Topic: Can't burn bootloader: Wrong Signature (Read 499 times) previous topic - next topic
baustromverteiler
Hi there,
I unsuccessfully tried to burn a bootloader on a new atmega 168-20PU for my Diecimila the last days.
First I tried to burn the bootloader with a paralell programmer but it didn't work out so I got a USBtinyISP off ebay.
this is my terminal output:
Code: [Select]
max@maxl:~$ sudo avrdude -F -v -c usbtiny -p m168 -P usb
avrdude: Version 5.10, compiled on Mar 23 2010 at 15:03:00
        Copyright (c) 2007-2009 Joerg Wunsch
        System wide configuration file is "/etc/avrdude.conf"
        User configuration file is "/home/max/.avrduderc"
        User configuration file does not exist or is not a regular file, skipping
        Using Port                    : usb
        Using Programmer              : usbtiny
        AVR Part                      : ATMEGA168
        Chip Erase delay              : 9000 us
        PAGEL                         : PD7
        BS2                           : PC2
        RESET disposition             : dedicated
        RETRY pulse                   : SCK
        serial program mode           : yes
        parallel program mode         : yes
        Timeout                       : 200
        StabDelay                     : 100
        CmdexeDelay                   : 25
        SyncLoops                     : 32
        ByteDelay                     : 0
        PollIndex                     : 3
        PollValue                     : 0x53
        Memory Detail                 :
                                 Block Poll               Page                       Polled
          Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
          eeprom        65     5     4    0 no        512    4      0  3600  3600 0xff 0xff
          flash         65     6   128    0 yes     16384  128    128  4500  4500 0xff 0xff
          lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
          signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
        Programmer Type : USBtiny
        Description     : USBtiny simple USB programmer, http://www.ladyada.net/make/usbtinyisp/
avrdude: programmer operation not supported
avrdude: Using SCK period of 10 usec
avrdude: initialization failed, rc=-1
avrdude: AVR device initialized and ready to accept instructions
avrdude: Device signature = 0x000000
avrdude: Yikes!  Invalid device signature.
avrdude: Expected signature for ATMEGA168 is 1E 94 06
avrdude done.  Thank you.
I already read about every thread I could find on google but wasn't able to solve my problem.
ANY advise is appreciated, I'd really like to get my Diecimila going again.
regards, max
baustromverteiler
I just found a solution to my problem: I unsoldert the pin13 led and I was finally able to burn the bootloader flawlessly!
