Topic: Please upgrade your Yún - latest is 1.4.2 (Read 4283 times) previous topic - next topic
federicofissore
Sep 04, 2014, 03:35 pm Last Edit: Sep 22, 2014, 05:17 pm by MadBob Reason: 1
Hi everyone
another release of OpenWrt-Yun is available. You can download it from http://arduino.cc/en/Main/Software#toc8
1.4.2 includes both bug fixes and new stuff.
We fixed some glitches in the webpanel (a bug was found by wildpalms: thank you!)
The OpenWRT Image Builder and the software produced by the http://allseenalliance.org/ is now available for download
Compared to 1.4.1 this release contains:
  • OpenWrt-Yun (Linux side)
    • Added "image builder" to the build process. See https://github.com/arduino/openwrt-yun/issues/20
    • Added alljoyn feeds and packages. Ses https://github.com/arduino/openwrt-yun/issues/24
  • Web panel
    • Fixed wrong JSONP serialization. See https://github.com/arduino/YunWebUI/issues/13
    • Fixed a javascript error in webpanel login page
The complete list of changes is available at https://github.com/arduino/openwrt-yun/blob/master/ChangeLog
rouch_neck
Were there any bugs pertaining to the serial port?
I compiled my own YUN openwrt from the source and added my own C program that communicates over the serial port to the YUN arduino, however the communication has many problems, missing bytes, wrong byte received etc,even when I dialed down the baud rate to only 300, still errors.
I'm opening /dev/ttyATH0 from linux code on YUN, and used serial1 channel on arduino,simple serial communications dont work even when I removed this line from inittab still get lots of errors.
#ttyATH0::askfirst:/bin/ash --login
will the new YUN update fix this serial problems? Is another process opening port too while I'm using it on linux?
Please help!!
federicofissore
Nope sorry. Perhaps you want to post your issues on http://forum.arduino.cc/index.php?topic=264300.0 (where you've already commented) double checking if any available updates, on both openwrt yun and java ide, fix the problem.
Also, you may want to test the quality of ttyATH0 using some already available software, like python's pyserial, just to be sure the bug is not in your code.
SPlatten
I haven't done anything with the Yun for a while and came back tonight read this and was interested in upgrading my Yun. Downloaded the image then read the big red alert informing me that going ahead will Void the warranty on the Yun.
(http://arduino.cc/en/Tutorial/YunUBootReflash)
Why?
For now I have chosen not to reflash.
Kind Regards,
Sy
federicofissore
That's the advanced,  low level and dangerous way. There is a safer and easier one: http://arduino.cc/en/Tutorial/YunSysupgrade
SPlatten
Kind Regards,
Sy
subrosa
Just as a helpful hint to the new folk...can you add the "please upgrade" to the "Getting Started" guide?
federicofissore
Good point! I'll have the docs updated asap
eddybower
I did the upgrade and it worked fined.
But, I noticed that the linux kernel version is an old one.
In the old version the kernel was 3.8.3, and after the update, it was downgraded to 3.3.8.
See pictures 4 and 7 from our blog http://nootrix.com/2014/09/upgrade-arduino-yun-openwrt/
Is it on purpose?
Thanx for the great job,
Eddy
