Topic: Analog input as digital input for button (Read 54227 times) previous topic - next topic
Rob311
This is more of a confirmation that i read it right, but i can use my analog inputs as digital inputs right?  i would just use pin 14-19?
Code: [Select]
digitalRead(14); //?
PaulS
Yes, you can use the analog pins as digital pins, by numbering them 14 - 19.
That's the proper way to read the pin. Well, except that the function returns a value that must be important, or you wouldn't have called the function, so toy probably want to store the returned value somewhere.
herctrap
does this also works and for the arduino mega
is this corect?
Code: [Select]
//********** i/o scan modes on analog inputs **********
int scan1 = (8+54) ;
int scan2 = (9+54);
int scan3 = (10+54);
int scan4 = (11+54);
int scan5 = (12+54);
int scan6 = (13+54);
int scan7 = (14+54);
//******************** inputs as i/o for the scan mode ********************
int simplescan = (0+54) ; // i/o switch for simple scann
int sensorenable = (1+54) ; // i/o switch for voice scan
int lightenable= (2+54) ; // i/o switch for light scan
int motionenable = (3+54) ; // i/o switch for motion enable scan
Rob311
You aren't reading the pin.
You would want:
Code: [Select]
int scan1 = digitalRead(8+54) ;
this will give you a 1/0 in scan1 and let you know if anything is connected to port (8+54=)66.
I've never used a mega so you may want to check that whole 8+54 business.
Jeff McD
Quick question:
Is the below correct if i want to read a push button on analog pin (0)?
its a rough version i know, but i just want to check the important parts...
pinmode(14,input);                       // set the pin to input
int BUTTON = digitalread(14);        // read analog pin 0 as digital and set it to a variable
if (BUTTON == HIGH)                   // it shows pressed
else if (BUTTON == LOW)             // it shows not pressed
hardware layout:
5v___button____10k ohm resistor___ground
                   |___analog pin 0
layout done as shown in:
ww.arduino.cc/en/Tutorial/Button
jada
Jeff McD
AWOL
Slower reply, no.
If BUTTON is not HIGH, there is no need to check to see if it is LOW.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
Jeff McD
yea i will prob use an else, but wanted to explain what both scenarios  represented.
btw wouldnt it still be yes, just with unnecessary code  :P
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
