Topic: Two NRF24L01 Transmitters sending temperatures to one Receiver (Read 366 times) previous topic - next topic
0miker0
I have two devices transmitting temperature to one receiver. Right now only one at a time will work displaying the proper temperature. This verifies that the hardware on each transmitter is working and Serv1 & Serv2 are properly set up.
  Mirf.getData((byte *) &temp1);  //small board
  //Mirf.getData((byte *) &temp2);  //large board
when both lines are uncommented out I can see that one temperature is correct but the other reads a constant wrong temperature.
I'm no good at code as you can tell so any help would be great.
Code: [Select]
#include <MirfHardwareSpiDriver.h>
int16_t h = 64;
int16_t w = 128;
// OLED I2C bus address
#define OLED_address  0x3c
Adafruit_SSD1306 display(OLED_RESET);
float temp1;  //int
float temp2;
  Wire.begin();
  Mirf.cePin = 8;
  Mirf.csnPin = 9;
  display.begin(SSD1306_SWITCHCAPVCC, 0x3c);  // initialize with the I2C addr 0x3D (for the 128x64)
  display.clearDisplay();   // clears the screen and buffer
  Wire.begin();
  init_OLED();
  reset_display();
  Mirf.spi = &MirfHardwareSpi;
  Mirf.init();
  Mirf.setRADDR((byte *)"serv1");   //has to be serv1 !
  Mirf.setRADDR((byte *)"serv2"); //has to be serv2 !
  Mirf.payload = sizeof(temp1);
  Mirf.payload = sizeof(temp2);
  Mirf.config();
  while(!Mirf.dataReady())
  //Can only use one at a time or gives an error one on Serv2
  Serial.println(temp1);
  Serial.println(temp2);
  display.setTextSize(1);
  display.setTextColor(WHITE);
  display.setCursor(0,10);
  display.print("Small Brd:");
  display.setCursor(70,10);  //over,up
  display.print(temp1);
  display.setCursor(0,40);
  display.print("Large Brd:");
  display.setCursor(70,40);  //over,up
  display.print(temp2);
