Loading...
Pages: [1]   Go Down
Author Topic: 8x8 matrix mit 74hx595 am pc steuern  (Read 225 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
also ich habe die Nacht mal eine Matrix mit 64 Blauen Led´s  sprich 8x8 zusammen gelöttet . dies mit 2 74hc595 versehen soweit gehen auch die Matrix  . nun wie kann man am pc aus eine nachricht zb an den arduino senden der es dann in der matrix ausstrahlt.
Gibt es da was ich habe es nur geschaft bisher blink blink  also hier mal den code bisher
#include <TimerOne.h>
//Pin connected to Pin 12 of 74HC595 (Latch)
int latchPin = 8;
//Pin connected to Pin 11 of 74HC595 (Clock)
int clockPin = 12;
//Pin connected to Pin 14 of 74HC595 (Data)
int dataPin = 11;
uint8_t led[8];
long counter1 = 0;
long counter2 = 0;
//set pins to output
pinMode(latchPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
led[0] = B11111111;
led[1] = B10000001;
led[2] = B10111101;
led[3] = B10100101;
led[4] = B10100101;
led[5] = B10111101;
led[6] = B10000001;
led[7] = B11111111;
Timer1.initialize(10000);
Timer1.attachInterrupt(screenUpdate);
counter1++;
if (counter1 >=100000) {counter2++;}
if (counter2 >= 10000) {
counter1 = 0;
counter2 = 0;
for (int i=0; i<8; i++) {
led= ~led;
void screenUpdate() {
uint8_t row = B00000001;
for (byte k = 0; k < 9; k++) {
// Open up the latch ready to receive data
 digitalWrite(latchPin, LOW);
shiftIt(~row );
shiftIt(led[k] ); // LED array
// Close the latch, sending the data in the registers out to the
digitalWrite(latchPin, HIGH); row = row << 1;
void shiftIt(byte dataOut) {
// Shift out 8 bits LSB first,
// on rising edge of clock
boolean pinState;
//clear shift register read for sending data
digitalWrite(dataPin, LOW);
// for each bit in dataOut send out a bit
//set clockPin to LOW prior to sending bit
digitalWrite(clockPin, LOW);
// if the value of DataOut and (logical AND) a bitmask
// are true, set pinState to 1 (HIGH)
if ( dataOut & (1<<i) ) {
pinState = HIGH;
else {
pinState = LOW;
//sets dataPin to HIGH or LOW depending on pinState
digitalWrite(dataPin, pinState);
//send bit out on rising edge of clock
digitalWrite(clockPin, HIGH);
//stop shifting
Logged
Pages: [1]   Go Up
Print
Jump to:
