« on: November 22, 2007, 08:10:07 am » |
I got to Vienna a couple hours ago, unpacked the sculpture, plugged in to modify the program, and of course it isn't working. I'm using the same laptop, the same arduino, nothing was added, nothing was taken away. My code verifies ok, and the arduino runs the sketch I last loaded into it just fine.
The message I am getting is
avrdude: verification error, first mismatch at byte 0x0000 0x39 != 0x00
avrdude: verification error; content mismatch
I'm not finding anything of much use checking AVR Dude forums.
Any help? The opening is in a couple hours!!! Many thanks in advance
Forum Administrator
« Reply #1 on: November 22, 2007, 08:52:00 am » |
Very strange message
it's clearly an upload error... do you have something else plugged into the laptop that might be interfering...?
what arduino are u using? NG, diecimila? what version of the software?
I dont suppose you brought anpther arduino
you need to give us more details
massimo
« Reply #2 on: November 22, 2007, 09:26:43 am » |
Nothing else is plugged in. I'm using version 10 of the software. I'm using an older board with the ATMEGA8 and USB. Same FTDI drivers as before. Happens whether powered by external power or USB. This is one of those things where it worked fine last night (and had been for weeks), but not now. I do the upload process, it finds the board, and the USB LEDs blink, as usual, so I know it is finding the board and communicating with it. And my code compiles fine.
As far as another arduino goes, I brought a bare bones board along, but I had never tested it until now (in fact I just soldered it up here in the gallery) and I get different errors when I try to upload a program to it - I get a sync error with that board:
avrdude: stk500_getsync(): not in sync: resp=0x00 avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
« Last Edit: November 22, 2007, 09:31:29 am by CTP »
« Reply #3 on: November 22, 2007, 10:27:22 am » |
Okay - I worked out the trouble with the bare bones board and am starting my programming - <3 hours until the show opens...no sweat :-)
I still wonder what is going on with the other board, but the panic is at least abated for now.
Forum Administrator
Cambridge, MA
« Reply #4 on: November 22, 2007, 10:46:43 am » |
You should try setting upload.verbose to true and seeing the full output of the upload attempt.
Did you try uploading a simple sketch to the board? Just to make sure it's not an issue with running out of RAM or memory.
« Reply #5 on: November 28, 2007, 03:38:23 pm » |
<<<You should try setting upload.verbose to true and seeing the full output of the upload attempt. >>>
I will try that. I got home last night around 3AM and came into the office this morning - my body doesn't really know what time it is yet. As soon as I unpack I will set up the sculpture and try it.
I thought of uploading a tiny sketch to it, but then realized that it was currently running a sketch that if all else failed would at least animate the piece somewhat - and if I changed that and couldn't go back, and couldn't get the new board to work, that I would be 100% screwed. <<<Did you try uploading a simple sketch to the board?>>> Yea, the entire sketch for the piece is pretty simple as it is - around 2K is all in its current form.
I soldered together the other board in the gallery, hooked it up, and it worked all though the show so everything worked out in the end. I'll start hacking on the other board tonight or tomorrow.
« Last Edit: November 28, 2007, 03:41:03 pm by CTP »
Canada
Arduino & Freeduino rocks!
« Reply #6 on: December 01, 2007, 03:04:08 pm » |
The same exact issue just happened to me. I tried to upload the the first LED flash code from the tutorials, and I got a similar error (with a different address): avrdude: verification error, first mismatch at byte 0x0042 0x9d != 0xd0 avrdude: verification error; content mismatch I'm using a Freeduino with the ATMEGA168 chip and there are no wires plugged into any pins. It is being powered by the USB port. I set upload.verbose = true, and I received more data that I could not understand; I could not fit all of it due to the character limit set on this post: Reading | avrdude: Send: U [55] . [00] . [00] [20] avrdude: Recv: avrdude: Recv: avrdude: Send: t [74] . [00] . [80] F [46] [20] avrdude: Recv: avrdude: Recv: avrdude: Recv: #####avrdude: Send: U [55] @ [40] . [00] [20] avrdude: Recv: avrdude: Recv: avrdude: Send: t [74] . [00] . [80] F [46] [20] avrdude: Recv: avrdude: Recv: avrdude: Recv: ######avrdude: Send: U [55] . [80] . [00] [20] avrdude: Recv: avrdude: Recv: avrdude: Send: t [74] . [00] . [80] F [46] [20] avrdude: Recv: avrdude: Recv: avrdude: Recv: ######avrdude: Send: U [55] . [c0] . [00] [20] avrdude: Recv: avrdude: Recv: avrdude: Send: t [74] . [00] . [80] F [46] [20] avrdude: Recv: avrdude: Recv: avrdude: Recv: ######avrdude: Send: U [55] . [00] . [01] [20] avrdude: Recv: avrdude: Recv: avrdude: Send: t [74] . [00] . [80] F [46] [20] avrdude: Recv: avrdude: Recv: avrdude: Recv: #####avrdude: Send: U [55] @ [40] . [01] [20] avrdude: Recv: avrdude: Recv: avrdude: Send: t [74] . [00] . [80] F [46] [20] avrdude: Recv: avrdude: Recv: avrdude: Recv: ######avrdude: Send: U [55] . [80] . [01] [20] avrdude: Recv: avrdude: Recv: avrdude: Send: t [74] . [00] . [80] F [46] [20] avrdude: Recv: avrdude: Recv: avrdude: Recv: ######avrdude: Send: U [55] . [c0] . [01] [20] avrdude: Recv: avrdude: Recv: avrdude: Send: t [74] . [00] . [80] F [46] [20] avrdude: Recv: avrdude: Recv: avrdude: Recv: ######avrdude: Send: U [55] . [00] . [02] [20] avrdude: Recv: avrdude: Recv: avrdude: Send: t [74] . [00] X [58] F [46] [20] avrdude: Recv: avrdude: Recv: avrdude: Recv: #### | 100% 0.85s
avrdude: verifying ... avrdude: verification error, first mismatch at byte 0x0042 0x9d != 0xd0 avrdude: verification error; content mismatch avrdude: Send: Q [51] [20] avrdude: Recv: avrdude: Recv:
avrdude done. Thank you. I stored the full text online at http://www.box.net/shared/774c65cjnc
« Last Edit: December 01, 2007, 04:09:46 pm by Anthony »
Buy a breadboard; it's worth it!
Canada
« Reply #7 on: December 05, 2007, 05:19:08 pm » |
I ordered a Arduino Diecimila board as a replacement; it worked with the Arduino IDE, which shows that it's a problem with my Freeduino. I realized that I could also replace the ATMEGA168 chip for $5, and see if I can still use my Freeduino. I should get it in the mail somewhere around next week, so I let you all know if it works; I'm sure it will, since the chip is basically the heart of the board, and I doubt that it's a problem with the Freeduino board itself that would just instantly pop-up. The last thing I remember doing with my board is uploading code to operate an LED with a potentiometer, and I made a 9V battery adapter that works with the Arduino also. I also kept unplugging and replugging the battery in, but I don't think that would cause a "Verification Error" over time. Thank goodness that the ATMEGA168 chips are cheap.
USA
Freeduino rocks
« Reply #8 on: December 05, 2007, 09:01:50 pm » |
Anthony, what Freeduino board do you have? Is it the KIT based board or the assembled prerelease board?
Canada
« Reply #9 on: December 06, 2007, 08:32:34 am » |
Anthony, what Freeduino board do you have? Is it the KIT based board or the assembled prerelease board? Hello. It's an assembled Freeduino pre-release board; when I received it, it was the board alone with its own ATMEGA168, and it came with nothing else.
« Last Edit: December 06, 2007, 08:33:03 am by Anthony »
gedrop
« Reply #10 on: December 10, 2007, 04:31:42 pm » |
I have the same trouble as the first person posting in this thread..
The arduino i use is caled "Arduino Diecimila compatible USB board complete KIT with pre-soldered FT232BL" i got it from Ebay. The bootloader is probably 9.. and i was using editor version 10
It was working just fine until i uploaded this script <http://www.arduino.cc/en/Tutorial/StepperUnipolar> The stepper motor was connected while i was uploading.. but i think i connected it wrong.. because it did not start rotating.. After this i tryd a different connection. but still no luck..
Then i disconnected everything and tryd uploading the BLINK script.
I set "upload.verbose = true" and noticed the verification message was giving back only zeros
Then i was thinking the Atmega168 is probably burned out or something, but after some more fiddling around with the arduino.. i noticed the stepper motor script was still on the arduino. and working.. I just cant upload a new script to the arduino..
So what could be the problem?? Could the upload part of my arduino be broken (the USB to serial converter)? Or could it be something else..
Canada
« Reply #11 on: December 10, 2007, 05:40:45 pm » |
The ATMEGA168 chip I ordered arrived in the mail today. I replaced it with the one in the Freeduino, and it works just fine.
This proves that it's a problem with the microcontroller chip itself and not the board. However, I don't know how to actually fix the problem.
If you're willing to spend $5, you can order a new one to replace the one in your board. As of the verification error, I don't know what to do about that, so I'll just hold onto it until there's a way for me to deal with it.
gedrop
« Reply #12 on: December 10, 2007, 06:21:13 pm » |
i ordered a new ATMEGA168 now also.. hopefully it works when i replace it.. that would be great! maybe it helps to re-upload the bootloader.. would the Parallel Port Programmer also work for the arduino diecimila? http://www.arduino.cc/en/Hacking/ParallelProgrammerGreets Gijs
Norway
R-Doo-Inoo in the making :3
« Reply #13 on: December 10, 2007, 07:05:08 pm » |
I also ordered the "Arduino Diecimila compatible USB board complete KIT with pre-soldered FT232BL" from NKC on eBay.. I hope I don't have this problem while I'm messing with it :o do you think i should order some spare ATMEGA168 chips just in case? :-/ seeing as I am a total noob at Arduino, microcontrollers, and programming  not that i don't understand what its about
« Last Edit: December 11, 2007, 04:13:06 am by The_Bongmaster »
B-dui in creation.
USA
Freeduino rocks
« Reply #14 on: December 10, 2007, 08:30:29 pm » |
Anthony, what Freeduino board do you have? Is it the KIT based board or the assembled prerelease board? Hello. It's an assembled Freeduino pre-release board; when I received it, it was the board alone with its own ATMEGA168, and it came with nothing else. Were you able to solve the problem by replacing the atmega168? If not, then contact me to my email freeduino at nkcelectronics dot com.
