Topic: attachInterrupt get interrupted pin (Read 3794 times) previous topic - next topic
brightdroid
I'll try to use one function to handle interrupts (same type) on multiple pins.
My question is, how can I get the currently interrupted pin number?
Sample Code:
Code: [Select]
int pinEcho1 = 30;
int pinEcho2 = 32;
void handleInterrupt()
  Serial.print("handle interrupt on pin: ");
  Serial.println(/* how? */);
  attachInterrupt(pinEcho1, handleInterrupt, CHANGE);
  attachInterrupt(pinEcho2, handleInterrupt, CHANGE);
MarkT
groundFungus
+1 for a handler for each interrupt.
Take the serial prints out of the interrupt handler(s).  Set a flag in handler and print in loop() when the flag is set.
brightdroid
Sure two functions work, but I'd like to use only one.
Is there no way to determine the pin which is currently interrupted?
P. S. the Serial.print is just for the example
Thanks in advance
groundFungus
The external interrupt flag register, EIFR, has a flag for each external interrupt. You should be able to check that register to see which pin caused the interrupt.  Check the data sheet under external interrupts.
MarkT
The Arduino attachInterrupt mechanism already polls this register to
dispatch to the right function, so just use a function per pin.  These functions
can call common code with a pin number if you like - a macro can be used
to define them even :
Code: [Select]
#define PIN_HANDLER(pin) \
void pin_handler_##pin (void) \
  common_handler (pin) ;
- it would be nice if that could put the attachInterrupt calls in setup() but
alas C macros are lowly beasts with few powers.
Perhaps polling the register yourself is best, on reflection!
It wouldn't be hard to adapt WInterrupts.c to use handler functions
with the signature:
Code: [Select]
void handler (int pin)
But it would mean creating some port/mask -> Arduino pin reverse
mappings.
brightdroid
Mhh, not working... :(
Code: [Select]
int pinEcho1 = 30;
int pinEcho2 = 32;
  handleInterrupt(pin);
void handleInterrupt(int pin)
  Serial.println(pin);
  attachInterrupt(pinEcho1, PIN_HANDLER(30), CHANGE);
  attachInterrupt(pinEcho2, PIN_HANDLER(32), CHANGE);
Message:
Quote
sketch_sep18a.ino:7:18: error: expected constructor, destructor, or type conversion before '(' token
sketch_sep18a.ino:8:1: error: expected declaration before '}' token
MarkT
Sorry,. forgot all the line continuations on that macro.  Fix it...
brightdroid
MarkT
Do you have any idea?
Erm, fix the missing line continuations?  Just \
add \
them \
to \
the \
end.
brightdroid
Mhhh, not working :(
Code: [Select]
int pinEcho1 = 30;
int pinEcho2 = 32;
  handleInterrupt(pin); \
Quote
Arduino: 1.5.7 (Linux), Board: "Arduino Due (Programming Port)"
sketch_sep22a.ino: In function 'void setup()':
sketch_sep22a.ino:5:1: error: expected primary-expression before 'void'
sketch_sep22a.ino:20:29: note: in expansion of macro 'PIN_HANDLER'
sketch_sep22a.ino:21:29: note: in expansion of macro 'PIN_HANDLER'
Any idea? Thanks :)
MarkT
Please actually think about the code - it is a macro for _defining_ functions.
So you call it at top-level to define the functions, it doesn't create function
calls, you have to do that:
Code: [Select]
const int pinEcho1 = 30;
const int pinEcho2 = 32;
// Now define all the trampoline functions
PIN_HANDLER (pinEcho1)
PIN_HANDLER (pinEcho2)
   // Do the right thing here.  Do not call delay() or Serial or anything else using interrupts!
  attachInterrupt (pinEcho1, pin_handler_pinEcho1, CHANGE);
  attachInterrupt (pinEcho2, pin_handler_pinEcho2, CHANGE);
brightdroid
Mhh, ok understand  :(
So is there no way to define it dynamically?
Thanks for your help :)
MarkT
C and C++ don't support closures, so there's no way to define functions
at runtime.  Its pretty clunky in fact.  And the macro system is horrible beyond
reason.
