Loading...
Pages: [1]   Go Down
Author Topic: need Help: Cannot upload code to Pro Mini board  (Read 153 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
I think my Pro Mini board is broken now.
I have two laptops:
1) Window XP
2) Vista
My Arduino is:
Pro Mini (Atmega 168)
I use FTDI adaptor chip/board for usb-to-serial connection.
Pro mini (it is 168 version i think: atmega 168), used to work on another laptop with XP untill few days back.
But I wanted to switch to laptop 2) with Vista.
So I downloaded IDE to laptop with Vista.
But I cannot get it to work on this new laptop with Vista.
When  I try to upload sketch I get error:
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocaol error, expect-0x14...
After this I tried several things:
confirm firewall is off
COM port is defined correctly
tried changing baude rate
tried latedt FTDI drivers
Then I went back to older laptop (on which it used to work until few days back). But i get same error on this laptop also !
So, now it does not work on XP or on Vista.
Both give same error as mentioned above.
So, I concluded the chip must be broken, right ?   smiley-sad
Logged
Forum Administrator
Cambridge, MA
Offline Offline
Faraday Member
View Profile
WWW
How is it connected?
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
You mean how is it connected with laptop ?
Well, I use a FTDI board that connects to Pro Mini. And the USB cable goes into FTDI board.
A sensor is connected to Pro Mini via analog input pins.
Pro mini gets power from USB.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Also:
- Red led on the Pro Mini lights up (and stays on, i think)
- Green LED beside reset button lights up when reset is pressed
- Tx/Rx LED on FTDI board blinks on/off after I press 'upload' button in IDE.
Logged
Pages: [1]   Go Up
Print
Jump to:
