Topic: 2.8" Touch LCD e Placa de desenvolvimento (Read 956 times) previous topic - next topic
camolas
Oct 06, 2010, 05:06 pm Last Edit: Oct 06, 2010, 05:51 pm by camolas Reason: 1
Boas malta,
Tenho para vender esta board com o lcd touch esta como nova apenas a liguei para ver se estava todo bem ela tras um programa demo para exprimentarmos o touch e esta tudo ok.
Vendo por ter de abandonar por agora o projecto ( falta de ?? !! ). Tambem fabrico tb PCB pelo metodo de fresagem por CNC se estiverem intressados por favor contactem para oriun1@clix.pt.
Sou de Penafiel e posso entregar em mao na zona do grande porto.
Obrigado e um abraço para todos e desculpem o topico  :-[
Preço do Lcd e board 50? Portes incluidos.
Carateristiscas e funçoes.
CPU: STM32F103RBT6; (LQFP64-pin, on-chip integrated 128K flash, 20KRAM, 16Bit A / D; PWM, CAN, USB and other resources)
With a 2.8-inch TFT true color touch screen module, color touch module configuration ADS7843 (or RSM1843 instead) controller, support for a SD card (SPI mode) can be used to store pictures, in support of AT45DBxxx of a DATA FLASH (can be used for storage)
USB interface, make USB experiment
USB to RS232 interface (ISP download), make RS232 communicate experiment
AD adjuster
Standard ARM JTAG 20 pin
A RTC in support, the four users LED lights, a power indicator light, a USB communication indicator, two user keys
8MHz crystal,32.768KHz crystal
USB power supply or power supply by J-Link
All I / O port through the standard pitch leads 2.54MM
Board Size: 82MM X 68MM
Rich in routines, not only functional modules MDK-board test-source: LED lights examples, RTC, USB, SD card, ADC, touch-screen test, TFT LCD screen test .....
but also there are successful transplantation UCOS2, UCGUI a number of routines can be directly applied to industrial control equipment or hand-held instrument of human-computer interface design, so that your product from the monotony of black and white, into the colorful world! Inspire your design inspiration!
Fresagem de PCB
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
