Topic: Up and Down counter with Debounce (Read 11598 times) previous topic - next topic
bastukee
OK!!!
So once millis reaches the maximum value, then it rolls over to 0, good to know!!!!
My code works perfectly when powered on USB to the terminal window.
My issue now is:
I power the Arduino Duemilanove ATMEGA168 board externally with 12V, since Rx and Tx are TTL, I thought I could loop Pin0 and Pin1, but it does not seem to work...
How do you make a Loop on the Arduino Pin0 and Pin1?
No trees were harmed by the transmission of this message. However a few million electrons were temporarily inconvenienced.
Groove
A couple of centimetres of hookup wire.
But why?
Per Arduino ad Astra
bastukee
Basically, the code sends a channel # Ex. "+TSC04" and if it echos back, the Arduino will display the current channel on the BCD/7-segment display...so if I could loop both serial pins it would act like I have it connected to the radio I plan to change channels too.
But it was a no-go when I did the mentioned hoop up wire from Pin0 to Pin1.
Groove
You've disconnected the FTDI chip?
bastukee
Grumpy_Mike
can I do this with jumper?
No look at the schematic you will find two 1K resistors in series with the TX and RX lines, remove them to isolate the line. However you have to solder them back to up load another sketch, so maybe you could add your own jumpers.
bastukee
Thanks for all your replays...
At this point I'm more than happy with my program, yet per the schematics I can't do a hardware loop back successfully.
I tried even removing Pin 2 and 3 on the Duemilanove and crossing them, but stil when I press the buttons I don't see the channel change. I even went and bought a 16 Mhz osc, but when I would plug the MAx233A TTL to RS232 converter, it would like reset the programming and I would have to re-program the device constantly. I can probably blame it on static, "tomorrow I try with 0.1 caps" but still, what I really need is the Serial 232 board that predates the Duemilanove.
Also, if anyone knew a good Software Loop Back for a Com Port it would be awesome! I tried making it on Visual Studio and got nowhere hehe.
I will keep you guys posted on the progress as it happens, but this is where I'm now...
bastukee
While I await for parts, I found a odd bug.
If I send over serial a command "+TSC01" to "+TSC09" all works fine.
Once I start sending commands different than those, it does odd things, example:
+TSC33
It shows 3 on the BCD 7 Segment LED
or
+TSC55
it shows 5 on the BCD 7 Segment LED
I like to add to my code a way that when it receive anything other than those in the switch case it would show a error.
Like on the if and else statements...but for the switch...
const int inPinUp = 6;
const int inPinDown = 7;
int channel = 1;
int buttonUpState = 0;
int buttonDownState = 0;
int prevBtnUp = LOW;
int prevBtnDwn = LOW;
unsigned long lastBtnUp = 0;
unsigned long lastBtnDwn = 0;
int transInt = 250;
int chanPolling = 10000;
unsigned long chanPrevPoll = 0;
char chan;
 pinMode(inPinUp, INPUT);
 pinMode(inPinDown, INPUT);
 for (int updown = 6; updown < 8; updown++) {
        pinMode(updown, INPUT);
 for (int BCD = 2; BCD < 6; BCD++) {
        pinMode(BCD, OUTPUT);
void channelFunction()
 switch (channel)
     case 1:
       Serial.println("+TSC01");
       Serial.println("+TSC?");
       break;
     case 2:
       Serial.println("+TSC02");
       break;
     case 3:
       Serial.println("+TSC03");
       break;
     case 4:
       Serial.println("+TSC04");
       break;
     case 5:
       Serial.println("+TSC05");
       break;
     case 6:
       Serial.println("+TSC06");
       break;
     case 7:
       Serial.println("+TSC07");
       break;
     case 8:
       Serial.println("+TSC08");
       break;
     case 9:
       Serial.println("+TSC09");
       break;
 buttonUpState = digitalRead(inPinUp);
 buttonDownState = digitalRead(inPinDown);
 if (buttonUpState == HIGH && prevBtnUp == LOW)
   if (millis() - lastBtnUp > transInt)
   channel++;
   if (channel > 9)
     channel = 1;
   lastBtnUp = millis();
   channelFunction();
 prevBtnUp = buttonUpState;
 if (buttonDownState == HIGH && prevBtnDwn == LOW)
   if (millis() - lastBtnDwn > transInt)
   channel--;
   if (channel < 1)
     channel = 9;
   lastBtnDwn = millis();
    channelFunction();
 prevBtnDwn = buttonDownState;
     if (millis() - chanPrevPoll > chanPolling)
   chanPrevPoll = millis();
 if (Serial.available() > 0)
    chan = Serial.read();
    switch (chan){
    case '+TSC01':
      digitalWrite(2, LOW);
      digitalWrite(3, LOW);
      digitalWrite(4, LOW);
      digitalWrite(5, HIGH);
      break;
    case '+TSC02':
      digitalWrite(4, HIGH);
      digitalWrite(5, LOW);
      break;
    case '+TSC03':
      break;
    case '+TSC04':
      digitalWrite(3, HIGH);
      break;
    case '+TSC05':
      break;
    case '+TSC06':
      break;
    case '+TSC07':
      break;
    case '+TSC08':
      digitalWrite(2, HIGH);
      break;
    case '+TSC09':
      break;
    default:
        digitalWrite(BCD, LOW);
PaulS
You have this code:
    switch (chan){
    case '+TSC01':
The chan variable is a single character. The case statement has multiple characters in the single character quotes.
That won't work.
If none of the previous switch cases are true, the default case will be executed. Put your error stuff there.
bastukee
PaulS
I believe I found out why my Arduino was not working, I have got a few 16 MHz crystals that I bought at a local store, for what I have being reading, you need the correct pairing of capacitors to make the crystal oscillate correctly. I went ahead and ordered the same crystal on the Arduino with a matching pair of 22p caps. I also ordered a ceramic resonator just in case.
http://www.cutedigi.com/product_info.php?cPath=277&products_id=4299&osCsid=fa52452e4320cff6523c735974aaf920
Now on the coding, I used:
char chan
So if I want to use a variable with more than a character then I must use something like this?
int chan
and for the code, I should replace this...
case '+TSC01'
with these?
case "+TSC01"
or what do I use for a multi-character variable case?
When I compile it gives me:
error: invalid conversion from 'const char*' to int
PaulS
If you want to read a string from the serial port, you have to do that one letter at a time. You store each letter in an array, and increment the index into that array.
char serialString[20]; // Set whatever size is appropriate
int serialIndex = 0;
char TC = '#'; // Some terminating character that you send
  while(Serial.available() > 0)
      char aChar = Serial.read();
      if(aChar == TC)
         break;
      serialString[serialIndex] = aChar; // Store the character
      serialIndex++;
      serialString[serialIndex] = '\0'; // Null terminate the string
  // Now, serialString contains something like "+TSC01".
  if(strcmp(serialString, "+TSC01") == 0)
      // The strings match. Do something...
  else if(strcmp(serialString, "+TSC02") == 0)
     // These strings match. Do something...
      // Unrecognized string. Let some smoke out...
      // Or something...
You can't use a switch statement with non-constant cases (like strings), so you have to emulate the switch statement with if/else if/else.
bastukee
#26
Feb 05, 2010, 07:56 pm Last Edit: Feb 05, 2010, 07:57 pm by bastukee Reason: 1
I can't program a termination character, so I used part of example code to array the serial characters, also strcmp and if else statements.
So far this works
I set my array for 6, now the issue is...what if I get garbage data in between?
for example...
1234567+TSC0189012
since is more than 6, when it gets to 7 it starts the array over and it sees:
123456
7+TSC0
189012
which when comparing with strcmp it can't recognize it.
I was wondering how to fix this...if I have to increase the size of my array and use ** or something alike?
This is my current code
int channel = 1;
int transInt = 250;
char serialString[6];
 switch (channel)
     case 1:
       break;
     case 2:
       break;
     case 3:
       break;
     case 4:
       break;
     case 5:
       break;
     case 6:
       break;
     case 7:
       break;
     case 8:
       break;
     case 9:
       break;
   channel++;
   if (channel > 9)
     channel = 1;
   channelFunction();
   channel--;
   if (channel < 1)
     channel = 9;
    channelFunction();
    serialIndex++;
    else if(strcmp(serialString, "+TSC03") == 0)
    else if(strcmp(serialString, "+TSC04") == 0)
    else if(strcmp(serialString, "+TSC05") == 0)
    else if(strcmp(serialString, "+TSC06") == 0)
    else if(strcmp(serialString, "+TSC07") == 0)
    else if(strcmp(serialString, "+TSC08") == 0)
    else if(strcmp(serialString, "+TSC09") == 0)
        Serial.println(serialString);  //for de-bugin
PaulS
If the valid part of the string always starts with +TSC, start storing data only when the + is encountered.
If not, you will need to find a way to send a start or stop (or both) character.
bastukee
I tried this approach...
    if (aChar or serialString[0] == '+')
      serialIndex++;
      serialString[0] = '\0';
But it does exactly what it use to do...
PaulS
Try this then:
boolean startReceived = false;
      if(startReceived)
         serialIndex++;
         if(aChar == '+')
            strartReceived = true;
            serialIndex++;
