Topic: Piezo is making a soft sound after having played a tone() - how can I stop it? (Read 3121 times) previous topic - next topic
local_dani_21
Hi
I connected a piezo speaker to a ATMEGA32U4 (pin 9). The other piezo-pin goes to ground
When I power up the board, the piezo is completely quiet. I then play a tone using tone(9,500,1000);. After having played the tone (and also after having executed noTone(9)), there is a soft hissing noise coming from the speaker.
Does anyone have any idea how to stop the noise?
Thank you,
Dani
robtillaart
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Jiggy-Ninja
Post your sketch.
I suspect this. When the sketch first powers up, all pins are in INPUT mode. This high Z input impedance causes there to be no current flow through the speaker, causing absolutely no noise.
When tone() is run, the pin is forced to OUTPUT. After noTone(), the pin is still OUTPUT, but written LOW. This is a low impedance output that can cause some currents and noise to flow.
After noTone(), try setting the pin to INPUT and see what happens.
Hackaday: https://hackaday.io/MarkRD
Advanced C++ Techniques: https://forum.arduino.cc/index.php?topic=493075.0
Grumpy_Mike
Quote
Yes, or write a logic LOW to the pin after the noTone.
Jiggy-Ninja
Quote
noTone() already does that.
Code: [Select]
void noTone(uint8_t _pin)
  int8_t _timer = -1;
  for (int i = 0; i < AVAILABLE_TONE_PINS; i++) {
    if (tone_pins[i] == _pin) {
      _timer = pgm_read_byte(tone_pin_to_timer_PGM + i);
      tone_pins[i] = 255;
  disableTimer(_timer);
  digitalWrite(_pin, 0);
