Loading...
Pages: [1]   Go Down
Author Topic: Programmer is not responding  (Read 201 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hello,
I've been using my Arduino Duemilanove 328 happily for a few weeks now. When I knocked off last night it was working just fine.
This morning, when I powered it up (via USB) the program that was loaded yesterday has stopped working and I can't upload anything to it.
I get: avrdude: stk500_recv(): programmer is not responding (twice).
The RX light flashes 3 times, there is a pause of about 1 second, it flashes once more - then I get the error message in the IDE.
I've done all the standard troubleshooting, the board is powering up and my DMM shows that the voltages all look right.
I was messing around yesterday with powering the board from an external supply - but like I said, it was working just fine when I shut down last night.
Is there anything I can try between now and ordering a new chip that might let me know if it is just a corrupt bootloader or a board problem?
Any help on this one would be most appreciated.
Thanks - J.
« Last Edit: November 21, 2009, 07:57:38 am by ADJ_ADT » Logged
ottawa, canada
Offline Offline
God Member
Arduino rocks
View Profile
I think the led blinking is the bootloader so the chip is executing instructions.
Logged
Spokane, Washington
Offline Offline
God Member
My name is Bob, and I'm an addict.
View Profile
WWW
Check to make sure you've got the right board selected (randomly when I log on, it's changed to something else)
Also, make sure nothing is connected to pin 0 and pin 1. The only other things I can think of  try push the reset button when uploading.
When I'm programming my chip on my breadboard (with the Arduino board) and I forget to hit reset, I get that error and the same LEDs lighting up. (this shouldn't matter, as the duemilanove has the auto-reset function, but a possibility)
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Thanks all,
I messed round with the Serial Port Selection this morning and she seems to be working again. Good, but odd.
I was sure I was using /dev/tty.usbserial (on Mac OS X / Arduino 0017) but it now seems to be working on /dev/cu.usbserial.
I guess it might have been a port selection thing after all.
Thanks again.
Logged
Pages: [1]   Go Up
Print
Jump to:
