.
  /* Serial.print(currentLight1);
  Serial.print(gapValue);
  Serial.println(" "); */
  // Drive.
  forwardAction();
  // Line following code.
  /*if(currentLight2 > currentLight1 + gapValue){
    topBeacon();
  } else if (currentLight1 > currentLight2 + gapValue) {
    topBeacon();
// Flashing light on roof, and pin 13.
void topBeacon(){
void ultraSonic(){
    digitalWrite(trigPin, LOW);  // Added this line
    delayMicroseconds(2); // Added this line
    digitalWrite(trigPin, HIGH);
  //  delayMicroseconds(1000); - Removed this line
    delayMicroseconds(10); // Added this line
    duration = pulseIn(echoPin, HIGH);
    distance = (duration/2) / 29.1;
    if(distance >= 400){
      distance = 0;
    if(distance <= 4){
      distance = 0;
void CMPS(){
   if(CMPSStorageSelector == 1 && (millis() / 100 % 2) == 0){
     CMPSStorage1 = distance;
     Serial.print("Storage #1 : ");
     Serial.print(CMPSStorage1);
     CMPSStorageSelector = 2;
   if(CMPSStorageSelector == 2 && (millis() / 100 % 2) != 0){
     CMPSStorage2 = distance;
     Serial.print("Storage #2 : ");
     Serial.print(CMPSStorage2);
     CMPSStorageSelector = 3;
   if(CMPSStorageSelector == 3 && (millis() / 100 % 2) == 0){
     CMPSStorage3 = distance;
     Serial.print("Storage #3 : ");
     Serial.print(CMPSStorage3);
     CMPSStorageSelector = 4;
   if(CMPSStorageSelector == 4 && (millis() / 100 % 2) != 0){
     CMPSStorage4 = distance;
     Serial.print("Storage #4 : ");
     Serial.print(CMPSStorage4);
   if((millis() / 200 % 2) == 0 && CMPSSelector == 0){
     CMPSDistanceAverage = (CMPSStorage1 - CMPSStorage2) + (CMPSStorage3 - CMPSStorage4);
     CMPSDistanceAverage = CMPSDistanceAverage * -1;
     Serial.println(CMPSDistanceAverage);
     CMPSSelector = 1;
   if((millis() / 200 % 2) != 0 && CMPSSelector == 1){
     CMPSSelector = 0;
void forwardAction(){
  if(distance < 40){
  } else if(CMPSDistanceAverage < targetSpeed){
    forwardAnalog++;
    analogWrite(forward, forwardAnalog);
    delayMicroseconds(15000);
  } else if(CMPSDistanceAverage > targetSpeed){
    forwardAnalog = forwardAnalog - 1;
    delayMicroseconds(100000);
GunnerCAF
You have a fairly light colored floor.  You could also try a black line to get more contrast.
Nice work!
Dave
