Topic: Digital Output pin set LOW vs. GND pin? (Read 35308 times) previous topic - next topic
retrolefty
#15
Jan 19, 2011, 05:57 am Last Edit: Jan 19, 2011, 05:58 am by retrolefty Reason: 1
Quote
Personally I prefer to use a FET - no resistor needed at all then
Me too. My favorite $1 transistor:
http://www.sparkfun.com/products/10213
All though it is a good safety idea to add a 10k resistor between gate and source, in case arduin power is turn off but device power is still on, that will ensure mosfet stays off.
Lefty
pwillard
#16
Jan 19, 2011, 08:51 pm Last Edit: Jan 19, 2011, 08:56 pm by pwillard Reason: 1
Quote
Sometimes true... but they can also be a lot more finicky when working with TTL logic levels.
Poor transistors... they get no love anymore.  If you talk to them nicely (bias and buffer them them nicely with resistors) they are really quite sweet.
Some good advice: I feel you can never have too many 0.1uF Caps or  1K, 10K, 4.7K resistors, or 2N2222A, 2N2907, 2N7000's in your parts bin.
Quote
N-Channel MOSFET 60V 30A
is overkill for nearly everything I do.  A 2N2222A with one or two resistors can accomplish so much and do it cheaply.
Grumpy_Mike
Quote
Except of course to protect the arduino from over current when it charges the discharged capacitor and drives into an effective short circuit for a small fraction of the time. 100R should be enough to keep it safe.
smeezekitty
What is the gate capacitance of a mosfet gate?
If its less then say, 0.01uf, i would not worry about the spike too much.
Avoid throwing electronics out as you or someone else might need them for parts or use.
Solid state rectifiers are the only REAL rectifiers.
Resistors for LEDS!
retrolefty
Quote
Depends on the specific mosfet and is given in the device datasheet. Larger current ratings have larger gate capacitance.
Lefty
smeezekitty
Even if a gate is 1000pf, it will not blow the pin unless you drive it REALLY fast.
Resistors for LEDS!
Folderol
IRF510 is rated at 100V 5A and has a gate capacitance <200pF.
Rise and fall times are a few tens of nS.
I've driven these directly from an output pin with not the slightest hint of a problem.
Grumpy_Mike
Quote
You won't have until they fail. A short circuit is a short circuit no matter how brefley it occours and it is exceeds the absolute maximum in the data sheets.
stimmer
You definitely need a resistor there in case the MOSFET fails. Because they very often fail with the gate short-circuiting to one of the other pins. The result is that your high-power motor or light or heater could be effectively wired directly from high voltage to the Arduino's pin, unless you have a protective resistor.
I've also found I need a gate-source resistor like Retrolefty suggested. Even the brief time a pin is high-impedance during a reset cycle was enough to fry one of my MOSFETS :( And they switch on so much current so quickly it induces spiky voltages all over the place, I had to add some capacitance just to slow the things down.
I'm very jealous of all you people who have them working wired directly!  :-[ Mine need at least two resistors and a capacitor...
Due VGA library - http://arduino.cc/forum/index.php/topic,150517.0.html
