Topic: Very important about eye blinking in Neurosky with Arduino (Read 1 time) previous topic - next topic
abdullah25
hi  :)
I am working on a robot run by Neurosky mindwave
right by on blink
left by two blink
forward meditation
backward attention
and i see  this code from www.pantechsolutions.net
 the code blink this
//    Program       : Mindwave with Arduino                //
//    Interfacing   : HC-05 Bluetooth Module               //
//    Output        : Eye Blink Control LED                //
#define   BAUDRATE           57600
#define   LED                8
#define   Theshold_Eyeblink  110
#define   EEG_AVG            70
long payloadDataS[5] = {0};
long payloadDataB[32] = {0};
byte checksum=0,generatedchecksum=0;
unsigned int Raw_data,Poorquality,Plength,Eye_Enable=0,On_Flag=0,Off_Flag=1 ;
unsigned int j,n=0;
long Temp,Avg_Raw,Temp_Avg;
   Serial.begin(BAUDRATE);           // USB
   pinMode(LED, OUTPUT);
 byte ReadOneByte()           // One Byte Read Function
   int ByteRead;
   while(!Serial.available());
   ByteRead = Serial.read();
   return ByteRead;
 void loop()                     // Main Function
   if(ReadOneByte() == 170)        // AA 1 st Sync data
     if(ReadOneByte() == 170)      // AA 2 st Sync data
       Plength = ReadOneByte();
       if(Plength == 4)   // Small Packet
         Small_Packet ();
       else if(Plength == 32)   // Big Packet
         Big_Packet ();
 void Small_Packet ()
   generatedchecksum = 0;
   for(int i = 0; i < Plength; i++)
     payloadDataS     = ReadOneByte();      //Read payload into memory
     generatedchecksum  += payloadDataS ;
   generatedchecksum = 255 - generatedchecksum;
   checksum  = ReadOneByte();
   if(checksum == generatedchecksum)        // Varify Checksum
     if (j<512)
       Raw_data  = ((payloadDataS[2] <<8)| payloadDataS[3]);
       if(Raw_data&0xF000)
         Raw_data = (((~Raw_data)&0xFFF)+1);
         Raw_data = (Raw_data&0xFFF);
       Temp += Raw_data;
       j++;
       Onesec_Rawval_Fun ();
 void Big_Packet()
     payloadDataB     = ReadOneByte();      //Read payload into memory
     generatedchecksum  += payloadDataB ;
     Poorquality = payloadDataB[1];
     if (Poorquality==0 )
       Eye_Enable = 1;
       Eye_Enable = 0;
 void Onesec_Rawval_Fun ()
   Avg_Raw = Temp/512;
   if (On_Flag==0 && Off_Flag==1)
     if (n<3)
       Temp_Avg += Avg_Raw;
       n++;
       Temp_Avg = Temp_Avg/3;
       if (Temp_Avg<EEG_AVG)
         On_Flag=1;Off_Flag=0;
       n=0;Temp_Avg=0;
   Eye_Blink ();
   j=0;
   Temp=0;
 void Eye_Blink ()
   if (Eye_Enable)
     if (On_Flag==1 && Off_Flag==0)
       if ((Avg_Raw>Theshold_Eyeblink) && (Avg_Raw<350))
         digitalWrite(LED,HIGH);
         if (Avg_Raw>350)
           On_Flag==0;Off_Flag==1;
         digitalWrite(LED,LOW);
this code one blink only
and i want this code by two blink how????
any information about this give me
thank you  :)
AWOL
Now, hopefully, you can see why we ask you to use code tags when posting code.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
sarano
Hi! Can i do the same work using the  shield module (RN42) instead of the module hc-05? Thank you!
