Hey guys, so I figured I've lurked around on here long enough and although I've spent a bit of time poking around with the arduino, I still consider myself very green. I couldn't find this specific problem anywhere in the forum so I thought I'd post it here. I just learned not too long ago that the arduino can interface with a wii nunchuck and read the accelerometer data along with the joystick position, very cool! It saves me from having to buy one and solder it into a breakout board while trying to keep it somewhat level. Anyway, I've tried to communicate with the nunchuck using the code from windmeadow (I can't hyperlink this until I've made my first post apparently) but I can't seem to get it working. I'm using the arduino mega (I had one lying around) and I have the SDA and SCL pins connected to pins 20 and 21. I upload the code, switch to the serial monitor, and all I get is "Finished Setup". So, I added a few more Serial.print lines just to see where things were stopping, and it looks like it stops communicating during nunchuck_init(), more specifically right after it sends the 0 at Wire.send(0x00) and before Wire.endTransmission(). Here's the code with the few serial.print lines I've added. Any thoughts on this? Thanks in advance!
#include <Wire.h>
#include <string.h>
#undef int
#include <stdio.h>
uint8_t outbuf[6]; // array to store arduino output
int cnt = 0;
int ledPin = 13;
void
setup ()
Serial.begin (19200);
Serial.print ("Finished setup\n");
Wire.begin (); // join i2c bus with address 0x52
nunchuck_init (); // send the initilization handshake
void
nunchuck_init ()
Serial.print ("Begin handshake\n");
Wire.beginTransmission (0x52); // transmit to device 0x52
Serial.print ("0x52\n");
Wire.send (0x40); // sends memory address
Serial.print ("0x40\n");
Wire.send (0x00); // sends sent a zero.
Serial.print ("0x00\n");
Wire.endTransmission (); // stop transmitting
Serial.print ("End handshake\n");
void
send_zero ()
Wire.send (0x00); // sends one byte
void
loop ()
Wire.requestFrom (0x52, 6); // request data from nunchuck
while (Wire.available ())
outbuf[cnt] = nunchuk_decode_byte (Wire.receive ()); // receive byte as an integer
digitalWrite (ledPin, HIGH); // sets the LED on
cnt++;
// If we recieved the 6 bytes, then go print them
if (cnt >= 5)
print ();
cnt = 0;
send_zero (); // send the request for next bytes
delay (100);
// Print the input data we have recieved
// accel data is 10 bits long
// so we read 8 bits, then we have to add
// on the last 2 bits. That is why I
// multiply them by 2 * 2
void
print ()
int joy_x_axis = outbuf[0];
int joy_y_axis = outbuf[1];
int accel_x_axis = outbuf[2] * 2 * 2;
int accel_y_axis = outbuf[3] * 2 * 2;
int accel_z_axis = outbuf[4] * 2 * 2;
int z_button = 0;
int c_button = 0;
// byte outbuf[5] contains bits for z and c buttons
// it also contains the least significant bits for the accelerometer data
// so we have to check each bit of byte outbuf[5]
if ((outbuf[5] >> 0) & 1)
z_button = 1;
if ((outbuf[5] >> 1) & 1)
c_button = 1;
if ((outbuf[5] >> 2) & 1)
accel_x_axis += 2;
if ((outbuf[5] >> 3) & 1)
accel_x_axis += 1;
if ((outbuf[5] >> 4) & 1)
accel_y_axis += 2;
if ((outbuf[5] >> 5) & 1)
accel_y_axis += 1;
if ((outbuf[5] >> 6) & 1)
accel_z_axis += 2;
if ((outbuf[5] >> 7) & 1)
accel_z_axis += 1;
Serial.print (joy_x_axis, DEC);
Serial.print ("\t");
Serial.print (joy_y_axis, DEC);
Serial.print (accel_x_axis, DEC);
Serial.print (accel_y_axis, DEC);
Serial.print (accel_z_axis, DEC);
Serial.print (z_button, DEC);
Serial.print (c_button, DEC);
Serial.print ("\r\n");
// Encode data to format that most wiimote drivers except
// only needed if you use one of the regular wiimote drivers
char
nunchuk_decode_byte (char x)
x = (x ^ 0x17) + 0x17;
return x;
Hopefully one day I get the hang of all this enough so I can post answers instead of problems, haha.
Edit: Oops, meant to drop this under Interfacing
