IF you use a real Arduino board, RESETR will be on one of the header pins. The board will have the button (normally open) & the required pull-up resistor. Just take a wire from the RESET pin and a wire from GND, the ground (common.)
Use a pushbutton also normally open and thee two leads. Now, the external button works like the one on the board - no code.
Ray
