Topic: who can blink LED  like sine wave ??? (Read 10691 times) previous topic - next topic
875584189
875584189
Jeff K
I am going to assume you don't actually mean you want to blink an LED but make it's intensity (brightness) change following the curve of a sine wave.
I don't have any code examples.  But you should probably do some research on just generating sine waves first.  It seems some people use lookup tables that have been pre generated.  Essentially you would find the equation for your sine wave. Select 255 (or other depending on resolution) evenly divided points across the sine wave.  Get values for these points (should be 0 - 255)... . then store these in the memory of the Arduino.
You would then just loop through these values and apply them to the  output the LED is on.
Jeff K - JKDevices.com - home of the MegaMini
raron
Or just use the sin() function..
Code: [Select]
 float something = millis()/1000.0;
 int value = 128.0 + 128 * sin( something * 2.0 * PI  );
 analogWrite(ledPin,value);
Where something is from 0 to 1 (ideally, or a multiple of), and is whatever you base the sin on. Note the 1000[glow].0[/glow], to make it a float calculation (since we need the decimals).
You might have to restrict the int value in the 0 - 255 range to prevent wrap to 0 instead of 256.
And you must use a PWM output pin for analogWrite to work.
875584189
875584189
raron , the led doesn't blink like sine wave
raron
#6
Jun 20, 2010, 01:55 pm Last Edit: Jun 20, 2010, 02:01 pm by raron Reason: 1
Did you use a PWM output? It works for me.
I don't have a duemilanove, but it should'nt matter.
I forgot to say that the millis() / 1000.0 was for a 1000 ms (as in 1 second) period.
Groove
Don't forget to compensate for the eye's logarithmic respose, or you won't perceive a true sine brightnesss curve.
Per Arduino ad Astra
875584189
raron, no I haven't connected to pwm,how can I connect it and I'm a beginner
raron
The Duemilanove:
http://arduino.cc/en/Main/ArduinoBoardDuemilanove
As you can see, not all the pins can provide a PWM output. Only pins 3, 5, 6, 9, 10 and  11. You must use one of these for analogWrite() to work.
That is for a hardware PWM (built-in the arduino). Software PWM is certainly possible too, on any pin, but the program would be more complex and use more processor time. I thought I saw a software PWM library somewhere, but I can't find it at the moment.
Btw, PWM (Pulse Width Modulation) is really a trick, it's not an analogue signal. It's digital, but as the name implies, its pulsing and the width of these pulses are what varies. The frequency on the arduino is about 450-500 Hz, so you wont see any flicker is you connect it to a LED.
http://www.arduino.cc/en/Tutorial/PWM
Oh and you use a resistor in series with the LED I hope?
Groove:
Quote
True, but I think we can forgo that for now? :P
875584189
so  what is the complete code I can upload to the board??? and how can I connect it ??
raron
Well the only thing missing from the code above is basically the setup() routine, like this: http://arduino.cc/en/Reference/Setup
Modify as required (little exercise for you there ;) ). Then just follow it with the loop() function, as in any arduino sketch: http://arduino.cc/en/Tutorial/Sketch
As for how to connect the LED, do it like this: http://www.makingthings.com/documentation/how-to/connect-an-led-to-a-digital-output
Doesn't matterJust remember to use a PWM output.
875584189
int Pin = 3;
 pinMode(Pin, INPUT);
 float something = millis()/5000.0;
 analogWrite(Pin,value);
I got the code, so amazing , thx raron so much
xl97
just to comment..
raron-
awesome work !
SO many time do I see beginners talked down to.. or just put off with tech babel or random links with no help explaining what they are being linked to.
KUDOS man!
Delivery of good info..
links to help understand what was just explained to him..
example code
and even a quick 'homework' assignment for him to not be spoon fed as much.
A+ help!!!!!
875584189
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
