Sorry, this is the complete code:
// Oregon V2 decoder added - Dominique Pierre
// Oregon V3 decoder revisited - Dominique Pierre
// New code to decode OOK signals from weather sensors, etc.
// 2010-04-11 <jcw@equi4.com> http://opensource.org/licenses/mit-license.php
// $Id: ookDecoder.pde 5331 2010-04-17 10:45:17Z jcw $
class DecodeOOK {
protected:
byte total_bits, bits, flip, state, pos, data[25];
virtual char decode (word width) =0;
public:
enum { UNKNOWN, T0, T1, T2, T3, OK, DONE };
DecodeOOK () { resetDecoder(); }
bool nextPulse (word width) {
if (state != DONE)
switch (decode(width)) {
case -1: resetDecoder(); break;
case 1: done(); break;
return isDone();
bool isDone () const { return state == DONE; }
const byte* getData (byte& count) const {
count = pos;
return data;
void resetDecoder () {
total_bits = bits = pos = flip = 0;
state = UNKNOWN;
// add one bit to the packet data buffer
virtual void gotBit (char value) {
total_bits++;
byte *ptr = data + pos;
*ptr = (*ptr >> 1) | (value << 7);
if (++bits >= 8) {
bits = 0;
if (++pos >= sizeof data) {
resetDecoder();
return;
state = OK;
// store a bit using Manchester encoding
void manchester (char value) {
flip ^= value; // manchester code, long pulse flips the bit
gotBit(flip);
// move bits to the front so that all the bits are aligned to the end
void alignTail (byte max =0) {
// align bits
if (bits != 0) {
data[pos] >>= 8 - bits;
for (byte i = 0; i < pos; ++i)
data[i] = (data[i] >> bits) | (data[i+1] << (8 - bits));
bits = 0;
// optionally shift bytes down if there are too many of 'em
if (max > 0 && pos > max) {
byte n = pos - max;
pos = max;
data[i] = data[i+n];
void reverseBits () {
for (byte i = 0; i < pos; ++i) {
byte b = data[i];
for (byte j = 0; j < 8; ++j) {
data[i] = (data[i] << 1) | (b & 1);
b >>= 1;
void reverseNibbles () {
data[i] = (data[i] << 4) | (data[i] >> 4);
void done () {
while (bits)
gotBit(0); // padding
state = DONE;
// 433 MHz decoders
class OregonDecoderV2 : public DecodeOOK {
public:
OregonDecoderV2() {}
if(!(total_bits & 0x01))
data[pos] = (data[pos] >> 1) | (value ? 0x80 : 00);
total_bits++;
pos = total_bits >> 4;
if (pos >= sizeof data) {
resetDecoder();
return;
state = OK;
virtual char decode (word width) {
if (200 <= width && width < 1200) {
byte w = width >= 700;
switch (state) {
case UNKNOWN:
if (w != 0) {
// Long pulse
++flip;
} else if (32 <= flip) {
// Short pulse, start bit
flip = 0;
state = T0;
// Reset decoder
return -1;
case OK:
if (w == 0) {
// Short pulse
state = T0;
// Long pulse
manchester(1);
case T0:
if (w == 0) {
// Second short pulse
manchester(0);
// Reset decoder
return -1;
return -1;
return total_bits == 160 ? 1: 0;
OregonDecoderV2 orscV2;
OregonDecoderV3 orscV3;
#define PORT 2
volatile word pulse;
// Serial activity LED
const int serialLED = 7;
// Sensor activity LED
const int sensorLED = 6;
// Details for my sensor:
const int sensorChannel = 1;
const int sensorCode = 0xEC;
// Serial variables
const int serialLength = 32; // size of the serial buffer
char serialString[serialLength];
byte serialIndex = 0;
char lasttemp[6] = "0.0";
char lasthumid[3] = "0";
long lasttime = 0;
#if defined(__AVR_ATmega1280__)
void ext_int_1(void) {
#else
ISR(ANALOG_COMP_vect) {
#endif
static word last;
// determine the pulse length in microseconds, for either polarity
pulse = micros() - last;
last += pulse;
void parseData (const char* s, class DecodeOOK& decoder) {
byte pos;
const byte* data = decoder.getData(pos);
// TODO: something sensible with the sensor code
// if ((int)(data[2] >> 4) == sensorChannel && (int)data[3] == sensorCode) {
if ((int)(data[2] >> 4) == sensorChannel) {
// Get the temperature.
char temp[6];
char *tempptr = &temp[0];
// 14th nibble indicates sign. non-zero for -ve
if ((int)(data[6] & 0x0F) != 0) {
*tempptr = '-';
tempptr++;
sprintf(tempptr, "%02x", (int)(data[5]));
tempptr = tempptr + 2;
*tempptr = '.';
tempptr++;
sprintf(tempptr, "%x", (int)(data[4] >> 4));
// Get the humidity.
char humid[3];
char *humidptr = &humid[0];
sprintf(humidptr, "%x", (int)(data[7] & 0x0F));
humidptr++;
sprintf(humidptr, "%x", (int)(data[6] >> 4));
humid[2] = '\0';
strcpy(lasttemp, temp);
strcpy(lasthumid, humid);
lasttime = millis();
decoder.resetDecoder();
void readSerial() {
while ((Serial.available() > 0) && (serialIndex < serialLength-1)) {
digitalWrite(serialLED, HIGH);
char serialByte = Serial.read();
if (serialByte != ';') {
serialString[serialIndex] = serialByte;
serialIndex++;
if (serialByte == ';' or serialIndex == (serialLength-1)) {
parseSerial();
serialIndex = 0;
memset(&serialString, 0, serialLength);
digitalWrite(serialLED, LOW);
void parseSerial() {
if (strcmp(serialString, "get") == 0) {
long age = (millis() - lasttime) / 1000;
// Format is "channel,temp,humidity,age;"
Serial.print("1,");
Serial.print(lasttemp);
Serial.print(",");
Serial.print(lasthumid);
Serial.print(",");
Serial.print(age);
Serial.print(";\n");
void setup () {
pinMode(serialLED, OUTPUT);
pinMode(sensorLED, OUTPUT);
pinMode(13, OUTPUT);
digitalWrite(13, LOW);
#if !defined(__AVR_ATmega1280__)
pinMode(13 + PORT, INPUT); // use the AIO pin
digitalWrite(13 + PORT, 1); // enable pull-up
// use analog comparator to switch at 1.1V bandgap transition
ACSR = _BV(ACBG) | _BV(ACI) | _BV(ACIE);
// set ADC mux to the proper port
ADCSRA &= ~ bit(ADEN);
ADCSRB |= bit(ACME);
ADMUX = PORT - 1;
#else
attachInterrupt(1, ext_int_1, CHANGE);
DDRE &= ~_BV(PE5);
PORTE &= ~_BV(PE5);
#endif
// Serial.println("\n[weatherstation initialised]");
void loop () {
static int i = 0;
cli();
word p = pulse;
pulse = 0;
sei();
//if (p != 0){ Serial.print(++i); Serial.print('\n');}
if (p != 0) {
digitalWrite(sensorLED, HIGH);
if (orscV2.nextPulse(p)) {
parseData("OSV2", orscV2);
digitalWrite(sensorLED, LOW);
readSerial();
