Topic: Using an Arduino as an AVR ISP (Read 25699 times) previous topic - next topic
prysm
Hi all
I am bit confused. I am using my duemilanove m828p as a programmer. I uploaded the AVRISP example into it and I see the heartbeat.
I am trying to burn a bootloader into an atmega8 in a breadboard without an external clock. by following th instructions here
arduino.cc/en/Tutorial/ArduinoToBreadboard
trying the connection in avrdude
sudo avrdude -c avrisp -p m328p -b 57600 -P /dev/cuaU0
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.10s
avrdude: Device signature = 0x1e950f
avrdude: safemode: Fuses OK
avrdude done.  Thank you.
Why am I not seeing my target atemga8?
retrolefty
I've not used AVRDUDE in command line mode, so of limited help. However:
Quote
As you said you are burning to a meg8 processor why have you specified the m328p processor type in that command?
Lefty
prysm
i was trying to show that arduino isp was exposing my host avr not the target. Anyway i got it working by adding the crystal into the target.
liuzengqiang
Maybe because I bootloaded chips that have not been bootloaded I could only bootload with a crystal, although the tutorial says you can bootload without a crystal.
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
