Topic: Arduino Duemilanove (Read 9722 times) previous topic - next topic
cellage
[size=14]Hello People
I recently brought Arduino [glow]Duemilanove[/glow] when i connected it to my windows 7 laptop , the system crashed and it behaves as if the Duemilanove was an attacking object, it didn't accept it .
now am afraid to connect it again after i fixed the PC.
I was very excited to use it, whats the problem and what shall I do ? :-/[/size]
pluggy
Paranoid PC.  I very much doubt an Arduino would pose any threat.  It barely has the power......
http://pluggy.is-a-geek.com/index.html
cellage
i know its Innocent but how do i convince my PC that it is ?
pluggy
We're going to need some clues.  What makes you think the PC thinks the Arduino a threat ?
u0421793
Was it before or after it said "Klaatu barada nikto"?
James C4S
You'll need to give a more detailed description on what is going on, if you want a serious answer.
cellage
ok right after i connected the board the computer turned off and every time i turned it on i got a blue screen with a Physical memory dump error, i could reach my files but it kept restarting, So please any suggestion now i want to connect it to another lenovo laptop with vista operating system and not sure of doing it
pluggy
Sounds like a seriously sick PC to me.  As far as the PC is concerned the arduino appears as a serial over USB connection. If just plugging that in causes it to blue screen, the problem is your PC.  It shouldn't cause a problem on a PC that works properly.  It certainly isn't a threat.
If you are really worried, you could remove the 328/168 chip from the Duemilanove and then try it, it has no capabilities beyond being a serial interface like that.  If it still blue screens, which is likely, the problem is definitely the PC.
cellage
Grumpy_Mike
The other thing is you could have a short circuit on the arduino and the computer is shutting down because of it. Most computers have some sort of protection on the USB port but you could be taking the main power supply out with your board or faulty lead.
James C4S
This sounds more like a physical problem on the board, as mike suggestions.  Since the computer is turning off the blue screen on power-up could just be a result of the hard shutdown.
It may be that your USB port's short circuit protection is either not work or non-existant.
cellage
Its been so long but i wanted to tell anyone who had this problem , that I connected the arduino to my Vista and it's been working very well.
