Topic: Serial Decimal Reading? (Read 2113 times) previous topic - next topic
12thspy
I have  project where i am wanting to read a decimal value through the serial monitor.  But all my data truncates to an integer it seems.  Below is my code which should do a simple count at 1.1, 2.1, 3.1 etc.  but all i get 1 2 3 4 etc.
Thoughts?
float count = 1.1 ;
void setup()                    // run once, when the sketch starts
 Serial.begin(9600);           // set up Serial library at 9600 bps
 count = count + 1.0;
 Serial.print(count, DEC);
 delay(10);                  // 1 sec delay to keep things in control
halley
In Arduino libraries up to 0012, there is no built-in way to print a float variable to the serial port.  What you're using is casting the value to an integer.  There are a number of home-grown functions here to fill that gap.  I've heard 0013 will have a float-to-string or float-to-print capability but I don't know the details.
12thspy
hmmm, then what is the point of the DEC option?
Serial.print(b, DEC) prints b as a decimal number in an ASCII string
halley
As opposed to printing it in HEX, or as a BYTE value.  In computing, the word "decimal" means "in base ten, digits 0 to 9," not particularly "with a decimal point and fractional parts afterward."
12thspy
Ah, that clears things up for me.  Good to know, guess i will just have to manually break down the values as i need.
Thank you much for you prompt info.
