Topic: if (gsmAccess.begin(PINNUMBER) == GSM_READY) not working (Read 2202 times) previous topic - next topic
waynedaly123
Nov 17, 2014, 07:59 pm Last Edit: Nov 17, 2014, 08:00 pm by waynedaly123
The serial console prints:   Serial.println("SMS Messages Receiver");
But it never prints anything after it so its not getting past:
I have tried the sim supplied by arduino, and the recoption is high when on my phone.
I also tried my own sim card, I am in Ireland.
Any idea how to get this thing working? Thanks!
I have also tried my pin number and blank.
Code: [Select]
  // initialize serial communications and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // connection state
  boolean notConnected = true;
  // Start GSM connection
  while (notConnected)
      notConnected = false;
      Serial.println("Not connected");
  Serial.println("GSM initialized");
  Serial.println("Waiting for messages");
waynedaly123
Here is an update, the debug information that is happening is:
Code: [Select]
AT%13%
0 25>AT%13%%13%%10%OK%13%%10%%13%%10%+CPIN: READY%13%%10%
AT+CGREG?%13%
25 70>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%%13%%10%Call Ready%13%%10%
AT+CGREG?%13%
70 101>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
101 4>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
4 35>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
35 66>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
66 97>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
97 0>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
0 31>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
31 62>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
62 93>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
93 124>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
124 27>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
27 58>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
58 89>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
AT+CGREG?%13%
89 120>AT+CGREG?%13%%13%%10%+CGREG: 0,2%13%%10%%13%%10%OK%13%%10%
itsanandyadav
Dear,
Did you find the solution? I am stuck here.
jdboud
I'm also in the same situation. I would also like to know if you've found a solution or if someone has one. Thanks
A lot is discussed on this thread but i'm still stuck at the looping' searching for network'.
Arduino UNO is on 12V + GSM arduino shield V2
SIM card and PIN are active
Network provider Koodo (Canada)
**The problem is most probably that my card is 3G (Bell and Telus) and not 2G (Rogers in Canada)
RonaldJKirby
it appears to me that your gsm is not connecting to the network
you should check if it is the right type for your network  and also check frequencies it works on
