Topic: Turning a Piezo buzzer off (Read 4976 times) previous topic - next topic
abasel
Why does
Code: [Select]
analogWrite(buzzer,255);
turn it off and
Code: [Select]
analogWrite(buzzer,0);
turn it on.
I thought that it would be the other way around.
JimboZA
Post the circuit.... if you have the buzzer +ve to 5V, and the -ve in an i/o pin, then you need the i/o pin to be at 0V for there to be a PD across the buzzer, so off is on.
Johannesburg hams call me: ZS6JMB on Highveld rep 145.7875 (-600 & 88.5 tone)
Dr Perry Cox: "Help me to help you, help me to help you...."
Your answer may already be here: https://forum.arduino.cc/index.php?topic=384198.0
abasel
Hi, it's an active buzzer http://www.aliexpress.com/snapshot/6164212500.html with I/O pin connected to A3. The VCC & GND are connected to 3.5V and GND respectively
Jiggy-Ninja
Look at the circuit diagram posted on that page. It uses a PNP transistor as a high-side switch. 5V will turn it off, 0V will turn it on. That's normal behavior for a high-side PNP.
Hackaday: https://hackaday.io/MarkRD
Advanced C++ Techniques: https://forum.arduino.cc/index.php?topic=493075.0
JimboZA
Damn- you beat me to it....
abasel
Thanks, I am learning slowly :-)
