Loading...
Pages: [1]   Go Down
Author Topic: power supply  (Read 258 times)
Katy, TX, USA
Offline Offline
Newbie
[ch937]
View Profile
I have a 12vdc p/s that I intend to use to power my arduino along with some other things (relays, transistors, etc.). It is 2200mA output. Do I need to limit this in some way to prevent damage to my arduino? Also, when using the barrell connector, which is +, inside or outside?
Logged
UK
Offline Offline
Faraday Member
Gorm deficient
View Profile
No, you don't need to limit it in any way - it draws what it draws.
You'll need a meter to tell which way round the plug is connected.
Logged
Per Arduino ad Astra
SW Scotland
Offline Offline
Edison Member
Arduino rocks
View Profile
Maplin do a very neat polarity box which via a couple of LEDs shows the polarity of flying lead wall-warts.
jack
Logged
Manchester (England England)
Online Online
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
On the arduino the inside is the + so if your power supply is different you will have to make a swap over lead.
Logged
Pages: [1]   Go Up
Print
Jump to:
