Author Topic: NOISE  (Read 379 times)
Hi there,
I am new to arduino. Recently I tried the Arduino Duemilanove, which was the basic board. I connected a accelerometer to the analog input and PWM was successfully generated. The servo did move accordingly, however I realise that [glow]there's some noise either internal or external, that makes the servo jerk[/glow] when the accelerometer is in rest, any good way to recommend me in [glow]removing/filtering the noise[/glow]?
Can show a diagram if possible?
Thanks in advance!
UK
Online Online
You fed a servo PWM?
Sorry, that is not the right way to drive a servo - have a look at the Servo libraries.
A very simple filter:
int filtered = 0;
const int FILTER_CONST = 4;
int newVal = analogRead (potPin);
filtered = (filtered - (filtered / FILTER_CONST)) + (newVal / FILTER_CONST);
« Last Edit: October 29, 2009, 06:20:37 am by AWOL » Logged
Oxford (England)
I thought servos used 50hz PWM as a control signal?
2.5% to 12.5% duty cycle to give end-to-end control.
UK
Online Online
50Hz yes, PWM no; well, not exactly.
The rate and duty cycles you mention will work, but the standard PWM pins don't run at 50Hz, more like  4 or 500Hz, which a standard R/C servo won't like.
Strictly speaking, R/C servos use Pulse Position Modulation (PPM), not Pulse Width Modulation (PWM).
The distinction is a fine one.
« Last Edit: October 30, 2009, 02:42:20 am by AWOL » Logged
Hi AWOL, below is [glow]your code[/glow]:
int filtered = 0;
[glow]And my program is[/glow]:
#include <LiquidCrystal.h>
#include <SoftwareServo.h>
SoftwareServo rudder;  // create servo object to control a servo
SoftwareServo aileron;  // create servo object to control a servo
SoftwareServo pitch;  // create servo object to control a servo
//=====================================Accelerometer============================================
int x_pot = 0;  // analog pin used to connect the potentiometer
int x_val;    // variable to read the value from the analog pin
int x_display;    // variable to read the value from the analog pin
int y_pot = 1;  // analog pin used to connect the potentiometer
int y_val;    // variable to read the value from the analog pin
int y_display;    // variable to read the value from the analog pin
//=====================================Joystick=======================================================
int x_joy = 2;  // analog pin used to connect the potentiometer
int z_val;    // variable to read the value from the analog pin
int z_display;    // variable to read the value from the analog pin
int y_joy = 3;
//===================================Switch================================================
int buttonPin = 7;
int buttonState =0;
LiquidCrystal lcd(6, 7, 8, 2, 3, 4, 5);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
  //rudder.attach(12);  // attaches the servo on pin 9 to the servo object
  aileron.attach(11);  // attaches the servo on pin 9 to the servo object
  pitch.attach(10);  // attaches the servo on pin 9 to the servo object
  if(buttonState == HIGH){
  x_val = analogRead(x_pot);            // reads the value of the potentiometer (value between 0 and 1023)
  y_val = analogRead(y_pot);            // reads the value of the potentiometer (value between 0 and 1023)
  x_val = map(x_val, 350,500 , 0, 179);     // scale it to use it with the servo (value between 0 and 180)
  y_val = map(y_val, 350, 500, 0, 179);     // scale it to use it with the servo (value between 0 and 180)
  else if(buttonState == LOW)
  x_val = analogRead(x_joy);            // reads the value of the potentiometer (value between 0 and 1023)
  y_val = analogRead(y_joy);            // reads the value of the potentiometer (value between 0 and 1023)
  x_val = map(x_val, 30,140 , 0, 179);     // scale it to use it with the servo (value between 0 and 180)
  y_val = map(y_val, 30, 140, 0, 179);     // scale it to use it with the servo (value between 0 and 180)
  //x_val = map(x_val, 30,60 , 0, 179);     // scale it to use it with the servo (value between 0 and 180)
  aileron.write(x_val);                  // sets the servo position according to the scaled value
  //aileron_right.write(x_val);                  // sets the servo position according to the scaled value
      // waits for the servo to get there
 // y_val = map(y_val, 30, 70, 0, 179);     // scale it to use it with the servo (value between 0 and 180)
  pitch.write(y_val);                  // sets the servo position according to the scaled value
  //delay(15);     // waits for the servo to get there
/*  x_val = analogRead(z_pot);            // reads the value of the potentiometer (value between 0 and 1023)
  z_val = map(z_val, 300, 800, 0, 179);     // scale it to use it with the servo (value between 0 and 180)
  rudder.write(z_val);                  // sets the servo position according to the scaled value
 // delay_val = analogRead(delay_pot);    // reads the value of the potentiometer (value between 0 and 1023)
 // delay_display = map(delay_pot, 0, 1023, 0 ,100);  // scale it to use it with the servo (value between 0 and 180)
  delay(15);
  SoftwareServo::refresh();
  // Print a message to the LCD.
  x_display = map(x_val, 0, 179, 0, 100);
  y_display = map(y_val, 0, 179, 0 ,100);
  lcd.clear();
   if( x_display == 50  ){
  lcd.setCursor(0,0);
  lcd.clear();
  lcd.print("Roll:");
  lcd.print(x_display-50);
  lcd.print("% neutral"); }
 else if( x_display >50){
  lcd.setCursor(0,0);
  //lcd.print("Pitch: 40%");
  //lcd.setCursor(0,1);
  //lcd.print("Yaw: 40%");
  //delay(2000);
 // lcd.clear();
  lcd.print("Roll:");
  lcd.print("% left");
  else {
   lcd.setCursor(0,0);
  //delay(2000);
  lcd.print("Roll:");
  lcd.print(50-x_display);
  lcd.print("% right");  }
  if( y_display == 50  ){
  lcd.setCursor(0,1);
  lcd.print("Pitch:");
  lcd.print(y_display);
  if(y_display >50){
  lcd.setCursor(0,1);
  lcd.print(y_display-50);
  lcd.print("% down");
  else {
  lcd.setCursor(0,1);
  lcd.print(50-y_display);
  lcd.print("% up");
basically I'm not using the LiquidCrystal.h, its just a additional thing. in which part of my program do you insert the code?
thks
UK
Online Online
Anywhere you need a filtered value.
You'll need a separate variable "filtered" for each value that you want to filter.
You might be better off not using the "softwareservo" library, and just use the standard "Servo" libray - it doesn't need a "refresh" and is possibly a little more accurate.
Please use the Code (#) button when posting code.
I see I see, thanks very much smiley
But I think I know what is the problem that cause the "noise". Basically I'm using a accelerometer to control the servo, the output of the accelerometer is not constant (eg. 350, 354, 348), and this might be the reason that cause the servo to be shaky. Do you have any way to make average out the accelerometer signal or PWM output to make it a constant (eg. [350 + 354 + 348] / 3 = 350.67) ?
I have an accelerometer  that runs on 3.3v.  The voltage regulator I was using was generating a very small amount of noise.  So small that I needed to use an oscilloscope to see it.  But the noise in the power supply was causing noticable noise in the reading from the accelerometer.  flitering the power with a capacitor fixed the issue
Hi gradbert, you mean put the 0.1 uF capacitor between the 3.3V terminal & gnd?
UK
Online Online
I already posted one - just substitute your accelerometer readings for the analogue readings in the example I gave in post #2.
Or if you prefer, substitute the PPM values for the servo.
Thanks AWOL, the program worked almost perfect, the x-axis & y-axis servo no longer 'jerk'. However, there's another problem.
When I turn the accelerometer on the x-axis, the servos for x-axis & y-axis move together. Similarly, when I turn the accelerometer on the y-axis, the servos for x-axis & y-axis move together also.
a servo
control a servo
SoftwareServo
to control a servo
int x_pot = 0;  //
potentiometer
int x_val;    //
from the analog pin
int
pin
potentiometer
int y_val;    //
from the analog pin
int
pin
int x_joy = 2;  //
potentiometer
int z_val;    //
from the analog pin
int
pin
int y_joy = 3;
int buttonPin = 7;
int
buttonState =0;
LiquidCrystal display with:
rs on pin 6
// rw on pin 7
enable on pin 8
// d4, d5, d6,
d7 on pins 2, 3, 4, 5
3, 4, 5);
Simple Averaging
Filter========================
const int
numReadings = 10;
int readings
[numReadings];      // the
readings from the analog input
int index = 0;
 // the index of the current
reading
int total = 0;
        // the running total
int average = 0;
 // the average
int filter(int num) {
subtract the last reading:
total= total - readings
[index];
  // read
from the sensor:
  readings
[index] = num;
  // add the
reading to the total:
  total=
total + readings[index];
  // advance to the next
position in the array:
index = index + 1;
  // if we're at the
end of the array...
  if (index
>= numReadings)
  // ...wrap around to the
beginning:
    index = 0;
calculate the average:
average = total / numReadings;
  return average;
void setup
  // initialize the
the servo object
the servo object
servo object
 //lcd.clear();
//lcd.print("Ngee Ann ");
//lcd.print("Polytechic");
delay(5000);
 /* lcd.clear();
lcd.print("Flight Simulator");
 lcd.setCursor(4,1);
lcd.print("Ver 3.0");
  delay
(2000);
  lcd.clear();
 for
(int thisReading = 0;
thisReading < numReadings;
thisReading++)
    readings
[thisReading] = 0;
void
loop()
  buttonState =
  if
  x_val
and 1023)
  y_val =
analogRead(y_pot);
and 1023)
  x_val = filter
(x_val);
  y_val = filter
(y_val);
  x_val = map(x_val,
180)
          // reads the value
between 0 and 1023)
  y_val =
analogRead(y_joy);
and 1023)
  x_val = filter
(x_val);
  y_val = filter
(y_val);
  x_val = map(x_val,
between 0 and 180)
between 0 and 180)
        // sets the servo
scaled value
                // sets the
the scaled value
there
 // y_val = map
180)
  pitch.write(y_val);
              // sets the
the scaled value
  //delay
servo to get there
between 0 and 1023)
  z_val =
180)
               // sets the
the scaled value
delay(15);
179, 0, 100);
  y_display =
lcd.clear();
   if( x_display
== 50  ){
  lcd.setCursor(0,0);
 lcd.clear();
  lcd.print
("Roll:");
  lcd.print
(x_display-50);
  lcd.print("%
neutral"); }
 else if(
x_display >50){
lcd.setCursor(0,0);
//delay(2000);
 // lcd.clear();
 lcd.print("Roll:");
else {
   lcd.setCursor(0,0);
//delay(2000);
  lcd.print
("Roll:");
  lcd.print(50-
x_display);
  lcd.print("%
right");  }
  if( y_display
== 50  ){
  lcd.setCursor
(0,1);
 if(y_display >50){
lcd.setCursor(0,1);
else {
  lcd.setCursor(0,1);
lcd.print("% up");
What's the problem? I don't understand.
