Topic: LPC810 mini ARM Prozessor in 8 pin dip package (Read 17154 times) previous topic - next topic
ChrisMicro
There is a little ARM-microcontroller in a 8 pin dip package.
Here I started to write a Arduino-Lib in C to make it easier to use this powerful and cheap chip:
http://hobby-roboter.de/forum/viewtopic.php?f=4&t=152
The chip itself can be programmed by a serial line. I used an old Arduino-Diecimilla on which I removed the Atmega8 and used it as an USB to serial converter. It is only neccessary to connect a Resistor to GND on the Rx line of the LPC810 because it uses 3.3V.
Have fun,
chris
ChrisMicro
For now, the following functions are implemented and working:
void pinMode(uint8_t pin, uint8_t mode);
void digitalWrite(uint8_t pin, uint8_t value);
void digitalToggle(uint8_t Pin);
int digitalRead(uint8_t pin);
void delay(uint32_t milliSeconds);
void Serial_begin(uint32_t baudRate);
void Serial_print(char * string);
void Serial_println(char * string);
void Serial_printnumber(uint32_t number);
uint32_t millis();
uint16_t analogRead(uint8_t channel );
int32_t map(int32_t x, int32_t in_min, int32_t in_max, int32_t out_min, int32_t out_max);
graynomad
Nice job from what I can see.
I'm a big fan of the LPCs and have also done an Arduino port (to the 1227). I too used C rather than C++ because at the time the C++ compiler cost $256. It's now free and I have a rewrite on my todo list.
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
ChrisMicro
Hi Rob,
thank you for your response.
>I too used C rather than C++ because at the time.
You are rigth, C++ is better because the commands can be made more compatible to the original.
Using my lib you would have to write
Serial_begin(9600);
instead of
and it is not "polymorphic" that the arguments can have different types.
The reason why I did it in this way is that I couln't find an easy to install C++ compiler for my Ubuntu 12.04 and I didn't want to put to much time in installing the development system.
There was only a precompilde C compiler
https://launchpad.net/~terry.guo/+archive/ubuntu/gcc-arm-embedded
so I used C.
And I'm not shure if C is using less memory because the space is very limited on the LPC810.
Du you have a link to your code? Probably it would be a nice idea to port it to a LPC1114FN28.
It has a 28 pin dip package.
graynomad
#4
Sep 16, 2014, 03:45 pm Last Edit: Sep 16, 2014, 04:44 pm by Graynomad Reason: 1
I have a couple of pages describing the API here
http://lard.robgray.com/index.php
I haven't done anything with this for maybe a year two years. The source is in a Git repo somewhere, it's not even at alpha state and not really for public consumption but if you want to have a look I can find the URL.
______
Rob
bobcousins
so I used C.
GCC includes a C++ compiler!
The LPC chips are good, I have done a few projects with them. I've mostly used free tools, though I did pay for a license for a vendor neutral tool to get JTAG debugging, but TBH it was not great value for money.
The ARM vendors seem to be competing by offering free IDEs, which is a great for us. Arduino everywhere!
Please ask questions in the forum so everyone can benefit. PM me for paid work.
ChrisMicro
uuuh ... I thought it is
arm-none-eabi-g++
I tried to compile C++ code with the make file included in my library:
http://hobby-roboter.de/forum/download/file.php?id=191
but I was not successful. I'm not good in creating make-files therefore I gave it up to compile C++ and used C instead.
But if anyone can rework the make-file for C++ it would be usefull.
BTW.: would it be possible to use the Arduino IDE ( for Arduino DUE ) to compile the code for the LPC810 ?
graynomad
It always was possible to use C++ if you were happy to dick around with makefiles, I even think you could still use the IDE, but that was too much like hard work for me so I use the LPCXpresso environment and dev boards, really simple almost turnkey operation.
I haven't looked at the LPC range for a while, I just noticed the new LPC11U68, what a great chip and there's a Xpresso dev board for it with Arduino headers.
I may revisit my LARD framework with a view to converting to C++ and getting it running on this and also smaller chips like the LPC1114FN28 you mentioned Chris. It's a bit heavy on resources though, dunno if it will fit, I'll check out that chip now.
Meanwhile I'm grabbing the latest LPCXpresso IDE.
______
Rob
bobcousins
It was always possible to build C++ code for ARM using Eclipse and the embedded plugin, no dicking around with makefiles required :)
You can't beat the vendor tools for ease of use though, as long as you don't mind being locked into their parts.
graynomad
OK, I remember there was a thread on the forum about getting the free IDE to work with C++, it's been a while now. IIRC it was just an option somewhere although I thought you had to point the IDE to your own makefile but maybe not. Either way the GCC compiler was the same.
I actually had a big winge to NXP about the fact that you had to pay for C++ when on other platforms like Arduino it was the default and free. Next thing I know I get asked to beta test the latest (at the time) IDE with C++ support, but by then I had lost interest.
______
Rob
bobcousins
I've got the Seeduino Arch Pro, so I would quite like to do an Arduino API for LPC1768, I've also got a few mini LPC boards which are ripe for Arduinoising (is that a word?).
graynomad
Quote
Not as it is, I think you would have to add your own variant file and core libraries but that's not an area I'm very familiar with.
@Bob/Chris, is it worth trying to develop an LPC Arduino port that will support several versions of LPC? It's certainly been an interest of mine but TBH I'm probably more HW than SW. I can certainly write code (was employed to do so for many years) but it's the toolchain stuff and organisation of files to allow all different CPUs that I struggle with.
______
Rob
ChrisMicro
I don't know. But it is always nice if there is a new microcontroller and an arduino lib avalilable. You can be very quick in getting the system running. Of course the arduino lib is not really for professional uses but for a first try it is quite good.
There is an arduino Lib for the STM-microcontrollers:
https://github.com/leaflabs/libmaple
Probably it would be good to have some thing like that for the LPCs.
I hate struggling with the toolchain stuff, but it happens every time I use a new controller. 2-3 days of struggling ...
That is the big advantage of the arduino ide: not really comfortable but quick to install.
ChrisMicro
That board looks very promising:
http://www.seeedstudio.com/wiki/Seeeduino_Arch
Also a nice board:
http://www.nxp.com/demoboard/OM13058.html
Strange that the have the arduino pin out and not an arduino lib.
graynomad
Quote
There's an opportunity for a bright young lad.
I think I'll get one of those OM13058s, that 11U68 CPU looks fantastic and I like the LPC architecture. I've been looking at the SAM D21 of late as well, great features but the registers are a real cluster f*ck. I know it's stupid and only matters to system programmers but that sort of thing really pisses me off.
______
Rob
