North Yorkshire, UK
Offline
Faraday Member
« Reply #15 on: June 24, 2010, 07:52:36 am » |
Mine have double sided tape that I can peel off temporarily and I could just cut through the metal strip. Mine all seem to be moulded into the plastic but mine have a break anyway  Mowcius
Logged
Western New York, USA
Offline
Faraday Member
« Reply #16 on: June 24, 2010, 08:56:52 am » |
You could always just break the row yourself, at least on some breadboards. Mine have double sided tape that I can peel off temporarily and I could just cut through the metal strip. As in Reply # 9. Don
Logged
Offline
Faraday Member
« Reply #17 on: June 24, 2010, 09:01:53 am » |
As far as I know, that's how they originally were. I am still using some of my original EL breadboards from the 1980's (or maybe earlier). They do not have the break. Also the horizontal strips are less than 0.3 inches from the vertical strips and more than 0.1 inch apart. I remember a lot of head scratching the first time I encountered a strip with the break. Don
« Last Edit: June 24, 2010, 09:02:52 am by floresta »
Logged
0
Offline
Newbie
Arduino rocks
« Reply #18 on: June 26, 2010, 12:48:39 pm » |
How do you determine that there is or is not a break? Also, what markings on the breadboard suggest one or the other that caused the confusion in the first place?
Logged
SE USA
Offline
Faraday Member
@ssh0le
« Reply #19 on: June 26, 2010, 12:53:10 pm » |
my radio shack bread board has no marking on it, its just a white breadboard on a black metal plate
my other one has red and blue lines on the bus bar, but as indicated above, just cause they run all the way across doesn't mean their connected (although mine is)
Logged
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
0
Offline
God Member
Arduino rocks
« Reply #20 on: June 26, 2010, 01:01:42 pm » |
Doesnt your RS board have a BREAK? down the outside rails though? (Im pretty sure it does).. also marked with a "W"
Logged
SE USA
Offline
Faraday Member
@ssh0le
« Reply #21 on: June 26, 2010, 01:37:57 pm » |
nope, the only marking rows and they are not printed, rather moulded in the plastic
also the bus sections are all evenly spaced so there is no indication that the breaks were there
Logged
Manchester, New Hampshire
Offline
Edison Member
Propmaker
« Reply #22 on: June 26, 2010, 04:39:32 pm » |
So last night I discovered that the Sparkfun board I bought didn't actually have a break on the voltage rails like I thought. I was certain it had a break... I could have sworn the reason I knew it had a break was because it caused one of my other circuits to fail. But lo and behold my AtMega was pulling power from the voltage regulator. I thought I must be going mad! Then just now, I discovered exactly the opposite. I went to connect a switch to one of the positive voltage rails and got nothing. So the Sparkfun board DOES have a break! But how can this be? ONE SET OF RAILS HAS A BREAK, AND THE OTHER SET DOES NOT. ON THE SAME BOARD. >
« Last Edit: June 26, 2010, 04:41:35 pm by scswift »
Logged
SE USA
Offline
Faraday Member
@ssh0le
« Reply #23 on: June 26, 2010, 09:10:21 pm » |
my "other" bread board is was bought from sparkfun, it does not have the break :o with the elenco line I think there is a product id difference tween the 2, but not sure no big deal carefully peel back the liner, solder or cut to your preference, do your self a favour and mount it to a backing material if not already provided, such as a sanded down chunk of plywood with the krylon touch  I rarely use the split rails so I prefer no split, and in a pinch I have it worked out to 2 bb's and 4 possible rails anyway http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1268626170/0
« Last Edit: June 26, 2010, 09:14:52 pm by Osgeld »
Logged
North Yorkshire, UK
Offline
Faraday Member
« Reply #24 on: June 27, 2010, 05:02:31 am » |
I sure hope your workbench has grown since then... I am planning a massive one still - project for next year. My current space is about twice the size of that at least and it's nowhere near large enough.  Mowcius
Logged
SE USA
Offline
Faraday Member
@ssh0le
« Reply #25 on: June 27, 2010, 12:43:07 pm » |
I sure hope your workbench has grown since then... no just the amount of crap on it has
Logged
