Hi there,
Environment: Duemilanove, ATmega328, USB-cable, openSUSE 11.2
As a nubee, at first I try to load the Blinker-Programm to the brand-new duemilanove. The green-LED is on, the PIN13-LED is already blinking since the first connection to the PC's USB-Port (without having loaded anything before).
Pushing the shift-button while uploading gives the following output:
Binary sketch size: 918 bytes (of a 14336 byte maximum)
/home/rafa/bin/arduino-IDE/arduino-0018/hardware/tools/avrdude -C/home/rafa/bin/arduino-IDE/arduino-0018/hardware/tools/avrdude.conf -v -v -v -v -patmega168 -cstk500v1 -P/dev/ttyUSB0 -b19200 -D -Uflash:w:/tmp/build3305624307436407839.tmp/Blink.cpp.hex:i
avrdude: Version 5.4-arduino, compiled on Jul 15 2009 at 20:33:23
Copyright (c) 2000-2005 Brian Dean,
http://www.bdmicro.com/ System wide configuration file is "/home/rafa/bin/arduino-IDE/arduino-0018/hardware/tools/avrdude.conf"
User configuration file is "/root/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyUSB0
Using Programmer : stk500v1
Overriding Baud Rate : 19200
avrdude: Send: 0 [30] [20]
avrdude: ser_recv(): programmer is not responding
avrdude: Send: Q [51] [20]
I read the troubleshooting-page and checked all the advised points.
I tried the upload with 9600 and 19200 bd as well (configured in the preferences.txt-file).
Furthermore: When I start the Arduino-IDE, the first board of the tools/board-menu is set by default. But with this choice nothing works. So I tried the second choice... with this choice I can start the upload.. but the result is the same.
The board is brand new, delivered from watterot-company yesterday, originally seald and treated like a raw egg !!! So I don't consider hardware-damage as cause of the problem.
Any Ideas ??
Thanks in advance, rafa from Ludwigshafen
