Topic: [solved]ATmega168 fuse setting problem (Read 2261 times) previous topic - next topic
lorenzfx
Jul 12, 2010, 11:35 pm Last Edit: Jul 13, 2010, 12:33 am by lorenzfx Reason: 1
I'm having some problems while burning a bootloader to some ATmega168. I'm using an mysmartusb mkII and OS X.
first I'm unlocking
avrdude -v -pm168 -P /dev/cu.SLAB_USBtoUART -cavr910 -U lock:w:0x3F:m which seems to work. But then when trying to set the fuses
avrdude -pm168 -P /dev/cu.SLAB_USBtoUART -v -cavr910 -Uhfuse:w:0xdd:m -Ulfuse:w:0xff:m -e -Uefuse:w:0×00:m I get:
avrdude: Version 5.10, compiled on Jul 11 2010 at 18:20:24
        Copyright (c) 2007-2009 Joerg Wunsch
        System wide configuration file is "/opt/local/etc/avrdude.conf"
        User configuration file is "/Users/cg/.avrduderc"
        User configuration file does not exist or is not a regular file, skipping
        Using Port                    : /dev/cu.SLAB_USBtoUART
        Using Programmer              : avr910
        avr910_devcode (avrdude.conf) : 0x6
        AVR Part                      : ATMEGA168
        Chip Erase delay              : 9000 us
        PAGEL                         : PD7
        BS2                           : PC2
        RESET disposition             : dedicated
        RETRY pulse                   : SCK
        serial program mode           : yes
        parallel program mode         : yes
        Timeout                       : 200
        StabDelay                     : 100
        CmdexeDelay                   : 25
        SyncLoops                     : 32
        ByteDelay                     : 0
        PollIndex                     : 3
        PollValue                     : 0x53
        Memory Detail                 :
                                 Block Poll               Page                       Polled
          Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
          eeprom        65     5     4    0 no        512    4      0  3600  3600 0xff 0xff
          flash         65     6   128    0 yes     16384  128    128  4500  4500 0xff 0xff
          lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
          signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
        Programmer Type : avr910
        Description     : Atmel Low Cost Serial Programmer
Found programmer: Id = "AVR ISP"; type = S
   Software Version = 2.5; Hardware Version = 2.0
Programmer supports auto addr increment.
Programmer supports buffered memory access with buffersize = 512 bytes.
Programmer supports the following devices:
   Device code: 0x01 = (unknown)
avrdude: avr910_devcode selected: 0x06
Reading | ################################################## | 100% 0.05s
avrdude: Device signature = 0x1e9406
avrdude: safemode: lfuse reads as FF
avrdude: safemode: hfuse reads as DD
avrdude: safemode: efuse reads as 1
avrdude: erasing chip
avrdude: reading input file "0xdd"
avrdude: writing hfuse (1 bytes):
Writing | ################################################## | 100% 0.01s
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xdd:
avrdude: load data hfuse data from input file 0xdd:
avrdude: input file 0xdd contains 1 bytes
avrdude: reading on-chip hfuse data:
Reading | ################################################## | 100% 0.01s
avrdude: verifying ...
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0xff"
avrdude: writing lfuse (1 bytes):
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xff:
avrdude: load data lfuse data from input file 0xff:
avrdude: input file 0xff contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: 1 bytes of lfuse verified
avrdude: reading input file "0×00"
avrdude: invalid byte value (0×00) specified for immediate mode
avrdude: write to file '0×00' failed
avrdude: safemode: Fuses OK
avrdude done.  Thank you.
I can then flash the bootloader without problems but only upload an arduino sketch once, since it seems to overwrite the bootloader (might be connected to the invalid extended fuse settings?)
I'd be grateful for any help.
thanks
madworm
#1
Jul 13, 2010, 12:26 am Last Edit: Jul 13, 2010, 12:26 am by madworm Reason: 1
a) what is this: 0[glow]×[/glow]00, the other fuses have a real 'x' instead!
b) you forgot to lock the bootloader, therefore it gets overwritten.
lorenzfx
#2
Jul 13, 2010, 12:36 am Last Edit: Jul 13, 2010, 01:07 am by lorenzfx Reason: 1
ok, I'm an idiot. With a real 0x00 this works perfectly. I don't know how I got that strange x in there. Thanks!
