Topic: Win7 Arduino Driver Nightmare (Read 6163 times) previous topic - next topic
HeneryH
I've been having nothing but troubles here.
I first did a basic load of the arduino app and asked it to load the drivers.  I got a usb device not recognized but moved past the error.
On using the app for the first time, I didn't see my port connected.
Looking at the drivers in my devices showed an error so I tried to manually install the driver from the device manager. I get the following error when using the "have disk" option and pointing to the drivers/arduino.ini file
  • The folder you specified doesn't contain a compatible software driver for your device. If the folder contains a driver, make sure it is designed to work with Windows for x64 based systems.
Further googling shows there are problems with the certification of the disk and gives a workaround.  I noted that the first time I tried this, the device showed up twice in the device manager; once under usb devices - unknown and a second time under other - unknown.  This is important for later.  The workaround says to manually update the driver for the other-unknown and say 'choose from loaded drivers or something' and click the "ports" driver type and select the arduino.
I tried this and it kind of tried to work but had some failures.
Here is where I am now screwed...  Retrying this, I only see the unknown device in the usb-unknown section.  NOT in the other-unknown.  Manually trying to install it via the workaround doesn't let me change to a 'port' type install.  It seems the device is permanently set to a 'usb type' and the arduino company doesn't show in the list.
I' totally stuck.
Anyone have ideas to get past this?
larryd
Have you clicked on the USB device in the device manager and selecting updated the driver, pointing to -   C:\Program Files (x86)\arduino-1.0.6\drivers  - (or your folder on your computer)  then press enter?
No technical PMs.
The last thing you did is where you should start looking.
HeneryH
I see the "which board are you using?" question is a common first follow-up post so I can update my problem with:
I am using an Arduino Uno.  I am using Windows 7 x64.
HeneryH
Yes, this is what gives the error saying it isn't compatible with Win7x64.
HeneryH
here is the error when manually loading the driver
larryd
This is what I have in the folder:
No technical PMs.
HeneryH
I have those exact files too.
But when I try to update the driver, it tells me that it isn't compatible with Win7x64.  A lot of internet research says that the reason is that it isn't a signed driver.
Are you on Win7x64 and have successfully loaded that driver with a standard windows driver update?
larryd
The procedure you went through I did yesterday and things worked on my 64 windows 7.
Maybe try to re install everything.
No technical PMs.
HeneryH
Which step was successful, did you have to use the worakround of selecting the other-unknown and searching the list for Arduino?  Or was a simple install from file enough?
The problem is that I CANT just do it again.  The unknown device is now only listed in the USB section, not the other section.
Now when I say "select driver from list" it only shows me USB items.  That step in the workaround that says "select type port" is not available to me.
HeneryH
Here are the exact screen shots:
When I try to load this driver in the device manager by saying "I Have Disk" and browsing to the folder, I get the noted error:
I then saw instructions about saying something like "select it from the list" rather than "I have disk".  My first try had the device listed under both "other-unknown" and "usb-unknown" and it kind of sort of worked but not quite.
Now I only have it in usb-unknown and this is what happens when I try to select from list:
Note in this last image, because it thinks it is a usb type, it does not allow me to select "port" type which is where the arduino is listed.
ChilliTronix
Can you post a link to the board you are using? Sometimes people have clones and sometimes copies, but seeing the link to the board you actually bought can either answer questions or clear things up.
HeneryH
http://lowpowerlab.com/moteino/#whatisit
ChilliTronix
Right... So you don't have an Arduino driver problem... You have a USB to serial converter driver problem!
What sort of USB to serial converter have you got, and can you post a link to that please?
ChilliTronix
Unless of course you got the one with an FTDI chip on it, in which case... have you tried the latest drivers from the FTDI website?
HeneryH
#14
Nov 24, 2014, 11:22 pm Last Edit: Nov 24, 2014, 11:37 pm by HeneryH
Yes, it has the FT232RL FTDI chip on it http://lowpowerlab.com/moteino/#whatisitUSB .  Yes, I downloaded the FTDI VCOM driver from their web site.
Figured this site would go dark on me as soon as I mentioned I didn't buy a board from here.
