Topic: Can't upload to Mega 2560 under Windows 2000 (Read 6504 times) previous topic - next topic
bossertj
I have installed the Arduino IDE 0021 on 2 Win2000 systems and on 2 WinXP systems.  I am able to compile and upload on the WinXP systems, but the Win2000 systems hang during upload.
I am wondering if this is an issue related to the ATMega 8U2 used for USB-to-serial communication and the Arduino_Mega_2560.inf driver provided for it.  The ATMega 8U2 is also used on the UNO board, so UNO users might have seen the same thing.
Anyone else seen this, or have a solution?
Foster
I have the same problem on Windows 2000, both the Mega 2560 and the Uno.  I'm running 0022.
I load the development application, select from the examples, Basic, Blink and compile it.
When I do the download I see the L led light, then the TX and RX lights flash for few seconds and I then get the following error:
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x41
avrdude: stk500_initialize(): (a) protocol error, expect=0x14, resp=0x42
avrdude: initialization failed, rc=-1
        Double check connections and try again, or use -F to override
        this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
I tested the boards and cable out on another (Win7) system and the two boards and the cable work there.
Thanks!
fdufnews
I think it is an issue with the driver and windows 2000. Windows 2000 is more restrictive on the way you access the hardware and the drivers should gain some privilege to execute.
Is there any windows 2000 guru here to confirm
mellis
Do the boards get assigned a COM port?  That is, do they show up in the Device Manager under Ports and in the Serial Port menu in the Arduino software?
What output do you get if you hold down the shift key while pressing the upload button?
Foster
For the Uno, I can see it on Port 2, this is the debug output
Binary sketch size: 16560 bytes (of a 32256 byte maximum)
C:\Documents and Settings\astro\My Documents\Ardunio\hardware/tools/avr/bin/avrdude -CC:\Documents and Settings\astro\My Documents\Ardunio\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P\\.\COM2 -b115200 -D -Uflash:w:C:\DOCUME~1\ASTRO~1\LOCALS~1\Temp\build239277540379715512.tmp\Webserv.cpp.hex:i
avrdude: Version 5.4-arduino, compiled on Oct 11 2007 at 19:12:32
        System wide configuration file is "C:\Documents and Settings\astro\My Documents\Ardunio\hardware/tools/avr/etc/avrdude.conf"
        Using Port            : \\.\COM2
        Using Programmer      : stk500v1
        Overriding Baud Rate  : 115200
avrdude: ser_open(): setting dtr
avrdude: Send: 0 [30]   [20]
avrdude: Recv:
avrdude: Recv:
        AVR Part              : ATMEGA328P
        Chip Erase delay      : 9000 us
        PAGEL                 : PD7
        BS2                   : PC2
        RESET disposition     : dedicated
        RETRY pulse           : SCK
        serial program mode   : yes
        parallel program mode : yes
        Timeout               : 200
        StabDelay             : 100
        CmdexeDelay           : 25
        SyncLoops             : 32
        ByteDelay             : 0
        PollIndex             : 3
        PollValue             : 0x53
        Memory Detail         :
                                 Block Poll               Page                       Polled
          Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
          eeprom        65     5     4    0 no       1024    4      0  3600  3600 0xff 0xff
          flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
          lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
          signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
        Programmer Type : STK500
        Description     : Atmel STK500 Version 1.x firmware
avrdude: Send: A [41] . [80]   [20]
avrdude: Recv:
avrdude: Send: A [41] . [81]   [20]
avrdude: Recv:
avrdude: Send: A [41] . [82]   [20]
avrdude: Recv:
avrdude: Send: A [41] . [98]   [20]
avrdude: Recv:
        Hardware Version: 4174116
        Firmware Version: 4417552.4368076
avrdude: Send: A [41] . [84]   [20]
avrdude: Recv:
avrdude: Send: A [41] . [85]   [20]
avrdude: Recv:
avrdude: Send: A [41] . [86]   [20]
avrdude: Recv:
avrdude: Send: A [41] . [87]   [20]
avrdude: Recv:
avrdude: Send: A [41] . [89]   [20]
avrdude: Recv:
        Vtarget         : 201331441.0 V
        Varef           : 229372.8 V
        Oscillator      : 0.002 Hz
        SCK period      : 2184793003.5 us
avrdude: Recv:
avrdude: Recv:
avrdude: Send: B [42] . [86] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [ff] . [ff] . [ff] . [ff] . [00] . [80] . [04] . [00] . [00] . [00] . [80] . [00]   [20]
avrdude: Recv:
        this check.
avrdude: Send: Q [51]   [20]
avrdude: Recv:
avrdude done.  Thank you.
Foster
For the Mega, the port is 4, and the debug code is here:
Binary sketch size: 17754 bytes (of a 258048 byte maximum)
C:\Documents and Settings\astro\My Documents\Ardunio\hardware/tools/avr/bin/avrdude -CC:\Documents and Settings\astro\My Documents\Ardunio\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM4 -b115200 -D -Uflash:w:C:\DOCUME~1\ASTRO~1\LOCALS~1\Temp\build239277540379715512.tmp\Webserv.cpp.hex:i
        Using Port            : \\.\COM4
        Using Programmer      : stk500v2
avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [02] . [00] . [01] . [0e] . [01] . [17]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [03] . [00] . [01] . [0e] . [01] . [16]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [04] . [00] . [01] . [0e] . [01] . [11]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [05] . [00] . [01] . [0e] . [01] . [10]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [06] . [00] . [01] . [0e] . [01] . [13]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [07] . [00] . [01] . [0e] . [01] . [12]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [08] . [00] . [01] . [0e] . [01] . [1d]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [09] . [00] . [01] . [0e] . [01] . [1c]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [0a] . [00] . [01] . [0e] . [01] . [1f]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [0b] . [00] . [01] . [0e] . [01] . [1e]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [0c] . [00] . [01] . [0e] . [01] . [19]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [0d] . [00] . [01] . [0e] . [01] . [18]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [0e] . [00] . [01] . [0e] . [01] . [1b]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [0f] . [00] . [01] . [0e] . [01] . [1a]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [10] . [00] . [01] . [0e] . [01] . [05]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [11] . [00] . [01] . [0e] . [01] . [04]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [12] . [00] . [01] . [0e] . [01] . [07]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [13] . [00] . [01] . [0e] . [01] . [06]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [14] . [00] . [01] . [0e] . [01] . [01]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [15] . [00] . [01] . [0e] . [01] . [00]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [16] . [00] . [01] . [0e] . [01] . [03]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [17] . [00] . [01] . [0e] . [01] . [02]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [18] . [00] . [01] . [0e] . [01] . [0d]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [19] . [00] . [01] . [0e] . [01] . [0c]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [1a] . [00] . [01] . [0e] . [01] . [0f]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [1b] . [00] . [01] . [0e] . [01] . [0e]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [1c] . [00] . [01] . [0e] . [01] . [09]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [1d] . [00] . [01] . [0e] . [01] . [08]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [1e] . [00] . [01] . [0e] . [01] . [0b]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] . [1f] . [00] . [01] . [0e] . [01] . [0a]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b]   [20] . [00] . [01] . [0e] . [01] 5 [35]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] ! [21] . [00] . [01] . [0e] . [01] 4 [34]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Send: . [1b] " [22] . [00] . [01] . [0e] . [01] 7 [37]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: stk500v2_getsync(): can't communicate with device: resp=0x01
        AVR Part              : ATMEGA2560
        PAGEL                 : PD7
        BS2                   : PA0
        RETRY pulse           : SCK
        Timeout               : 200
        StabDelay             : 100
        CmdexeDelay           : 25
        SyncLoops             : 32
        ByteDelay             : 0
        PollIndex             : 3
        PollValue             : 0x53
        Memory Detail         :
          eeprom        65    10     8    0 no       4096    8      0  9000  9000 0x00 0x00
          flash         65    10   256    0 yes    262144  256   1024  4500  4500 0x00 0x00
          lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
          hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
          efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
          lock           0     0     0    0 no          1    0      0  90
Foster
Noticed all the Mega didn't fit. This is the last part of the trace.
Memory Detail         :
          lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
        Programmer Type : STK500V2
        Description     : Atmel STK500 Version 2.x firmware
        Programmer Model: Unknown
avrdude: Send: . [1b] # [23] . [00] . [02] . [0e] . [03] . [90] . [a7]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: stk500v2_command(): unknown status 0x90
avrdude: stk500v2_getparm(): failed to get parameter 0x90
avrdude: Send: . [1b] $ [24] . [00] . [02] . [0e] . [03] . [91] . [a1]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: stk500v2_command(): unknown status 0x91
avrdude: stk500v2_getparm(): failed to get parameter 0x91
avrdude: Send: . [1b] % [25] . [00] . [02] . [0e] . [03] . [92] . [a3]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: stk500v2_command(): unknown status 0x92
avrdude: stk500v2_getparm(): failed to get parameter 0x92
        Hardware Version: 0
        Firmware Version: 63.183
avrdude: Send: . [1b] & [26] . [00] . [02] . [0e] . [03] . [94] . [a6]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: stk500v2_command(): unknown status 0x94
avrdude: stk500v2_getparm(): failed to get parameter 0x94
        Vtarget         : 0.0 V
avrdude: Send: . [1b] ' [27] . [00] . [02] . [0e] . [03] . [98] . [ab]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: stk500v2_command(): unknown status 0x98
avrdude: stk500v2_getparm(): failed to get parameter 0x98
        SCK period      : 36.9 us
avrdude: Send: . [1b] ( [28] . [00] . [0c] . [0e] . [10] . [c8] d [64] . [19]   [20] . [00] S [53] . [03] . [ac] S [53] " [22] . [00] 9 [39]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: stk500v2_command(): unknown status 0xc8
        this check.
avrdude: Send: . [1b] ) [29] . [00] . [03] . [0e] . [11] . [01] . [01] . [2e]
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: Recv:
avrdude: stk500v2_command(): unknown status 0x01
avrdude: stk500v2_disable(): failed to leave programming mode
