« on: May 31, 2010, 03:41:05 pm » |
Hi, I have one question. I write something on my arduino, but then when I turn it on again, it take some seconds to start running. Is there a way to make it start faster?
Thanks
DeKalb, IL USA
KB9SXU
« Reply #1 on: May 31, 2010, 04:19:05 pm » |
The delay is in the bootloader. Have a look at some of the alternative bootloaders, take a look in the playground or search google. If you have a programmer that doesn't require a bootloader, you could remove the bootloader completely and have no delay caused by a bootloader.
Jeff K - JKDevices.com - home of the MegaMini
SE USA
@ssh0le
« Reply #2 on: May 31, 2010, 05:01:04 pm » |
yea you will have to change bootloaders, which require a avr programmer, or atleast another arduino to act as one
« Reply #3 on: May 31, 2010, 05:46:10 pm » |
Ok, I have the USBTinyISP, where can I get more info about how to program? Because my program was written on arduino.
Thanks in advance
DeKalb, IL USA
KB9SXU
« Reply #4 on: May 31, 2010, 07:25:12 pm » |
To point you in the right direction... you will probably have to use avrdude through the command line to either get rid of the current bootloader or change the bootloader. Then I think you would need to modify your boards.txt file in the arduino folder to allow you to program directly from the arduino IDE. For an different bootloader... take a look here for directions... http://www.ladyada.net/library/arduino/bootloader.html
SE USA
@ssh0le
« Reply #5 on: May 31, 2010, 07:39:49 pm » |
quick tutorial ... http://www.ladyada.net/make/usbtinyisp/use.htmlusing avr dude and the command line, from there you can replace the bootloader with a modified quick load one, or you can search your computer for the most recent compiled version out of the arduino IDE (its in a temp folder and likes to move) and upload it through the command line or you can modify boards.txt to use your programmer (on the avrdude tutorial its specified as avrdude -c usbtiny) so you can upload direct from arduino with no bootloader
« Last Edit: May 31, 2010, 07:40:27 pm by Osgeld »
« Reply #6 on: June 01, 2010, 11:14:41 am » |
if I get the .hex file and upload usin =g AVRDUDE, will it work without the bootloader, and then won't have that delay?
Thanks
« Reply #7 on: June 01, 2010, 11:47:30 am » |
another thing, arduino is not writing the .hex on the file folder anymore?
SE USA
@ssh0le
« Reply #8 on: June 02, 2010, 03:26:50 pm » |
yes if you upload the hex via your programmer (avrdude is just a soft tool, even arduino uses it for serial uploads) then there will be zero delay
and no, it does not put the hex in the same folder as your script anymore, it lurks in a temp file, so I am often doing windows search for sketch*.hex while I am using my attiny84
« Reply #9 on: June 03, 2010, 06:54:34 pm » |
so I could use arduino to make the prototype, then if I want to write, let's say 10 circuits, then the best would be to get the .hex and program it using ICSP, so it wouldn't have that annoying delay. right?
thanks
