Topic: (solved) Duemilanove input voltage (Read 1 time) previous topic - next topic
madc
Nov 11, 2010, 01:21 pm Last Edit: Nov 11, 2010, 03:36 pm by madc Reason: 1
Hey folks,
I am running on Duemilanove and simply want to get a digital signal from some pins (D4-D7), but as soon as i attach a wire to any of the pins and send the value of digitalRead() via serial port, i get 20 times high, 20 times low, 20 times high ond so on. Even if the wire goes nowhere.
Is there something like a pull-down resistor or am i missing something else? Or is this a normal behavior in some way?
thanks.
/m
AWOL
#1
Nov 11, 2010, 01:40 pm Last Edit: Nov 11, 2010, 01:41 pm by AWOL Reason: 1
Floating inputs comes up about once a week here.
Quote
What are you going to be connecting them to?
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
madc
#2
Nov 11, 2010, 01:49 pm Last Edit: Nov 11, 2010, 01:56 pm by madc Reason: 1
Some kind of pushbutton ( http://www.sparkfun.com/commerce/product_info.php?products_id=9182 ) which should pull the pin on high if pressed.
But is this a normal behavior for the board to chage the state?
Osgeld
pins set as input are in a high impedance state, it does not take much of anything to make them switch including just random electrical noise
yes its normal, this is why you must use pull up or pull down resistors
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
madc
Ok, thanks solving this!
I searched a lot, but for some reason, i missed the pull-down resistor as a searchword. So i wasnt sure, if i maybe killted by arduino or something.
/m
Grumpy_Mike
madc
I just read over this one: http://www.ladyada.net/learn/arduino/lesson5.html
