Loading...
Pages: [1]   Go Down
Author Topic: SparkFun LED-Matrix  (Read 604 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
ich würde gern mit einer 8x8 RG-LED-Matrix (die von SparkFun mit SPI-Backpack) Bilder und Lauftexte darstellen. Einen Inhalt einmal darstellen klappt auch schon.
Ich habe mich an den Code aus dem Forum gehalten.
Code:
// Simple program to test using the Arduino with the RGB Matrix
// & Backpack from Sparkfun. Code is a combination of Heather Dewey-Hagborg,
// Arduino Forum user: Little-Scale, and // Daniel Hirschmann. Enjoy!
// The Backpack requires 125Khz SPI, which is the slowest rate
// at which the Arduino's hardware SPI bus can communicate at.
// We need to send SPI to the backpack in the following steps:
// 1) Activate ChipSelect;
// 2) Wait 500microseconds;
// 3) Transfer 64bytes @ 125KHz (1 byte for each RGB LED in the matrix);
// 4) De-activate ChipSelect;
// 5) Wait 500microseconds
// Repeat however often you like!
#define CHIPSELECT 10//ss
#define SPICLOCK  13//sck
#define DATAOUT 11//MOSI / DI
#define DATAIN 12//MISO / DO
int data[] =
{0,0,0,0,0,0,0,0,
0,0,1,1,0,1,1,0,
0,1,0,0,1,0,0,1,
0,1,0,0,0,0,0,1,
0,0,1,0,0,0,1,0,
0,0,0,1,0,1,0,0,
0,0,0,0,1,0,0,0,
0,0,0,0,0,0,0,0
char spi_transfer(volatile char data)
SPDR = data;                    // Start the transmission
while (!(SPSR & (1<<SPIF)))     // Wait the end of the transmission
byte clr;
pinMode(DATAOUT,OUTPUT);
pinMode(SPICLOCK,OUTPUT);
pinMode(CHIPSELECT,OUTPUT);
digitalWrite(CHIPSELECT,HIGH); //disable device
SPCR = B01010001;             //SPI Registers
SPSR = SPSR & B11111110;      //make sure the speed is 125KHz
SPCR bits:
 7: SPIEE - enables SPI interrupt when high
 6: SPE - enable SPI bus when high
 5: DORD - LSB first when high, MSB first when low
 4: MSTR - arduino is in master mode when high, slave when low
 3: CPOL - data clock idle when high if 1, idle when low if 0
 2: CPHA - data on falling edge of clock when high, rising edge when low
 1: SPR1 - set speed of SPI bus
 0: SPR0 - set speed of SPI bus (00 is fastest @ 4MHz, 11 is slowest @ 250KHz)
clr=SPSR;
clr=SPDR;
delay(10);
  delay(100);
  int index = 0;
  digitalWrite(CHIPSELECT,LOW); // enable the ChipSelect on the backpack
  delayMicroseconds(500);
  for (int i=0;i<8;i++) for (int j=0;j<8;j++)
    spi_transfer(data[index]);
      index++;
  digitalWrite(CHIPSELECT,HIGH); // disable the ChipSelect on the backpack
Was mir aber einfach nicht gelingen will, ist die Schleife in der Art zu erweitern um nach einer einem delay ein weiteres Bild zu zeigen.
Ist das denn der richtige Ansatz? Kann mir jemand ein wenig auf die Spünge helfen?
Gruß
Logged
Bangkok
Offline Offline
Full Member
freeduino.de Admin
View Profile
WWW
ich hab damit keine rfahrungen, aber es sieht so aus als seine das shift register, ich glaube die muss man erst leeren bevor man das neue bild schreiben kann.
Logged
Pages: [1]   Go Up
Print
Jump to:
