Topic: We've figured it out. Problem solved!! (Read 10469 times) previous topic - next topic
AKSoapy29
Sorry, but I don't get what your drawning means.
Andrew K.
CrossRoads
How were you able to wire up the arduino/shield/LED/buttons/resisters in your picture?
You must have been following some kind of schematic/layout.
Seperately from that,
Post the sketch  you want to run.
AKSoapy29
I'm not following anything. I just made a diagram to help you with this. It's basically this:
Andrew K.
AKSoapy29
Andrew K.
AKSoapy29
#19
Dec 26, 2010, 10:32 pm Last Edit: Dec 26, 2010, 10:35 pm by Soapy29 Reason: 1
Refresh, or it's just you. Here's the link: http://www.vexforum.com/gallery/showimage.php?i=4873
Andrew K.
CrossRoads
Okay, you have the right idea for the buttons, just need to change the wiring a little.
The way you have it drawn, the button push is not able to change from hi to low.
Change it like this.
The resisters will pull pins 2,3,4 low, and when a button is pushed it will connect to 5V and can be read in as a high.
AKSoapy29
So just change Ground and 5V in my drawing?
Andrew K.
AKSoapy29
Wait, nevermind. Is there something I have to change in my programming?
Andrew K.
CrossRoads
Changing 5V on the buttons to GND would work. If you have the D2,D3,D4 inputs set with the internals pullups enabled:
pinMode (D2, INPUT);
digitalWrite (D2, HIGH);  // enables internal pullup
then when the button is pressed the input would read as Low, and High the rest of the time.
You wouldn't need the resistors with the buttons at all.
AKSoapy29
So the arrows on the switch goto what?
Andrew K.
AKSoapy29
#25
Dec 26, 2010, 11:15 pm Last Edit: Dec 26, 2010, 11:17 pm by Soapy29 Reason: 1
Here's what I have now:
And here's my code:
 Button
Turns on and off a light emitting diode(LED) connected to digital
pin 13, when pressing a pushbutton attached to pin 2.
The circuit:
* LED attached from pin 13 to ground
* pushbutton attached to pin 2 from +5V
* 10K resistor attached to pin 2 from ground
* Note: on most Arduinos there is already an LED on the board
attached to pin 13.
created 2005
by DojoDave <http://www.0j0.org>
modified 28 Oct 2010
by Tom Igoe
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/Button
// constants won't change. They're used here to
// set pin numbers:
const int buttonPin1 = 2;     // the number of the pushbutton pin
const int ledPin1 =  8;      // the number of the LED pin
const int buttonPin2 = 3;     // the number of the pushbutton pin
const int ledPin2 =  9;      // the number of the LED pin
const int buttonPin3 = 4;     // the number of the pushbutton pin
const int ledPin3 =  10;      // the number of the LED pin
// variables will change:
int buttonState1 = 0;         // variable for reading the pushbutton status
int buttonState2 = 0;         // variable for reading the pushbutton status
int buttonState3 = 0;         // variable for reading the pushbutton status
 // initialize the LED pin as an output:
 pinMode(ledPin1, OUTPUT);
 // initialize the pushbutton pin as an input:
 pinMode(buttonPin1, INPUT);
 pinMode(ledPin2, OUTPUT);
 pinMode(buttonPin2, INPUT);
 pinMode(ledPin3, OUTPUT);
 pinMode(buttonPin3, INPUT);
void loop(){
 // read the state of the pushbutton value:
 buttonState1 = digitalRead(buttonPin1);
 buttonState2 = digitalRead(buttonPin2);
 buttonState3 = digitalRead(buttonPin3);
 // check if the pushbutton is pressed.
 // if it is, the buttonState is HIGH:
 if (buttonState1 == LOW) {
   // turn LED on:
   digitalWrite(ledPin1, HIGH);
 else {
   // turn LED off:
   digitalWrite(ledPin1, LOW);
   if (buttonState2 == LOW) {
   // turn LED on:
   digitalWrite(ledPin2, HIGH);
 else {
   // turn LED off:
   digitalWrite(ledPin2, LOW);
   if (buttonState3 == LOW) {
   // turn LED on:
   digitalWrite(ledPin3, HIGH);
 else {
   // turn LED off:
   digitalWrite(ledPin3, LOW);
Andrew K.
AWOL
#26
Dec 26, 2010, 11:19 pm Last Edit: Dec 26, 2010, 11:21 pm by AWOL Reason: 1
And posted correctly: (comments are a bit dodgy though)
Code: [Select]
Button
The circuit:
attached to pin 13.
created 2005
by DojoDave <http://www.0j0.org>;
by Tom Igoe
// set pin numbers:
void loop(){
  // turn LED on:
else {
  // turn LED off:
  // turn LED on:
else {
  // turn LED off:
  // turn LED on:
else {
  // turn LED off:
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
CrossRoads
One contact on the switch goes to ground, one contact goes to an arduino pin.
The switch may have pins, am pretty sure the pins are connected in pairs.
Scroll down to where it says 'pcb layout' on this datasheet as an example.
http://www.sparkfun.com/datasheets/Components/Buttons/KSA_KSLMKII_4feb.pdf
AKSoapy29
Ok, I have them setup like you said. I posted my code above, and the led doesn't light. :(
Andrew K.
CrossRoads
#29
Dec 26, 2010, 11:25 pm Last Edit: Dec 26, 2010, 11:25 pm by CrossRoads Reason: 1
Just add this to the input definitions to ensure the pin is high when the button is not pressed.
[glow]digitalWrite(buttonPin1, HIGH);  //enable internal pullup resister[/glow]
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
