Loading...
Pages: 1 [2]   Go Down
Author Topic: Tools -> Serial Port greyed out on Linux  (Read 6950 times)
0 Members and 2 Guests are viewing this topic.
0
Online Online
Tesla Member
View Profile
because Tools > Serial Port is gray i can't see the selection.. with sudo power i can confirm serial port is /dev/ttyS0
tryng to upload without sudo power:
Code:
Binary sketch size: 902 bytes (of a 30720 byte maximum)
processing.app.SerialException: Serial port 'COM1' not found.  Did you select the right one from the Tools > Serial Port menu?
      at processing.app.Serial.<init>(Serial.java:153)
      at processing.app.Serial.<init>(Serial.java:76)
      at processing.app.debug.Uploader.flushSerialBuffer(Uploader.java:73)
      at processing.app.debug.AvrdudeUploader.uploadViaBootloader(AvrdudeUploader.java:83)
      at processing.app.debug.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:55)
      at processing.app.Sketch.upload(Sketch.java:1498)
      at processing.app.Sketch.exportApplet(Sketch.java:1465)
      at processing.app.Sketch.exportApplet(Sketch.java:1420)
      at processing.app.Editor$46.run(Editor.java:2219)
      at java.lang.Thread.run(Thread.java:619)
processing.app.debug.RunnerException: Serial port 'COM1' not found.  Did you select the right one from the Tools > Serial Port menu?
      at processing.app.debug.Uploader.flushSerialBuffer(Uploader.java:93)
/dev/ttyS0 with sudo power:
Code:
seems a permission problem.. maybe ubuntu is more "user friendly" with USB/serial permission. I also don't need to use sudo power to mount devices, maybe it's a driver restriction, i don't know.
« Last Edit: July 25, 2010, 06:21:49 pm by lestofante » Logged
my Arduino code: https://github.com/lestofante/arduinoSketch
sei nuovo? non sai da dove partire? leggi qui: http://playground.arduino.cc/Italiano/Newbie
Lancashire, UK
Offline Offline
Edison Member
View Profile
WWW
Part of the problem (and part of its appeal on the other side of the coin) is that there are hundreds of distros of Linux.  Many linux gurus scoff at Ubuntu because its popular (just as many microcontroller experts scoff at Arduino because its popular).  Its popular because it's pretty easy to live with (I've played with quite a few of the major distros and Ubuntu is probably the easiest).  Popular means its well supported, which tends to help its popularity.   You'll get a lot more joy on forums if you are using something (no insult intended here) thats a little less obscure.
« Last Edit: July 26, 2010, 07:53:01 am by stephen_t » Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I've changed the user groups, but still not working.
In console is showing the code:
Code:
check_group_uucp(): error testing lock file creation Error details:Permission deniedcheck_lock_status: No permission to create lock file.
please see: How can I use Lock Files with rxtx? in INSTALL
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I just opened terminal, logged in as root (su) and then just run ./arduino ... it's working great
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hello,
better late than never!
"Others" need write access to /var/lock
via (example)
chmod o+rwx /var/lock
The user starting the IDE has to a member of the following groups:
dialout
uucp
(OpenSuSE 11.3)
Best regards
caerdu
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
