I'm having some problems while burning a bootloader to some ATmega168. I'm using an mysmartusb mkII and OS X.
first I'm unlocking
avrdude -v -pm168 -P /dev/cu.SLAB_USBtoUART -cavr910 -U lock:w:0x3F:m
which seems to work. But then when trying to set the fuses
avrdude -pm168 -P /dev/cu.SLAB_USBtoUART -v -cavr910 -Uhfuse:w:0xdd:m -Ulfuse:w:0xff:m -e -Uefuse:w:0×00:m
I get:
avrdude: Version 5.10, compiled on Jul 11 2010 at 18:20:24
    Copyright (c) 2007-2009 Joerg Wunsch
    System wide configuration file is "/opt/local/etc/avrdude.conf"
    User configuration file is "/Users/cg/.avrduderc"
    User configuration file does not exist or is not a regular file, skipping
    Using Port           : /dev/cu.SLAB_USBtoUART
    Using Programmer        : avr910
    avr910_devcode (avrdude.conf) : 0x6
    AVR Part            : ATMEGA168
    Chip Erase delay        : 9000 us
    PAGEL             : PD7
    BS2              : PC2
    RESET disposition       : dedicated
    RETRY pulse          : SCK
    serial program mode      : yes
    parallel program mode     : yes
    Timeout            : 200
    StabDelay           : 100
    CmdexeDelay          : 25
    SyncLoops           : 32
    ByteDelay           : 0
    PollIndex           : 3
    PollValue           : 0x53
    Memory Detail         :
                 Block Poll        Page            Polled
     Memory Type Mode Delay Size  Indx Paged  Size  Size #Pages MinW  MaxW  ReadBack
     eeprom     65   5   4   0 no     512   4    0  3600  3600 0xff 0xff
     flash     65   6  128   0 yes   16384  128   128  4500  4500 0xff 0xff
     lfuse      0   0   0   0 no      1   0    0  4500  4500 0x00 0x00
     hfuse      0   0   0   0 no      1   0    0  4500  4500 0x00 0x00
     efuse      0   0   0   0 no      1   0    0  4500  4500 0x00 0x00
     lock      0   0   0   0 no      1   0    0  4500  4500 0x00 0x00
     calibration   0   0   0   0 no      1   0    0   0   0 0x00 0x00
     signature    0   0   0   0 no      3   0    0   0   0 0x00 0x00
    Programmer Type : avr910
    Description   : Atmel Low Cost Serial Programmer
Found programmer: Id = "AVR ISP"; type = S
  Software Version = 2.5; Hardware Version = 2.0
Programmer supports auto addr increment.
Programmer supports buffered memory access with buffersize = 512 bytes.
Programmer supports the following devices:
  Device code: 0x01 = (unknown)
avrdude: avr910_devcode selected: 0x06
Reading | ################################################## | 100% 0.05s
avrdude: Device signature = 0x1e9406
avrdude: safemode: lfuse reads as FF
avrdude: safemode: hfuse reads as DD
avrdude: safemode: efuse reads as 1
avrdude: erasing chip
avrdude: reading input file "0xdd"
avrdude: writing hfuse (1 bytes):
Writing | ################################################## | 100% 0.01s
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xdd:
avrdude: load data hfuse data from input file 0xdd:
avrdude: input file 0xdd contains 1 bytes
avrdude: reading on-chip hfuse data:
Reading | ################################################## | 100% 0.01s
avrdude: verifying ...
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0xff"
avrdude: writing lfuse (1 bytes):
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xff:
avrdude: load data lfuse data from input file 0xff:
avrdude: input file 0xff contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: 1 bytes of lfuse verified
avrdude: reading input file "0×00"
avrdude: invalid byte value (0×00) specified for immediate mode
avrdude: write to file '0×00' failed
avrdude: safemode: Fuses OK
avrdude done. Â Thank you.
I can then flash the bootloader without problems but only upload an arduino sketch once, since it seems to overwrite the bootloader (might be connected to the invalid extended fuse settings?)
I'd be grateful for any help.
thanks
