Forum Administrator
Cambridge, MA
Offline
Faraday Member
« Reply #75 on: March 19, 2008, 11:21:13 am » |
thanks - is there a clear description of how to burn a bootloader if I'm seeing errors while attempting to do it from within Arduino? I'm not sure it would help. With upload.verbose set to true, do you get more information when you try to burn the bootloader? It should also show you the command line being used, if you wanted to try it. What will I possibly gain from buying a USB device - for example the AVRISP mkII - over troubleshooting it with my current toolset which includes a home-brew parallel device, which seems to work fine for Atmega8 Arduinos?
The AVRISP mkII or the USBtinyISP seem to be more reliable than parallel programmers, but if the latter work, then there's no real advantage of buying another programmer. And one other thing, is there any clear guidance on issues like the length of arrays for the atmega168, chip memory size etc?
There's some information at http://www.arduino.cc/en/Tutorial/Memory, but it could probably use work. Any suggestions?
Logged
0
Offline
Newbie
I love YaBB 1G - SP1!
« Reply #76 on: March 26, 2008, 07:22:30 am » |
hi, I'm back now using the AVRISP mkII. So, to recap - my Arduino Diecimilia is an island - I caused a problem I think by uploading a programme with to many variable bytes which taxed the SRAM, see http://www.arduino.cc/en/Tutorial/Memory. So now, when I upload from Arduino I repeatedly see: "avrdude: stk500_recv(): programmer is not responding" Now, I'm using the MAKEFILE in /Applications/arduino-0010/hardware/bootloaders/atmega168/ to put anew bootloader on the board. Here's an output from OS X terminal: [CRD:bootloader-usb] tobie% cd /Applications/arduino-0010/hardware/bootloaders/atmega168/ [CRD:atmega168] tobie% make TARGET=diecimila isp avrdude -c stk500v2 -p m168 -P usb -b 115200 -e -u -U lock:w:0x3f:m -U efuse:w:0x00:m -U hfuse:w:0xdd:m -U lfuse:w:0xff:m
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9406 avrdude: erasing chip avrdude: reading input file "0x3f" avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 1 bytes of lock written avrdude: verifying lock memory against 0x3f: avrdude: load data lock data from input file 0x3f: avrdude: input file 0x3f contains 1 bytes avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.00s
avrdude: verifying ... avrdude: 1 bytes of lock verified avrdude: reading input file "0x00" avrdude: writing efuse (1 bytes):
avrdude: 1 bytes of efuse written avrdude: verifying efuse memory against 0x00: avrdude: load data efuse data from input file 0x00: avrdude: input file 0x00 contains 1 bytes avrdude: reading on-chip efuse data:
avrdude: verifying ... avrdude: 1 bytes of efuse verified avrdude: reading input file "0xdd" avrdude: writing hfuse (1 bytes):
Writing | ################################################## | 100% 0.02s
avrdude: 1 bytes of hfuse written avrdude: verifying hfuse memory against 0xdd: avrdude: load data hfuse data from input file 0xdd: avrdude: input file 0xdd contains 1 bytes avrdude: reading on-chip hfuse data:
avrdude: verifying ... avrdude: 1 bytes of hfuse verified avrdude: reading input file "0xff" avrdude: writing lfuse (1 bytes):
avrdude: 1 bytes of lfuse written avrdude: verifying lfuse memory against 0xff: avrdude: load data lfuse data from input file 0xff: avrdude: input file 0xff contains 1 bytes avrdude: reading on-chip lfuse data:
avrdude: verifying ... avrdude: 1 bytes of lfuse verified
avrdude done. Thank you.
avrdude -c stk500v2 -p m168 -P usb -b 115200 -U flash:w:ATmegaBOOT_168_diecimila.hex -U lock:w:0x0f:m
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e9406 avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed To disable this feature, specify the -D option. avrdude: erasing chip avrdude: reading input file "ATmegaBOOT_168_diecimila.hex" avrdude: input file ATmegaBOOT_168_diecimila.hex auto detected as Intel Hex avrdude: writing flash (16154 bytes):
Writing | ################################################## | 100% 0.87s
avrdude: 16154 bytes of flash written avrdude: verifying flash memory against ATmegaBOOT_168_diecimila.hex: avrdude: load data flash data from input file ATmegaBOOT_168_diecimila.hex: avrdude: input file ATmegaBOOT_168_diecimila.hex auto detected as Intel Hex avrdude: input file ATmegaBOOT_168_diecimila.hex contains 16154 bytes avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 7.58s
avrdude: verifying ... avrdude: 16154 bytes of flash verified avrdude: reading input file "0x0f" avrdude: writing lock (1 bytes):
avrdude: 1 bytes of lock written avrdude: verifying lock memory against 0x0f: avrdude: load data lock data from input file 0x0f: avrdude: input file 0x0f contains 1 bytes avrdude: reading on-chip lock data:
avrdude: safemode: Fuses OK
[CRD:atmega168] tobie% All looks well I think? But on the board, I'm seeing a rapidly flashing LED labelled L - as before. Then, when I try to load a programme, the familiar error in the debug pane: ... avrdude: Send: 0 [30] [20] avrdude: Send: 0 [30] [20] avrdude: Send: 0 [30] [20] avrdude: ser_recv(): programmer is not responding avrdude: stk500_recv(): programmer is not responding avrdude: Send: Q [51] [20] avrdude: ser_recv(): programmer is not responding avrdude: stk500_recv(): programmer is not responding Any ideas what I can try next?
Logged
Forum Administrator
Cambridge, MA
Offline
Faraday Member
« Reply #77 on: March 26, 2008, 01:21:16 pm » |
It sounds like the USB communication isn't working - maybe the FTDI chip is dead, or the cable is lose, or something is preventing you from reading from the virtual serial port. Maybe try a different computer (now that you should have a clean bootloader) or a putting the chip into a different board? Or, if you have a usb-to-serial converter, you could try connecting it to pins 0 and 1 and uploading that way. Or you can burn your sketch using the AVR-ISP mkII instead of over the USB connection (this will be possible from the IDE in Arduino 0011; for now you'd need to use the command line).
Logged
0
Offline
Newbie
« Reply #78 on: March 27, 2008, 07:05:37 am » |
[glow]Or you can burn your sketch using the AVR-ISP mkII instead of over the USB connection (this will be possible from the IDE in Arduino 0011; for now you'd need to use the command line).[/glow] Thanks - I'm doing this all now using the AVR-ISP mkII. First I upload the bootloader using AVR-ISP mkII with these commands, these are adapted from the makefile in "/Applications/arduino-0010/hardware/bootloaders/atmega168/Makefile" # Erase chip write lock and fuses avrdude -p m168 -b 115200 -P usb -c avrispmkII -e -U lock:w:0x3f:m -U hfuse:w:0xdf:m -U lfuse:w:0xff:m -U efuse:w:0x00:m # Upload bootloader code avrdude -p m168 -b 115200 -P usb -c avrispmkII -D -U flash:w:/Applications/arduino-0010/hardware/bootloaders/atmega168/ATmegaBOOT_168_diecimila.hex:i # Lock boot section avrdude -p m168 -b 115200 -P usb -c avrispmkII -U lock:w:0x0f:m avrdude reports success, and I see a rapidly flashing LED, about 10 HZ - is that expected behaviour? Then I'm trying to upload the compiled blink sketch, again using the AVR-ISP mkII, which should change the LED to 1 Hz. I've encluded the verbose output of this operation here: [CRD:hardware] tobie% avrdude -C /Applications/arduino-0010/hardware/tools/avr/etc/avrdude.conf -v -p m168 -c avrispmkII -P usb -b 19200 -D -U flash:w:/Applications/arduino-0010/examples/Digital/Blink/applet/Blink.hex:i
avrdude: Version 5.5, compiled on Mar 18 2008 at 20:25:02 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
System wide configuration file is "/Applications/arduino-0010/hardware/tools/avr/etc/avrdude.conf" User configuration file is "/Users/tobie/.avrduderc" User configuration file does not exist or is not a regular file, skipping
Using Port : usb Using Programmer : avrispmkII Overriding Baud Rate : 19200 avrdude: usbdev_open(): Found AVRISP mkII, serno: 0000B0010049 AVR Part : ATMEGA168 Chip Erase delay : 9000 us PAGEL : PD7 BS2 : PC2 RESET disposition : dedicated RETRY pulse : SCK serial program mode : yes parallel program mode : yes Timeout : 200 StabDelay : 100 CmdexeDelay : 25 SyncLoops : 32 ByteDelay : 0 PollIndex : 3 PollValue : 0x53 Memory Detail :
Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack ----------- ---- ----- ----- ---- ------ ------ ---- ------ ----- ----- --------- eeprom 65 5 4 0 no 512 4 0 3600 3600 0xff 0xff flash 65 6 128 0 yes 16384 128 128 4500 4500 0xff 0xff lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00 signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500V2 Description : Atmel AVR ISP mkII Programmer Model: AVRISP mkII Hardware Version: 1 Firmware Version: 1.01 Vtarget : 4.9 V SCK period : 10.37 us
avrdude: Device signature = 0x1e9406 avrdude: safemode: lfuse reads as C7 avrdude: safemode: hfuse reads as DF avrdude: safemode: efuse reads as 0 avrdude: reading input file "/Applications/arduino-0010/examples/Digital/Blink/applet/Blink.hex" avrdude: writing flash (1108 bytes):
Writing | ################################################## | 100% 0.53s
avrdude: 1108 bytes of flash written avrdude: verifying flash memory against /Applications/arduino-0010/examples/Digital/Blink/applet/Blink.hex: avrdude: load data flash data from input file /Applications/arduino-0010/examples/Digital/Blink/applet/Blink.hex: avrdude: input file /Applications/arduino-0010/examples/Digital/Blink/applet/Blink.hex contains 1108 bytes avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.52s
avrdude: verifying ... avrdude: 1108 bytes of flash verified
avrdude: safemode: lfuse reads as C7 avrdude: safemode: hfuse reads as DF avrdude: safemode: efuse reads as 0 avrdude: safemode: Fuses OK
[CRD:hardware] tobie% it appears that avrdude reports that all is well, yet I'm still seeing the 10 Hz blinking LED. Sorry if I'm missing something here, but I'm not sure where to go next.
Logged
0
Offline
Newbie
Arduino rocks
« Reply #79 on: April 07, 2008, 11:48:46 pm » |
Hi everyone, yet another "programmer is not responding" issue (but this thread's here for that right ?  So here it is: I built my own serial arduino (ATmega8) based on the schematics at http://www.arduino.cc/en/Main/StandaloneAssembly. The only difference is that i m using a 10Mhz crystal instead of a 16Mhz one because that s all I could find. I also put together a parallel programmer, and managed to burn the bootloader both using the arduino software (the version I use is 0011 alpha) and using uisp. So far so good. Now, upon reset or power on, the LED on pin 13 blinks rapidly for less than a second then nothing for about 10 seconds, and starts again (as if the reset button was pressed. Is that how it s supposed to be ?). However, uploading a sketch has proven more difficult. For that purpose, I hooked up two LEDs with 1K resistor to pin 2 and 3 of the serial connector. When I try uploading from Arduino, I get: Binary sketch size: 864 bytes (of a 7168 byte maximum) hardware/tools/avrdude -Chardware/tools/avrdude.conf -v -v -v -v -pm8 -cstk500v1 -P/dev/ttyS0 -b19200 -D -Uflash:w:/media/sda2/gilles/download/arduino/arduino-0011-IDE/examples/Digital/Blink/applet/Blink.hex:i
avrdude: Version 5.4-arduino, compiled on Oct 22 2007 at 13:15:12 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
System wide configuration file is "hardware/tools/avrdude.conf" User configuration file is "/home/gilles/.avrduderc" User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyS0 Using Programmer : stk500v1 Overriding Baud Rate : 19200 avrdude: Send: 0 [30] [20] avrdude: Send: 0 [30] [20] avrdude: Send: 0 [30] [20] avrdude: ser_recv(): programmer is not responding avrdude: stk500_recv(): programmer is not responding avrdude: Send: Q [51] [20] avrdude: ser_recv(): programmer is not responding avrdude: stk500_recv(): programmer is not responding
I tried also uisp: sudo uisp -v=4 -dpart=atmega8 -dprog=stk500 -dserial=/dev/ttyS0 -dspeed=19200 Transmit: { 0 [30] [20] } Programmer is not responding.
In both cases, the Rx LED (DB9 pin3) blinks briefly so I assume the board does receive the "0 " and "Q " commands. However, the Tx LED (DB9 pin 2) never blinks. Just to confirm the board still works, I unplgged the serial cable, plugged back the parallel programmer and burnt the bootloader. All went well. Going back to the serial cable, nothing changed. The board receives data (Rx LED flashing) but doesnt seem to transmit any. I did try all sorts of reset timings (before & after upload) without success. Looking at the ATmega8 bootloader code, I saw that the board replies to "u" with a couple signature bytes (0x14 0x1E 0x93 0x07 0x10). As a last test, I wrote a small program to send the character "u" over the serial port repeatedly and print any replies. here again, I tried different timings, but nothing was ever printed on the terminal. Help would be greatly appreciated. Thanks, Gilles
Logged
Forum Administrator
Cambridge, MA
Offline
Faraday Member
« Reply #80 on: April 08, 2008, 01:54:41 pm » |
djalis: you'll need to recompile the bootloader to work with the 10 MHz crystal. The .hex files that come with the Arduino environment (and are burned with the "Burn Bootloader" commands) assume a 16 MHz clock; if they run on a board with a different clock, the serial timing will be off. Alternatively, you can skip the bootloader and just upload your sketches with the programmer: http://www.arduino.cc/en/Hacking/Programmer
Logged
0
Offline
Newbie
Arduino rocks
« Reply #81 on: April 08, 2008, 07:06:06 pm » |
djalis: you'll need to recompile the bootloader to work with the 10 MHz crystal. The .hex files that come with the Arduino environment (and are burned with the "Burn Bootloader" commands) assume a 16 MHz clock; if they run on a board with a different clock, the serial timing will be off. Thanks for pointing this out. Now I assume the only change required to accomodate a 10Mhz clock instead of 16Mhz is to change the F_CPU macro in the Makefile from 16000000 to 10000000. This is what I did. I tried re-compiling the bootloader ("make") and it failed with: /usr/bin/avr-gcc -g -Wall -Os -mmcu=atmega8 -Datmega8 -DF_CPU=10000000 -DBAUD_RATE=19200 -I/usr/include -Wl,-Map,ATmegaBOOT.map,--section-start=.text=0x1c00 -o ATmegaBOOT.elf ATmegaBOOT.o /usr/lib/gcc/avr/4.2.1/../../../../avr/bin/ld: address 0x204e of ATmegaBOOT.elf section .text is not within region text make: *** [ATmegaBOOT.elf] Error 1 The linking seems to fail because of the text region not being at the right place as far as I understand. Any idea on how to fix this ? I gave this approach a shot. I closed Arduino, modified the "upload.using" line in preferences.txt from "bootloader" to "dapa" and restarted Arduino. The upload fails because Arduino uses this command: hardware/tools/avrdude -Chardware/tools/avrdude.conf -v -v -v -v -pm8 -cnull -Uflash:w:/media/sda2/gilles/download/arduino/arduino-0011-IDE/examples/Digital/Blink/applet/Blink.hex:i The "-cnull" argument is at fault here. From a terminal, I ran the same command with "-cnull" replaced with "-cdapa" and it worked like a charm, the sketch is uploaded and runs straight away. I tried setting "upload.using" to "Parallel Programmer" (as shown in hardware/programmers.txt) but no success, Arduino still uses "-cnull" instead of "-cdapa". I had a look at the Arduino code, and found out that "upload.using" should be set to "parallel". and now I can upload sketches from Arduino ! Gilles
Logged
Forum Administrator
Cambridge, MA
Offline
Faraday Member
« Reply #82 on: April 08, 2008, 08:34:30 pm » |
Awesome.
The error you're getting when compiling the bootloader is because the version of gcc you're using generates a .hex file that's slightly too big for the space we're giving it (1 KB). Older versions (like the one we used to compile) generated smaller .hex files that were just under 1 KB. You'd probably need to compile it with gcc 3 something.
(Also when I say size of the .hex file, I mean the amount of space it will take up on the chip; not the actual size of the file. To find out what it is, you can use "avr-size foo.hex").
Logged
0
Offline
Newbie
« Reply #83 on: April 10, 2008, 04:33:27 am » |
hi, I had a problem with 2 Arduino Diecimila - they became hostile islands, unreachable by USB or AVRISP.
I've just managed to burn bootloaders from Arduino 11 using the AVRISP II, and all is well, thanks for this latest update.
Logged
0
Offline
Newbie
Arduino rocks
« Reply #84 on: October 14, 2008, 03:26:59 pm » |
I have now experienced this problem too. I've been using the arduino for about 3 months reliably. Today I made a program using the serial library and after some messing about locked up my board.
(Don't know if this is relevant) I was using pure data and also the serial port logger on the arduino development software to monitor serial output.
Now led on pin 13 flashes about 2hz and I can't send new programs. I turned on verbose and got the same error as posted on this thread. Seems that it needs a new bootloader burnt.
I made a parallel programmer and tried to burn the atmega168 boot loader. Couldn't get it to work - though might be bad cable (very hacked), bad atmega168 defs (why isn't this as standard in the avrdude defs file in /etc), or bad parallel programmer defs.
So I've ordered a complete new board and AVR ISP500 programmer to burn the bootloader more reliably. I've got a deadline coming up!
Anything else I can try before my new stuff arives? Any idea why this happens?
Thanks,
Matthew
Logged
0
Offline
Newbie
Arduino rocks
« Reply #85 on: December 09, 2008, 07:50:22 am » |
hello again board. I'm back on the case with trying to fix my broken arduino. I got the olimex avr-isp500 programmer, which I've got working now (needs external power). I can read and write the fuses, and I've used this script to program the bootloader (thanks to Rob at http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl) #!/bin/sh -x
PART=ATmega168 PROG=stk500v2 PORT=/dev/ttyACM0
ARDUINODIR=/home/matthew/work/reprogArduino/arduino-0011 BOOTER=${ARDUINODIR}/hardware/bootloaders/atmega168/ATmegaBOOT_168_diecimila.hex AVRDIR=${ARDUINODIR}/hardware/tools AVRCONF=${AVRDIR}/avrdude.conf AVRBIN=${AVRDIR}
# unlock bootloader segment by erasing the chip $AVRBIN/avrdude -C $AVRCONF -e -p $PART -P $PORT -c $PROG
# set fuses # bootloader size of 512 words; from 0xE00-0xFFF # clock speed of 16 MHz, external quartz $AVRBIN/avrdude -C $AVRCONF -p $PART -P $PORT -c $PROG -U lfuse:w:0xdf:m -U hfuse:w:0xca:m
# upload bootloader $AVRBIN/avrdude -C $AVRCONF -p $PART -P $PORT -c $PROG -U flash:w:$BOOTER:i
# lock bootloader segment $AVRBIN/avrdude -C $AVRCONF -V -p $PART -P $PORT -c $PROG -U lock:w:0xcf:m
I see the fuses get set and the bootloader loaded and verified. This solves my constantly blinking LED issue. However, when I try and use the bootloader with Arduino, I get: avrdude: Version 5.4-arduino, compiled on Oct 22 2007 at 13:15:12 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
System wide configuration file is "hardware/tools/avrdude.conf" User configuration file is "/home/matthew/.avrduderc" User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyUSB0 Using Programmer : stk500v1 Overriding Baud Rate : 19200 avrdude: Send: 0 [30] [20] avrdude: Send: 0 [30] [20] avrdude: Send: 0 [30] [20] avrdude: ser_recv(): programmer is not responding avrdude: stk500_recv(): programmer is not responding avrdude: Send: Q [51] [20] avrdude: ser_recv(): programmer is not responding avrdude: stk500_recv(): programmer is not responding
I have tried my other ATmega168 in the board and that works OK. So it's either * the chip is bust or * I haven't managed to get the bootloader on there. * I've got the bootloader on but it won't respond When I plug the broken board in, I get the TX and RX lights flashing a few times and then led 13 stays on. It doesn't blink, so I'm guessing the bootloader isn't correct or hasn't been written properly. When I try and program the board with Arduino I get the RX light flash 3 times dimly. Then it times out and I get an error. Any clues where to go next? Thanks, Matthew
« Last Edit: December 09, 2008, 07:58:57 am by matthewvenn »
Logged
0
Offline
Newbie
Arduino rocks
« Reply #86 on: December 09, 2008, 08:26:08 am » |
**solved**
I found the makefile in the bootloader directory of arduino-11. By modifying it to work with the supplied avrdude I got it to do the burn as well.
I also recompiled the bootloader which ended up being a different size to the supplied diecimila.hex file.
After burning I got the flashing led13 and was successful with the arduino program! YES!!
Logged
0
Offline
Newbie
Arduino rocks
« Reply #87 on: April 07, 2009, 08:44:21 am » |
hi guys, I found other thing that might cause the same problem and get you the same avrdude error. I got a new decimila with atmega 328 and by mistake set the board in the ide as decimila with atmega 168. The board's behaviour was exactly as described in this thread, but fortunately I did not have to reflash the bootloader. Btw. I am using 19200 communication speed (I had to change it in preferences) and all works great!  dood321
Logged
London
Offline
Full Member
Yes, we can (solder)!
« Reply #88 on: May 06, 2009, 09:54:20 am » |
Just got a Duemilanove, can't upload anything, the IDE says:
Tried resetting before and after uploading. Also, I have installed the USB drivers. Any ideas? Should I send it back to the seller?
Mac OS X 10.4.11
Logged
London
Offline
Full Member
« Reply #89 on: May 06, 2009, 10:17:21 am » |
Also, should I change the baud rate? It's on 9600.
Logged
