Topic: recording conversation with Arduino Yun  (Read 305 times) previous topic - next topic
jesslee5377
Good day,
I need to record conversation for a project.  I have an arduino yun, a base shield, a sound sensor and a loudness sensor as well as a SD for memory.
I am new to the whole coding thing so basically i have no idea how to make this work!
Essentially i want the device to store the conversations. Ideally the data from it needs to be able to tell me the different between the two people talking, and indicate when the conversation changes.
Ideally, the data i get from it needs to be time stamped in a CSV format.
Is this possible, and if so, how would i go about it?
Any advice appreciated.
Thank you,
Jess
Angelo9999
I think it is possible but there are a lot of things to do in your project, they go from interfacing sensors to manipulating data and files ( not easy because you want to manipulate audio ).
If you are new to all this, it is better to make some research on what you need, how you want to do it and what you need to learn.
Then when you have specific questions you will find a lot of help here.
https://github.com/sngl
